by Joe
Lstiburek
The four hurricanes that struck Florida last summer proved the
effectiveness of the tough building codes passed by the state
after Hurricane Andrew's strike in 1992. Hurricanes Charley,
Frances, Ivan, and Jeanne killed dozens of people, but not one
of those deaths was caused by failure of any structure built to
the new codes.
Unfortunately, though, many stucco-clad homes in the state
experienced a problem we would not be discussing if they had
simply fallen down or blown away: They got wet.
After 20-plus inches of windblown rain soaked the whole region,
there were hundreds of reports of water intrusion through
stucco walls of otherwise undamaged homes. The Florida Home
Builders Association hired my company, Building Science
Corporation, to investigate the situation, identify causes, and
propose solutions.
We applied a wide range of investigative techniques (see Figure
1): We inspected homes soaked by the storms as well as new
homes built after the storms; we tested and experimented with
new buildings and mocked-up assemblies; and we did bench-top
testing of materials and components, including felt paper,
plastic housewraps, and windows. We also reviewed relevant
codes and standards, and interviewed builders, contractors,
materials suppliers, manufacturers, and code officials.
Members of the author's investigative
team examined stucco walls with infrared cameras (top left) and
camera probes (top right). To measure water leakage, they
applied hydrostatic head tests (bottom left) as well as simple
water sprays and simulated wind-driven rain (bottom
right).
In this article, I will explain what we learned. Anyone who
wants to keep rain out of a building might benefit from the
lessons of Florida's wet walls. After all, whether you build in
Florida or somewhere else, water is water, wind is wind, and
the laws of physics are the same.
Why Stucco Leaks
We were asked to focus on stucco-clad homes. Actually, there
are two kinds of stucco used in central Florida: traditional
"hard coat" or "three-coat" stucco, and the modern
"cementitious decorative finishes," popularly called "thin-coat
stucco." Both types of cladding let water into homes during the
storms.
Our testing of Florida homes confirmed what we already knew
about stucco: It always cracks, and the cracks always leak. In
homes we tested, stucco that was cracked leaked at the cracks;
and where the stucco was not cracked, it did not leak (Figure
2). But there's a little more to the story than that.
Figure 2.Using new garage block walls as test
structures, the investigators compared the leak performance of
bare masonry-block walls with that of various stucco claddings,
with and without cracks. A water spray on a bare block wall
(top left) lead to a characteristic leak pattern at mortar
joints (top right). Water sprays on unpainted stucco (middle)
did not cause leaks if the stucco was not cracked. However,
when typical small stucco cracks (bottom left) received the
water spray, water intrusion occurred at mortar joints and at
the wall base (bottom right).
Traditional stucco and thin-coat stucco aren't fundamentally
different. Both are surface treatments applied to a substrate,
and they behave in a generally similar fashion. Most important,
neither can be considered waterproof or leakproof. On the
contrary, when you use either, you can be sure it'll leak. But
with both decorative thin stucco and traditional three-coat
stucco, there are ways to decrease the frequency of
cracking.
Traditional stucco. This
centuries-old coating is supposed to go on in three coats. The
first is the scratch coat. It's applied about 3/8 to 1/2 inch
thick and allowed to cure. Because it's cement, it shrinks as
it cures, and as it shrinks, it cracks. Then, two or three
weeks later, when it is done shrinking, you go back and apply
the brown coat, which serves to fill in the shrinkage cracks in
the scratch coat. After that cures, you go back yet again and
apply the finish coat (the color coat), and you're done.
With each coat you apply, you change the mix of cement, lime,
sand, and water slightly, so that each coat is a little weaker,
more permeable, and more flexible than the one it covers. Thus
the softer, outer coats have relatively more lime and sand
— and less cement — than the hard inner coat.
But modern-day stucco applicators, in Florida as well as in
other places, typically don't wait several weeks for the first
coat to cure; they go back and apply the second coat the same
day. That means, of course, that both coats shrink and crack at
once — one reason the stucco in Florida leaked as much as
it did.
Thin-coat stucco is applied in just one coat, so it's going to
crack no matter what. However, with both thin-coat stucco and
two- and three-coat applications that are not given time to
cure between coats, it's possible to reduce the amount of
cracking by using fiber mesh in the mix, and by adding polymers
to make the coats more flexible.
So why not change codes to require either a mandatory curing
period between coats or the use of additives in the mix? That
wouldn't really be a practical solution. Neither technique will
prevent shrinkage cracks altogether. Nothing will. More to the
point, there's another cause of cracking that we also can't
prevent: settlement (Figure 3). Virtually all buildings move
and shift enough in the first few years after construction to
cause some cracking of the stucco — and no stucco,
whether traditional or polymer-modified, is immune to
that.
