A.Wood siding can be
nailed directly over plywood sheathing without a
house wrap, rosin paper, or building felt, but I
would not recommend it.
Primarily, an exterior air barrier, whether it
is a plastic housewrap, rosin paper, or asphalt
impregnated felt, prevents air infiltration through
cracks in the building shell that aren’t
usually sealed, such as the joints between the
plate and the subfloor, around the band joist, and
between the sheathing. If all the joints in the
sheathing are taped, or if every joint in the
sheathing is over a stud or plate and the sheathing
extends past the mud sill (not just to the bottom
of the wall plate), you don’t need an
extra air barrier. In these cases, the sheathing is
the air barrier. But these conditions seldom
occur.
Secondly, an air barrier provides some
protection for the sheathing from water which may
be driven through the laps in the clapboards by the
wind or capillary action.
Finally, both rosin paper and building felt will
absorb and safely release small amounts of moisture
that move through the siding because of the daily
heating and cooling cycle. Without an absorptive
layer, this moisture can condense on the backside
of the siding, and might cause the siding boards to
cup and the paint to peel. Since plywood is
somewhat absorbent, the temporary moisture storage
provided by building paper is usually not
necessary, but is desirable when siding over
impervious materials such as foil-faced foam.
Plastic housewrap is not absorptive, but since
it is moisture permeable, water vapor can diffuse
through it, where it can be absorbed into the face
of the plywood.
Asphalt-impregnated felt isn’t an
especially good vapor barrier, so you
don’t have to worry much about a cold-side
vapor barrier. The glue line in the plywood is a
much better vapor retarder, so if there is a danger
of a cold-side vapor retarder, it is the plywood,
not the paper or felt, that is the problem.
