- Q.I'm removing the wood
siding from a '70s colonial, down to the sheathing, and
plan to put up vinyl siding. I'm thinking of covering
the exterior with foil-faced foam for extra insulation
but am concerned about trapping moisture in the walls.
The house is located in New England. Should I use the
foam, or should I just use housewrap below the
vinyl?
A.Contributing editor Paul
Fisette responds: Although the energy crisis
hit during the '70s, most homes built during that
decade were still under-insulated, so it's a good
idea to upgrade. Adding an exterior layer of
insulation to the walls is easy to do while you're
residing. It creates a continuous layer of
protection that mutes through-conduction of the
framing members. The installation of a "winter
coat" also keeps walls warmer, reducing the
likelihood that condensation will form within the
wall cavities. In your climate, it's best to select
insulating sheathing that is somewhat permeable to
vapor. Northern building codes require the
installation of interior vapor barriers. Installing
an impermeable barrier on the exterior of the wall
can trap moisture that reaches wall cavities,
creating conditions that are ripe for mold, mildew,
and rot. So it's best to avoid the use of
foil-faced foam panels in cold climates. Using
unfaced polystyrene or other semipermeable foams is
a reasonable choice in your cold location. Dow
Sturdy-R is urethane foam board with a perm rating
of 3 and an R rating of 5 per inch, a good
choice.
