As a tile contractor and consultant, I’ve had plenty
of opportunity to observe failed tile installations. But
I’m also aware of tile work that is centuries old and
still looks fresh and new. Why? Maybe because most of the
ancient tile work was done for pharaohs and kings, and the
penalty for less than perfect craftsmanship was death. About
the worst that can happen today is to have an installation
red-flagged by the inspector.
Most of the installation failures I’ve seen have
resulted from a failure to follow directions. Whether the
directions are in the form of specifications, industry
recommendations, or the printed instructions on a container,
failure to heed the advice will almost guarantee problems. Most
contractors don’t intentionally ignore instructions, but
they often fail to make themselves aware of the recommended
methods. What follows are the instructions and recommendations
most often ignored by tilesetters, and the problems that
result.
Allowing for Movement
Probably 90% of the tile installation problems I’ve
encountered are a result of the tilesetter failing to allow for
substrate movement. Typical problem spots are vertical wall
planes that intersect with horizontal surfaces, concrete
substrates with control joints or random cracks, and the
junctures of dissimilar materials. In these situations, a
"movement joint" (my term for a broad class of expansion or
control joints) should be used.
Inside corners should be left free of grout, then caulked
after the grout has cured. Use a high-quality silicone caulk,
and install a foam backer rod in the open joint before
caulking. It’s also important that all "hard" material be
cleaned out of an open joint before caulking. Small bits of
hardened adhesive or grout can apply point pressures to
adjacent wall surfaces, causing cracks as the substrate
expands.
When installing tile over a concrete slab, creating movement
joints can be a little trickier. One approach is to position an
open tile joint directly above any slab joints, install backer
rod, and caulk. The trouble with this approach is that the
location of this open joint may disrupt a patterned tile
layout, or you may be forced to follow a slab joint that is
crooked or out of square.
A more adaptable approach is to use a crack isolation
membrane like the one manufactured by the Noble Company (614
Monroe St., Grand Haven, MI 49417-0350; 800/878-5788). Although
its use will not completely eliminate cracks, the 1/32-inch
membrane material isolates the tile from the substrate movement
and allows tile movement joints to be located near the slab
joint instead of directly over it. The width of the membrane
should be three times the tile size, and it should be bonded to
the slab using either Noble’s proprietary latex-based
adhesive or an acrylic or polymeric modified thinset mortar
(see Figure 1).
| Figure
1. A tilesetter uses a floor roller to adhere a
crack isolation membrane over a slab control joint. The
membrane should be three times the width of the
tile. |
After the membrane is installed, the tile is bedded in
thinset adhesive and two movement joints are located on either
side of the slab joint (Figure 2).
Installing Isolation
Membrane
Figure
2. Install an isolation membrane over slab cracks and
control joints (top) and at the juncture of dissimilar
materials (second). Use a movement joint on each side of the
crack. In the case of diagonal tiles (third), use a zigzag
movement joint. For random cracks (bottom), movement joints
should be located on both sides, following the direction of the
crack.
When the slab joint is covered by angled pattern tile, the
movement joint is zig-zagged over the slab joint.
This isolation membrane is also ideal for bridging random
slab cracks (a difficult item to work into a tile pattern) and
joints created when two dissimilar substrates meet. The same
ratio of membrane width to tile size applies, and movement
joints must be located on either side of the random slab
crack.
Unless you’re using a white grout, you may have
difficulty finding an off-the-shelf caulk for the movement
joint that matches the grout color. Color Caulk (723 W. Mill
St., San Bernardino, CA 92410; 909/888-6225) carries an
inventory of colored and sanded caulks that will match just
about any manufactured grout on the market.
