Drainage Plane
Installation of the DuroScreen system begins with the base
flashing, followed by the barrier paper (Figure 7).
Figure
7. Installation of the drainage plane begins with vinyl
or metal base flashing (left). The building is then wrapped in
felt paper or Stuccowrap, with 4- to 6-inch overlaps at the
joints (middle), followed by staple-on mesh furring strips,
which provide an air space behind the Durock (top right). Extra
care is taken to make windows and other openings watertight
(bottom right), using a self-sealing barrier tape where
needed.
On this job, we used 15-lb. felt paper. (As an alternative
to felt paper, DuPont Stuccowrap was recently approved by USG
for use with its systems. Similar to Tyvek, Stuccowrap is
ribbed to encourage drainage.) The lowest course of felt is
lapped over the upper leg of the base flashing, and successive
courses are overlapped 4 to 6 inches. We pull the paper around
outside corners and seal any holes with water barrier tape, a
heavy self-sealing bituminous tape with a release sheet.
At windows, doors, and other openings, we cut the felt paper
horizontally at the top and bottom of the opening, then
vertically down the center, and wrap it into the opening around
the jack studs. To keep the drainage plane intact, however,
it’s important not to wrap the felt paper around headers.
Instead, we use a piece of starter track together with a
special vinyl drip cap. When correctly installed, the felt
covers the flanges of these flashings so that any water is
channeled away from the building.
Furring lath, when specified, goes on next. The special mesh
strips are designed to be stapled on top of the
weather-resistive barrier at each stud location to create a
small gap behind the Durock. Many engineers will specify the
furring lath as extra drainage insurance in a retrofit, but
it’s not needed if the house is wrapped with ribbed
Stuccowrap.
