Insulating With Spray Cellulose
- Continued
A wall-spray job begins by prepping the house. The
combination of moisture and cellulose can leave quite a mess,
so all windows and electrical outlets are covered with
polyethylene and electrical boxes are protected with tape
(Figure 4).
| Figure
4. As protection from overspray, windows are
covered with poly (above), and electrical boxes are
taped over (left). |
Add water. The key to a
good spray job is achieving a proper blend of air, fiber, and
water. We've seen and heard about installations in which the
product was sprayed so wet that the water literally started to
seep out of the bottom of the cavity just as it would from a
saturated sponge. That is unacceptable. Normally, the
liquid-to-fiber ratio should be .3 to .4 pounds of water per
pound of fiber, or about a gallon of water per bag of
insulation. In simple terms, this means that the applied
material should be damp but not wet. A basic test we often use
is to grab a handful of wall-spray cellulose right after it is
sprayed and squeeze it. If any water can be squeezed out, the
mix is too wet.
Scrubbing and scraping.
The spraying itself goes pretty quickly. It takes about 30 to
45 seconds to fill an 8-foot wall cavity, and a three- or
four-person crew can spray a 3,000- to 4,000-square-foot house
in a day. Spraying well takes some experience. If you spray at
too oblique an angle or don't get close enough, gaps may appear
between the cellulose and the framing. This happens most often
in the last three to five inches below a plate or sill,
resulting in a horizontal defect we call a "smile" (Figure
5).
| Figure
5. "Smiles" are horizontal gaps that result from
poor technique when spraying below window sills,
plates, or blocking. To correct the problem, the worker
is compressing the insulation by hand before
re-spraying the affected area. |
When a cavity is sprayed, it is filled past the face of the
studs. This fills the cavity completely but also creates
another step. We use a tool called a scrubber — a
rotating brush that rides on the face of the studs — to
cut or shave the cellulose flush with the face of the studs
(Figure 6). Our usual crew consists of one worker to spray, one
or two to move material and keep the hopper filled, and one to
run the scrubber and keep the job clean.
Figure
6. The area at left in this photo has already
been scrubbed, leaving the faces of the studs flush
with the surface of the cellulose. The scrubbed-off
material accumulating on the floor will later be
collected, combined with fresh material, and reapplied
elsewhere. |
The scrubber works well on open expanses of wall, but it
can't get all the way into inside corners, so there's always
some hand work as well. To clean out corners and other
obstructed areas, we use a wide-bladed paint scraper with a
threaded socket on the handle. This accepts an extension handle
like those used with paint rollers, making it possible to reach
the angle between wall and ceiling (Figure 7). To allow the
blade to slide easily over the framing rather than digging in,
we often cover the metal edge with a strip of duct tape.
Figure
7. Damp, freshly sprayed cellulose comes off
easily, but the material sticks firmly when dry.
Corners and other areas too tight for the scrubber to
handle are cleaned with a paint scraper fitted with a
pole extension. |
