Damp-spray cellulose stops air infiltration, offers
excellent sound insulation,and costs only slightly more than
fiberglass batts
by Michael Uniacke
In the hierarchy of the building trades, insulation
contractors are often considered about half a step above the
porta-john guy. That's because insulation is one of the most
taken-for-granted systems in a house. It's installed in
exterior walls one day and covered up with sheetrock the next,
and few municipalities have substantive insulation inspections.
The result is little accountability or quality control on the
majority of jobs I inspect.
In spite of all that, insulation can and should be done
right. My company, Advanced Insulation in Prescott, Ariz.,
works with several types of insulation, but our workhorse
product for wall applications is damp-spray cellulose (formerly
known as wet-spray cellulose).
That preference is based on years of experience in our
marketplace, which is at 5,000 feet elevation and has a climate
similar to that of Denver. We've found that walls insulated
with spray cellulose are more thermally efficient than those
with fiberglass batts. In our 5,000 heating-degree-day climate,
we are seeing 1,600-square-foot homes that don't require
conventional forced-air heating systems. In some cases, the
actual heating load is so small that it can be handled by a
heater-rated gas log fireplace. Equally important, our
customers tell us that spray cellulose provides a much more
comfortable house.
Spray cellulose does cost a little more than batts —
in our market, it's about $.60 per square foot of wall area,
compared to $.42 for fiberglass, or an additional $250 or so
for a typical 2,000-square-foot house — but the gain in
energy efficiency and overall comfort makes the investment well
worth it.
Cellulose Basics
Cellulose fiber is produced from paper, which in turn is
derived from wood. However the insulation is installed —
blown into the attic or damp-sprayed into wall cavities —
the material is the same. It comes packed in bags that weigh
from 25 to 35 pounds apiece (see Figure 1). By weight, about
82% to 85% of the material is cellulose fiber — most of
which is reprocessed from old newspaper — with the
remainder consisting of chemical fire retardant. The fire
retardants are added in the form of a dry powder. The borate
chemicals used — often in combination with ammonium
sulfate — also add mold, insect, and rodent resistance.
We often use an all-borate insulation called Incide (Hamilton
Manufacturing, 901 Russet St., Twin Falls, ID 83301;
208/733-9689; ) that is designed to prevent infestation by
termites and other insects throughout the life of the
structure.
| Figure
1. The same cellulose material is used for both
wall-spray and loose-fill applications. A typical
whole-house wall-spray application requires 60-120
bags. |
Although pure cellulose is flammable, the added fire retardants
make cellulose insulation a safe material. The cellulose
manufacturing industry adheres to strict standards set by the
ASTM and Consumer Products Safety Commission, and at least
three of the ten material attributes considered by the ASTM
(thermal resistance, surface burning characteristics, adhesive
and cohesive strength, smoldering combustion, fungi resistance,
corrosiveness, moisture vapor absorption, odor, and flame
resistance permanency) relate directly to fire safety. Test
data consistently show that the fire resistance of cellulose is
as good as or better than that of most insulating materials.
According to Canada's National Research Council, for example,
cellulose-insulated walls are from 22% to 55% more fire
resistant than uninsulated walls. Walls insulated with
fiberglass were found to be slightly less fire resistant than
uninsulated walls.
My own experience has led me to the conclusion that
cellulose insulation simply does not burn, partly because of
the added fire retardants but also because cellulose contains
few voids, excluding the air necessary for combustion. Not long
ago a plumber working in a house that we had recently insulated
got careless with a torch and set fire to a stud. The stud and
adjacent insulation smoldered all night and filled the
crawlspace with smoke, but the fire never spread. I've also
inspected hundreds of attics insulated by others in which
cellulose was carelessly blown against B-vent chimneys, on top
of metal fireplaces, and against recessed cans and other hot
points, and although I've occasionally seen slight charring,
I've never seen evidence of fire. (I've also seen charring of
the kraft facing of improperly placed fiberglass batts.) It
goes without saying that such practices should be avoided, but
it's reassuring to know that even under such worst-case
conditions, the material won't burn.
Why Damp Spray?
In a blown cellulose installation, the material is simply
blown into place in a loose, unconsolidated state. This is
commonly done in attics, where the cellulose is supported by
the ceiling beneath. Loose-fill cellulose can also be blown
into enclosed walls in remodeling applications — an
application known as dense-pack cellulose — although it
can be tricky to do that without leaving hidden voids.
Damp spray, on the other hand, is self-sticking, so it can
be placed in open wall cavities that are backed by sheathing or
spray mesh.
Blown and damp-spray cellulose use the same basic equipment
— typically, a truck-mounted insulation-blowing machine
that delivers the material through a 21/2-inch hose — but
with one important difference: The nozzle of a damp-spray hose
contains a separate water nozzle that mixes the cellulose with
a fine water spray as it emerges (Figure 2). The water, which
is delivered at 200-300 psi, comes from a truck-mounted tank
through a hose like that used on pressure washers. The
200-gallon tanks on our trucks contain enough water to complete
a typical house.
Figure
2. A high-pressure water nozzle moistens both
the surface to be sprayed and the insulation as it is
blown from the hose. The water flow is adjustable by
the operator, who must supply enough moisture to get
the insulation to adhere properly but not so much that
excess moisture leads to nail pops and other problems.
Freshly applied spray cellulose should contain between
30% and 40% moisture by weight. |
Fiber and water. When the
spray nozzle is properly adjusted, it delivers a fine spray
that simultaneously moistens the studs and sheathing as well as
the insulation itself. The moistened fibers then adhere
strongly to both the substrate and one another.
This bond gets even stronger as it dries, which makes
correctly installed spray cellulose very resistant to settling.
At the recommended density of 3 pounds per cubic foot, it's
reliably self-supporting. (For comparison, loose-fill attic
insulation is typically installed at about 1.6 pounds per cubic
foot.) Some cellulose manufacturers regularly test their
products in a machine that vibrates an 8-foot-tall wall cavity
for 24 hours to simulate 20 years of normal vibration. For a
product to meet the standard, no more than a quarter-inch gap
can appear at the top of the cavity.
Some damp-spray cellulose used in commercial construction
— for coating gym ceilings, for example, where the
insulation will be left exposed — contains adhesives that
provide an even stronger bond. A similar technique is used for
blowing insulation against the masonry walls of unvented
crawlspaces. But this is overkill in residential wall cavities
and complicates cleanup, so we don't use added adhesives
there.
Figure
3. A 24-foot box truck holds up to 200 bags of
insulation, as well as the blower, water supply, and
other equipment. We try to get as close to the job as
possible, but our equipment is powerful enough to push
material up to 250 feet if necessary. |
