As a contractor
specializing in remediation and repairs, I've been
concentrating for years on fixing failed applications of EIFS
and traditional stucco. I've learned from experience that most
stucco failures result from improper flashing and drainage
details behind the stucco. Typically, houses that end up with
rotten sheathing and framing under the stucco don't have
properly installed building papers and flashings.
In recent years, I've been finding more and more cases of
leaking and rot behind another material that is very similar to
stucco: cementitious manufactured-stone veneer, or "cast
stone," as it is sometimes called. The problems we are finding
with cast stone are just like the problems we've seen with
incorrectly applied stucco. But the weather detailing flaws we
identify in artificial-stone jobs often cause even greater
problems than the errors made with stucco. With cast-stone
veneer, leaks and rot often show up sooner, progress more
quickly, and cause more severe damage inside the wall (see
Figure 1).
Figure 1.Where stucco (top photos) and cast stone
(bottom) have been installed on the same home, the author
frequently finds more severe moisture and rot damage under the
cast-stone portions of the exterior. One reason is that the
stucco terminates at the bottom with a weep screed, while the
cast stone sits in a bed of mortar and grout, directly on a
foundation ledge, with no weeps or flashings.
After investigating and repairing at least a hundred examples,
I've concluded that the problems with cast stone go back to a
misunderstanding of the material. Installers as well as
building inspectors have gotten used to thinking of cast stone
as a masonry material, and they expect walls to get the kind of
weather detailing behind the stone that is traditional with
brick: a single layer of paper, lapped a couple of inches at
the horizontal joints. But, unlike brick, cast stone is not
installed with an air space between the cladding and the framed
wall. Cast-stone veneers are cementitiously adhered to a
stuccolike base coat that is applied directly to the wall. Like
stucco, cast stone gets saturated with water in a rainstorm and
holds that water right up against the framed wall. The papers
and flashings under the veneer have to fend off that moisture
load without the benefit of any drainage or drying space. One
layer of paper isn't going to do the job — two layers,
as specified under stucco, are necessary.
Painstaking Details Required
If anything, cast stone should in fact be backed up by even
tougher details than stucco. That's because it has some
characteristics that may help create a more stressful moisture
load for walls during wet weather.
For one thing, manufactured stone is a cement-based product
that absorbs and holds water like stucco, but cast stone is
thicker than stucco and can thus store more moisture. Also,
most of the cast-stone brands now have "ledgestone" versions of
the product, which have a long, horizontal shape; the long,
flat, shelflike ledges are often sloped toward the framing when
installed, which provides a place for rain water to puddle up
and soak into the wall (Figure 2,).
Figure 2.
Long, flat "ledgestone" pieces like this
create many horizontal shelves where water can stand and soak
into grout joints.
The greater thickness of cast stone also complicates the task
of fabricating and installing practical flashing components.
The kickout or diverter flashing required where a roofline
butts into a wall is a good example. On job after job, my
company gets paid good money to go in after the fact, tear
cast-stone veneer off a wall, and retrofit a larger kickout
flashing to the wall because the original roofer's kickout
flashing was too small to push water out beyond the plane of
the cladding. If the diverter flashing is too small, it may as
well not be there: All the water flowing and blowing against
that spot will just get dumped into the wall system below
(Figure 3, next page).
Of course, all the other typical vulnerable spots in a stucco
application are just as problematic, if not more so, in a
cast-stone application. Window pan flashings, for instance, are
a good idea in a manufactured-stone job. However, we are more
likely to see a reverse-lap flashing error, with building paper
run to the window edge in such a way that the window flange
directs water beneath the paper instead of on top of it (Figure
3). And, as with stucco, brick, or any other cladding, a
cast-stone veneer should be equipped with weeps of some kind at
any bottom termination, whether at the foundation sill or above
a window or abutting roof. Otherwise, water will pool longest
at the lowest points, and those areas may stay continuously
wet.
