I've built homes and furniture in northwestern Vermont for 25
years, but for the past 10 years, my design-build firm has
focused on the highly competitive new-home market. Most of my
homes are in the "move-up" category in desirable neighborhoods.
Buyers in that market segment expect some interesting
architectural details and a premium trim package. It could be
my formal education in accounting, or it could be old-fashioned
Yankee ingenuity (or frugality), but I've always prided myself
on good-looking trim details that don't cost a fortune. Those
details make my homes distinctive and get people in the door,
but it's their impact on the bottom line that's made my
business successful.
One of my favorite ways to give my customers something out of
the ordinary while saving money is to use MDF trim instead of
solid wood. Besides standard trim details like baseboard,
casing, and crown, I use it for custom details like wainscot
and built-ins. With MDF trim costing less than half of what a
similar wood product costs, I can create an attractive high-end
look without pushing the selling price into the
stratosphere.
I think that cost-effective finish work today is really about
knowing how and where to integrate new or nontraditional
materials. There was a time when I used only natural wood for
all my casings and finish trims. Now I actually choose MDF over
wood because it's better for painted trim — with the
money I save, I splurge on hardwoods for areas that call for a
strong first impression (see Figure 1).
Figure
1.Using MDF for most of
the trim leaves room in the author's budget to use
attractive figured hardwoods in high-visibility areas
like sills, window seats, and other
built-ins. |
What's Available?
I try to stick with stock profiles because the factory-applied
primer makes finishing easier, although I sometimes use custom
wainscoting. Some MDF profiles are new designs, but many are
based on traditional wood profiles. One of my favorites is
Windsor 3 1/2-inch casing. This versatile trim can be used for
window and door casings, chair rail, or top-rail on
wainscoting, or even as a frame for bathroom mirrors. It
creates a custom effect with minimal work. Because this trim is
so versatile, I never throw anything away — I'm always
finding new uses for even the smallest pieces (Figure 2).
| | Figure
2.Windsor casing made
from MDF costs about half what the same profile costs
in wood. But because it's more dimensionally stable
than wood, MDF miters don't open with seasonal moisture
changes. The author uses a fast-setting adhesive to
guarantee tight joints. |
Working With MDF
MDF is made from super-compressed paper and glue, so it
doesn't have any discernible grain. That's both the most
notable benefit and the greatest difficulty in working with it.
On the plus side, it can be cut, machined, and filled easily;
on the minus side, the lack of grain makes thin sections prone
to breakage. As a result, we miter rather than cope inside
corners. Another key to successfully working with MDF is using
sharp tools — especially sharp saw blades. We use
high-quality, 80-tooth blades and sharpen them regularly.
We also glue miters and returns, using MDF 2400 Adhesive from
Koetter Woodworking (Borden, Ind.; 812/923-8875,
www.koetterwoodworking.com). This two-part
adhesive sets fast, so it's critical to check the fit first. A
small bead of adhesive is applied to one side of the joint, and
the other side is sprayed with activator. Once the two pieces
touch, there's only about five seconds before the bond is
set.
Another helpful tip is to use 18-gauge brads instead of
15-gauge finish nails. We've found that the smaller wire
reduces "mushrooming" or "puckers" around the nail hole and
makes finishing easier. Initially, I had concerns about the
smaller nail having enough strength, but we haven't had any
problems.
Besides costing less than wood, one of MDF's greatest
attributes is its dimensional stability. Seasonal changes in
temperature and humidity won't cause swelling, splitting, or
opening of joints. That makes it the perfect wainscot material
(Figure 3).
| Figure
3.Using MDF wainscoting
in a variety of heights comple-ments standard stool and
head casing heights, creating a much livelier interior.
The author installs the wainscot with construction
adhesive and a few 18-gauge brads to hold it in
position while the glue sets — making for fewer
nail holes to fill. Windsor casing, rabbeted on the
bottom, makes a good cap (bottom right). |
Finishing
When it comes to paint, the primed finish of MDF is obviously
easier to cover than bare wood. I use MDF trim with a smooth,
baked-on finish, which saves time in sanding and can eliminate
a second coat of finish paint. We fill nail holes and
imperfections with Dap 222 filler and caulk gaps with a
high-quality latex caulk. Once the MDF trim is painted and
finished, the final touch is to urethane the bird's-eye or
curly maple stools and caps.
I have finally come to the conclusion that not only can MDF be
used in place of wood, it delivers a better result when painted
trim is desired. I attribute a lot of our success using MDF to
our finish carpenters, Lucien and Larry Poitras and Steve
Tucker. Those guys put together the custom details that create
our unique look and style.
Bill Poseyis the owner of W.E. Posey Design/Build
in Shelburne, Vt.
