Download PDF version (2626.6k) Log In or Register to view the full article as a PDF document.
Launch Slideshow
EIFS Revisited
EIFS Revisited
  • http://www.jlconline.com/Images/965860020_1012_JLC_EIFS_00a_tcm96-1079580.jpg
    600
  • http://www.jlconline.com/Images/1743310768_1012_JLC_EIFS_01a_tcm96-1079588.jpg
    600
    Before applying the WeatherSeal elastomeric waterproofing membrane, workers use plywood and duct tape to prevent the coating from dripping onto a concrete porch floor.
  • http://www.jlconline.com/Images/904830581_1012_JLC_EIFS_01b_tcm96-1079596.jpg
    600
    The blue membrane is troweled onto seams and joints.
  • http://www.jlconline.com/Images/1607406250_1012_JLC_EIFS_01c_tcm96-1079604.jpg
    600
    The membrane is reinforced with a special joint tape.
  • http://www.jlconline.com/Images/768926063_1012_JLC_EIFS_01d_tcm96-1079612.jpg
    600
    Once the joints are treated, the entire surface will be skim-coated with the membrane.
  • http://www.jlconline.com/Images/281817767_1012_JLC_EIFS_02a_tcm96-1079620.jpg
    600
    Once the WeatherSeal membrane has been installed, DrainEdge termination strips are stapled over door and window openings, followed by backwrapping mesh.
  • http://www.jlconline.com/Images/213865508_1012_JLC_EIFS_02b_tcm96-1079628.jpg
    600
    The EPS panels are glued to the walls with adhesive that's been applied with a notched trowel. The notches are vertically oriented so that moisture can drain down the channels between the membrane and the foam and out of the wall assembly wherever the DrainEdge has been installed.
  • http://www.jlconline.com/Images/1103712931_1012_JLC_EIFS_02c_tcm96-1079636.jpg
    600
    Installing the EPS panels.
  • http://www.jlconline.com/Images/1454916709_1012_JLC_EIFS_03a_tcm96-1079644.jpg
    600
    Molded polyethylene kick-out flashings, like this one from Raintek, can be trimmed to fit different foam thicknesses. Kick-out flashings are installed with the step flashings.
  • http://www.jlconline.com/Images/548652376_1012_JLC_EIFS_03b_tcm96-1079652.jpg
    600
  • http://www.jlconline.com/Images/1319012191_1012_JLC_EIFS_03c_tcm96-1079660.jpg
    600
  • http://www.jlconline.com/Images/1063788178_1012_JLC_EIFS_03d_tcm96-1079668.jpg
    600
  • http://www.jlconline.com/Images/38036237_1012_JLC_EIFS_04a_tcm96-1079676.jpg
    600
    The author fabricates trim details like these bullnose returns with a hot wire cutter.
  • http://www.jlconline.com/Images/576511769_1012_JLC_EIFS_04b_tcm96-1079684.jpg
    600
    After the foam has been glued to the walls, all of the gaps between panels are filled with spray foam.
  • http://www.jlconline.com/Images/1047203155_1012_JLC_EIFS_05a_tcm96-1079692.jpg
    600
    Base-coat application can begin after the foam has been leveled with a rasping board and abraded with a grit-welded float. Inside and outside corners get a double thickness of reinforcing mesh bedded in the base coat.
  • http://www.jlconline.com/Images/979250896_1012_JLC_EIFS_05b_tcm96-1079700.jpg
    600
    To help with adhesion, these walls received a second base coat, which was then scratched with diamond mesh lath.
  • http://www.jlconline.com/Images/72986563_1012_JLC_EIFS_06a_tcm96-1079708.jpg
    600
    Most EIF systems have a smooth and uniform finish coat, but this home was given a deeply textured finish coat to match the Mediterranean architecture.
  • http://www.jlconline.com/Images/543677949_1012_JLC_EIFS_07a_tcm96-1079716.jpg
    600
    Expansion joints are needed in EIFS cladding wherever two dissimilar substrates meet, such as at the foundation.
  • http://www.jlconline.com/Images/1082153481_1012_JLC_EIFS_08a_tcm96-1079724.jpg
    600
    Corbels and other architectural details can be added to EIFS cladding by gluing foam profiles to the EPS before applying the base coat and finish. Areas that don’t require insulation, like the columns supporting the arches on this home, can be wrapped with cement backerboard instead of foam, which gives them better impact resistance.
  • http://www.jlconline.com/Images/1552844867_1012_JLC_EIFS_08b_tcm96-1079732.jpg
    600
    The finished project
DrainEdge and Backwrapping
WeatherSeal dries quickly — in less than an hour in most conditions — so we can immediately start stapling up lengths of backwrap reinforcing mesh. Backwrapping is needed wherever there will be penetrations through the foam; the mesh is eventually embedded in the cementitious base coat after the EPS foam is installed. Backwrapping encapsulates the edge of the foam; it’s a fire-stopping measure required by code.
At horizontal terminations where water needs to weep out — above windows and doors and at the bottom edge of the wall — we first staple lengths of Parex’s DrainEdge before installing the backwrap mesh (Figure 2). DrainEdge is basically Tyvek that’s been perforated with 3/16-inch-diameter holes spaced about one inch apart. It comes in 9-inch-wide rolls. Embedded in adhesive, it acts as a bond-breaker between the waterproofing membrane and the adhered foam, creating a capillary break that allows water to drain. We prefer DrainEdge to the vented track used by many EIFS installers because it won’t get clogged by the extremely adhesive base coats we use.
The backwrapping mesh goes on over the DrainEdge. Depending on the thickness of the foam, we leave 2 to 4 inches of the DrainEdge extending out the bottom, and enough mesh to completely wrap around to the front face of the foam. After finishing, we trim the DrainEdge so that it can’t be easily seen. Installing Kick-Out Flashings
EPS Installation
The minimum foam thickness for EIFS installations in our area is 1 1/2 inches (which provides a little more than R-5 to the wall assembly), but 2 inches is more common. On this project, the homeowners wanted at least 4 inches of foam for better R-value, and a bullnose profile around their inset windows and doors, so we used 5-inch- thick panels to get the required radius (see slideshow). Regardless of panel thickness, we always glue the 2-foot-by-4-foot EPS sheets to the wall instead of attaching them with mechanical fasteners.
We typically apply adhesive directly to the foam panels rather than to the wall, using a 3/8-inch-by-1/2-inch-by-1 1/4-inch U-notched trowel. Because we orient the ribbons of adhesive vertically rather than randomly, they provide passive drainage, so that water can move down the wall and out through the DrainEdge termination strips (hence the name of the system, VNT — vertical notched trowel).
When we install the EPS panels, we run them horizontally in a running bond pattern. This helps us eliminate continuous lines in the foam and joints over vertical and horizontal sheathing seams, which tend to telegraph through the finish. At the corners, we stagger the joints so that the panels interlock. We also try to cut out door and window corners from single sheets of foam, rather than create joints in the foam over the corners of window and door openings. There should be least 6 inches of clearance between the foam and unpaved grade, and 2 inches of clearance at paved areas. Rooflines and balconies require at least one inch of clearance.
After installing the panels, we stuff slivers of cut foam into large gaps and fill smaller cracks, joints, and seams with canned foam. If there are high spots, we level the foam with a rasping board. Then we abrade the entire surface with a grit-welded 6-inch-by-13-inch float so that the panel pattern won’t telegraph through the stucco finish. To create built-out trim details, we laminate additional decorative layers of EPS foam to the surface. Afterward, we thoroughly clean loose EPS particles from the surface with brooms and brushes.