Figure 3.Houses shift after construction as
supporting soils consolidate and materials change size with
changing temperature and moisture content. This movement of
substrates, though typical and expected, inevitably brings
about some cracking in brittle surfaces like stucco, creating
the need for ongoing maintenance and repair in the early years
of a building's service life.
What, then, do we do? The answer is that you have to assume
there will be cracks and that water will be able to get through
them. Accordingly, you have to design wall systems that
tolerate those leaks, and accept that some maintenance and
crack repair by the occupants will be necessary over the years
after the home is finished and occupied.
Two Kinds of Walls
The picture in Florida is complicated by the fact that
builders there typically use two types of exterior walls on the
same house. It's common to lay a concrete-block wall for the
first story and then stick-frame second-story walls and gable
ends; stucco is applied to both stories. Both types of walls
leaked in the Florida storms, for somewhat different
reasons.
Building paper and
housewrap. Upper-story stick-frame walls, in principle,
should function as "drained assemblies." The stucco is applied
over a "weather-resistive barrier" (you can use housewrap,
asphalt felt, or Grade D asphalt-saturated kraft paper). Any
water that penetrates to the weather-resistive barrier is
supposed to drain down it until encountering a flashing that
directs the moisture out to the exterior.
One reason Florida walls leaked was that the housewraps or
papers installed beneath the stucco did not function
effectively as a drainage plane (Figure 4). Stucco tends to
bond to housewrap and building paper, eliminating the air space
in which water is supposed to drain. Also, the housewrap or
building paper itself loses water repellency when stucco
adheres to it, or when it comes in contact with surfactants
(soaplike chemicals that reduce the surface tension of water).
In Florida, water that reached the housewrap or building-paper
layer in the walls often bled through into the frame
assemblies.
Figure 4.
Upper-story walls in central Florida are
typically stick-framed, while lower-story walls are laid up
with concrete block (top left). Both wall types leaked, but for
different reasons. Designed as drained assemblies, frame walls
were handicapped by the bonding of building paper or housewrap
to the stucco coatings, which prevented free drainage (top
right). Forced into contact with trapped water, most housewraps
allow some water penetration, as shown in table-top testing at
the author's shop: Water dripped onto a horizontal housewrap
surface (middle left) soaked into the absorbent test material
underneath (middle right). In the field, saturated stucco
coatings over imperfectly performing housewrap allowed water
into sheathing and stud bays (bottom).
Reverse flashing. However, even if the housewrap or
building paper had worked as intended, there still would have
been problems caused by incorrect flashing. At the base of the
frame walls, where the upper-story cladding meets the
lower-story cladding, builders typically install a metal
expansion-joint component over the building paper and run the
building paper down into the top edge of the lower-story stucco
coat (Figure 5). This detail allows water running down the
upper-story drainage plane to flow into the lower-story mass
wall, rather than move to the exterior. Builders can't be
blamed for using this detail: The method is required by the
code, as interpreted by local officials.
Figure 5.The joint detail typically required in
Florida between upper-wall and lower-wall stucco sections (top)
does not manage water well. When the control-joint accessory is
installed over the top of a continuous sheet of building paper
or housewrap (bottom left), water is not kicked to the exterior
but is allowed to pass behind the joint into the wall below
(bottom right).
Lower-story mass walls. Masonry-block walls with stucco
cladding aren't intended to function as drained assemblies.
They are "mass assemblies." Water that penetrates the stucco
through cracks is supposed to be absorbed by the masonry mass,
which it doesn't damage, and then dry slowly to both the
exterior and the interior during periods of dry weather (Figure
6). Central Florida's masonry walls, for the most part, were
able to manage moderate amounts of rain but were simply
overwhelmed by the huge water onslaught from three consecutive
hurricanes.
Figure 6.Masonry walls are intended to absorb and
store minor amounts of penetrating water, and then allow the
moisture to escape later during dry periods. But when their
storage capacity is exceeded by continuing water intrusion,
they can let water enter the home at the wall base or bleed
through onto interior finishes.
Rather than suggest a modification of the stucco materials or
installations, I've suggested a few small design changes that
would enhance the ability of these systems to absorb and
dissipate water without allowing it to enter living space or
damage finishes. But even improved masonry mass walls shouldn't
be expected to handle rainwater that leaks in from windows,
service penetrations, or other holes in the wall assembly
— and it turns out that leaks at windows and other
openings were a major source of water intrusion during
Florida's storms.
Windows and Other
Penetrations
The industry standards and building-code rules for windows
don't require them to be leakproof when facing the kind of wind
and rain that central Florida saw in 2004. Windows installed in
Florida homes are rated for water holdout at 15 percent of the
design wind load, or no lower than 140 pascals of pressure
(approximately the pressure of a 35-mph wind). Clearly, these
limits were exceeded during August and September of 2004. In a
hurricane, the codes expect windows to stay in the wall, but
not necessarily to hold out all the rain.
