A.Michael Byrne
responds: If the tiles in question will be
used to cover a serving counter that is normally
dry, then they can be set directly over plywood
with an epoxy mortar or an organic adhesive. But if
a sink is part of the installation, plywood should
not be used as the base for tiles.
The American National Standards Institute (ANSI)
specification for tile characterizes plywood as
dimensionally unstable and not ideal backing for
ceramic or stone tiles. Nevertheless, many thinset
mortar manufacturers produce tile adhesives
specifically for use with plywood.
In my work, if plywood is specified in plans and
must be used as the base for tiles, I get the
architect or GC to include a waterproofing
membrane. I recommend either a sheet membrane, such
as NobleSeal TS (The Noble Co., P.O. Box 350, Grand
Haven, MI 49417; 616/842-7844), or a trowelapplied
membrane, such a Laticrete 92-36 (Laticrete
International, One Laticrete Park North, Bethany,
CT 06525; 800/243-4788).
A better approach than using plywood, however,
is to use cement backerboard, which is made
specifically for tiles. Cement backerboards provide
a tough base for ceramic or stone tiles, and are
unaffected by water or moisture.
For moderate protection against moisture
penetration, the backerboard can be laminated
directly to a plywood base with latex-modified
thinset mortar. For a commercial or active
residential kitchen or bathroom countertop,
however, I recommend combining the backerboard with
a waterproofing membrane as the base for the
countertop tiles.
Michael Byrne is a tile consultant and
specialty installer based in Burlington,
Vt.
