A.Joe Lstiburek
responds: Wood siding, including cedar siding, should be
installed over an air space, regardless of the type of
sheathing used. With foam sheathing, an air space is essential,
both to reduce the siding’s water uptake and to provide a
receptor space for the moisture in the siding. If the cedar
siding is installed directly on foil-faced foam sheathing, it
will be prone to cupping, splitting, and premature paint
peeling.
Since sidings are not watertight, no matter what we do,
moisture will get into any wood siding. Rain water penetrates
the siding at joints, nail holes, penetrations, and overlaps,
and runs down the back surface of the siding. Additionally,
capillary action can pull water upward at siding overlaps.
When the sun beats down on wet siding, it drives the
moisture inward. If the sheathing is plywood or boards, the
moisture is redistributed into the sheathing, relieving the
moisture stress on wood siding that happens when the front is
really dry and the back is really wet. This redistribution of
the moisture can’t happen with wood sidings over foam
sheathing, so we need an air space. Even a shallow air space
— 1/4 to 3/8 inch — will do. To provide an air
space, most installers find it easiest to install the siding on
vertical battens.
Housewrap or asphalt felt is useful to control rainwater
that penetrates the siding. In locations with high exposure to
wind-driven rain, it may be necessary to install tar paper or
housewrap behind foam sheathing to help control any rainwater
To sum up, If you want to install tar paper or a housewrap
with foam sheathing, install it under the foam sheathing
— but keep the air space between the siding and foam.
Joe Lstiburek is an engineer and principal with Building Science Corp. in Westford,
Mass.
