- Q.I’ve heard that if
you use 5 1/2-inch-thick fiberglass batts in a 2x4
wall, the insulation will have a higher R-value than
standard 3 1/2-inch batts provide. But some people say
that compressing fiberglass batts lowers the R-value.
What’s the story?
A.Bruce Harley, an energy
efficiency expert at Conservation Services Group,
responds: Both statements are correct. When
you compress fiberglass insulation, you increase
its R-value per inch, up to a point. However, when
you compress a batt of a particular thickness, the
total R-value does decrease. For example, standard
low-density batts, at their nominal rated thickness
— R-11 at 3 1/2 inches, or R-19 at 6
inches — have an R-value of about 3.1 per
inch. If you compress a 6-inch R-19 batt into a 3
1/2-inch cavity, you get about R-14, or 4.0 per
inch. This is a much higher R-value per inch, but
the total value of R-14 is still substantially less
than the R-19 you started with. Even in a 5
1/2-inch wall, the R-19 (which is rated at 6 inches
of thickness) gives you only R-18.
For the best performance, any batt should be
installed carefully, to fill the entire space
without compressing around wires, pipes, bridging,
or other obstructions. For those seeking higher
R-values per inch than standard fiberglass batts,
one alternative to compressing large batts into
small cavities is to use so-called high-density
batts (R-13 or R-15 at 3 1/2 inches, or R-21 at 5
1/2 inches). Although they cost more than standard
batts, they are stiffer, easier to fluff up, and
easier to cut around obstructions in wall framing.
These factors result in a bigger benefit in
real-world performance than the factory ratings
indicate.
