Manufactured-Stone Nightmares - Continued
Under a Fine Surface, a Disturbing Discovery...
...and
a Costly Repair
The owners of this one-year-old custom
home . reported moldy smells behind the
drywall; a mushroom growing from the cast-stone veneer face was
the only visible sign of trouble on the exterior
. The gutter butting into the top of the wall
seemed a likely source of moisture, while the bottom of the
wall provided no way for moisture to escape
Opening the wall revealed severely rotted
OSB sheathing and damage to the framing. While the row of
soldier bricks at fascia height provided some protection
, the water coming off the roof saturated the
cast stone and soaked through the housewrap beneath, turning
the sheathing at the base of the wall to compost in less than
two years .To repair the damage, the author's crew
replaced the rotted wood members , but was
able to leave the original drywall in place because it had been
protected by the interior vapor barrier .
Parts of the band joist were left in place but soaked with a
copper-based wood preservative .
Destructive Investigation: Tracing a Leak to Its
Source
On this job, the original installer of
the cast-stone veneer wall had tried unsuccessfully to stop
leaks by spraying a clear sealer onto the stone and by removing
the lowest courses to apply a membrane flashing where the wall
meets the foundation. To assess the problem, the Ram Builders
team first seals large openings inside the home
and sets up a blower door
. With the blower door running to
depressurize the house, the crew turns on a water-spray
apparatus , thus simulating the effect of a
15-mph wind-driven rain. Within a short time, water finds its
way into the house .After verifying that the cladding leaks,
the team digs under the surface to find out why. Tearing off
small areas of EIFS on the upper wall reveals that there is no
building paper or window flashing installed where the EIFS meet
the cast stone , or between upper and lower
windows in the EIFS wall . Tearing off cast
stone near a window , the team learns that
water has wet the OSB sheathing. The author measures high
moisture content even at the bottom of the wall, where no
direct stream was applied . The retrofit
flashing repair has proven ineffective because flaws higher in
the wall dump water behind it.owns and operates Ram Builders, based in
Lindon, Utah, which specializes in remediation and repair work
in Utah, Texas, Colorado, and California.
