M.Power CRB7 Combination Router Base Set
The M.Power CRB7 router base, compatible with most routers, adds functionality to the tool. The wide footplate helps with tilt support and easier offset routing. Using the base, a router can cut circles with diameters from 3/4 inch to 8 3/4 inches. Two small legs can be attached to the bottom to improve accuracy while mortising; they also add stability when cutting thin materials. In addition, the base can be set up to create repetitive dadoes, like on a faux panel. Also comes with an anti-tilt leg.
Price: $110 / COO: UK / +44 (0) 1980 629 526. / m-powertools.com
Doug Mahoney
