Rigid Foam
Update
Over the past two decades,
the use of rigid foam
insulation in residential
construction has grown enormously.
From below-grade foundation
insulation to structural
insulated panel systems, from
vinyl siding backers to cathedral
ceiling insulation, rigid foam has
proved to be an effective means of
reducing air infiltration, adding Rvalue,
and eliminating conductive
heat loss, particularly where conditions
limit the allowable thickness
of the insulation.
Although several foam recipes
have come and gone, three main
types of rigid foam boards are still
readily available today: expanded
and extruded polystyrene, and
polyisocyanurate (see Figure 1,
next page).
Expanded polystyrene (EPS),
commonly referred to as "beadboard,"
is a closed-cell foam made
of dense polystyrene crystals that
are steam-expanded to 40 times
their original volume. Although the resulting beads
