DeWalt Bluetooth Charger Radio
Charge your batteries, charge your phone, and stream your music - all-in-one.
The DCR025, a new Charger Radio from DeWalt, can run off of 20V Max and Flexvolt batteries, and a power cord. It offers 3Amp charging of 20V Max and 60V Max batteries when plugged in. What’s cool about this radio is that it has 2 additional power outlets on the side so it acts as a sort of power station when the unit is plugged into an outlet. It won’t power the onboard outlets from batteries, but their portable power station will. The radio is Bluetooth enabled, so you can stream music from your smartphone while charging it off of the built-in 2.1AMP USB port. If you don’t want to stream music you can plug your device into the AUX port. And on the side, there’s a bottle opener so you don’t have to go searching for one. Cost: $199
Check out the video to learn more.