Figure 3.Undersized or omitted diverter —
or kickout — flashings allow water to flow beneath the
cast-stone facade (top). Window flanges that lap under instead
of over building paper can bring rain water into direct contact
with the sheathing (bottom).
We also see problems when cast stone is paired with another
material on the same wall. It's very common, for instance, for
a single house to have stucco or EIFS as well as cast stone; if
the joint where the two meet is detailed wrong, water can get
to the wood-framed wall and cause trouble.
Investigating Problems
When my company is called to look at a building, the owners or
the builder often have no conception of the severity of the
problem they may be facing. Poly vapor barriers under the
home's drywall often conceal wall framing that is sopping wet;
on the exterior, the cementitious stone or stucco does not
decay, so it never betrays the secret underneath. Homeowners
may complain of just a few small leaks, or be worried about a
moldy smell.
From experience, we know where trouble is likely to be found,
and how bad it can be. By spraying a wall with water while we
create negative pressure inside the house, we can find out how
water is getting in, and by removing a few small sections of
the cladding, we can get an idea of the extent of the resultant
damage.
Repairing the Failures
On many occasions, our company has found a shocking amount of
water damage and rot under the cast-stone cladding of homes
less than two years old, or in some cases less than one year
old. The amount of water that can be taken in and held by
cultured stone is significant — enough to support
robust growth of wood-destroying funguses. If rot organisms
have water and they have wood, they will thrive until the wood
is gone. Often, what we find under cast stone looks more like
the ashes of a fire than like lumber (see "Under a Fine
Surface, a Disturbing Discovery," page 4).
If it's caught soon enough, the damage can be repaired. But
this is far more costly than doing the job right the first
time. Although I make my living from this kind of work, I wish
that every builder and contractor who installs this material,
as well as the building officials who inspect the jobs, could
see some of the failures I have seen and learn how to avoid
them. Too often, I've seen problems like these ruin a family's
finances when they lead to the uninsured loss of much of a
home's value.
Details That Work
Code provisions for cast stone can be confusing and murky. The
product isn't mentioned in the body of the building code, and
the evaluation reports and manufacturer instructions required
for code acceptance can be contradictory or incomplete. But the
basic methods required to succeed with the material are not
that complicated. In essence, cast stone has to be treated as
if it were stucco.
Before you apply lath to the wall, you need to be sure you
have a weather-resistant paper barrier on that wall —
and it needs to include two layers of paper, not just one.
Wherever there are penetrations, or intersections between
assemblies such as walls and roofs, or joints between cast
stone and other materials like brick or stucco, there must be
properly lapped flashings that keep kicking water away from the
building. And at the bottom of the wall, there has to be a way
for water to drain out. If all those precautions are observed,
there is no reason cast stone should cause moisture
problems.
When you're choosing your building paper, be careful. Type D
paper gets a "minute rating," based on the time the paper can
be placed in direct contact with water before it soaks through.
You can get 15-minute, 30-minute, or 60-minute rated paper, and
the more severe the climate, the higher the rating you should
choose. In dry and mild parts of Southern California or
Arizona, for instance, two layers of 15-minute paper ought to
be fine. In the valley-floor areas near Salt Lake City, we use
two layers of 30-minute paper. But if we work up near the ski
areas, where there is lots of wind and rain, we use 60-minute
paper. Sixty-minute paper is very rugged stuff — it is
more than twice as thick as 30-minute paper. In Houston, we use
either 60-minute paper or sometimes a layer or two of asphalt
felt paper applied over the top of a housewrap such as
Tyvek.
But no paper is intended to be absolutely waterproof for an
indefinite period. That's why the flashings and weeps are so
important. If you don't have them, water can pool at low points
and stand against the wall for hours, days, or weeks. And if
that happens, no paper, be it housewrap, asphalt felt, or Type
D kraft, is going to save your wall from rot. So if you're
applying cast stone, be smart: Use the papers, install the
flashings, and provide the weeps. It will cost a little more,
but it is a lot cheaper than hiring me and my crew to come back
and fix the wall when the studs are decaying underneath the
cast stone.
