Substrate Deflection
Most contractors understand that a bouncy floor will result
in cracked tile. The allowable deflection (or "sag") for a tile
floor system is generally limited to L/360. What many
contractors fail to understand is that the L/360 tolerance also
applies to the floor areas located between individual
joists. Before you start looking for tables that list the
deflection of plywood substrates, it would pay to review the
Handbook for Ceramic Tile Installation (Tile Council of
America, P.O. Box 1787, Clemson, SC 29633; 864/646-8453).
According to the Handbook, there is no approved method
for installing tiles over joists spaced more than 16 inches
on-center. The prudent approach when dealing with wider joist
spacing is to install additional joists between the existing
ones.
If you install tile on floor systems with joist spacing that
exceeds 16 inches on-center, be prepared to shoulder the
liability, or get assurance from all involved manufacturers
that the system you intend to use will perform adequately (see
"Durable Substrates for Thinset Tile," 8/96).
Getting Adhesives to Stick
Whether you’re using an organic mastic adhesive or a
Portland-cement-based thinset adhesive, there is an important
sentence found in the instructions that most builders ignore.
It usually reads something like this: "The approved substrate
should be free from dust, dirt, oil, and grease." Bedding tile
in a dirty substrate will result in a weakened bond (and in
extreme cases, a nonexistent bond), and it sets the
stage for cracking when the inadequate bond fails to hold the
tiles in place.
Before you reach for the adhesive, all floors should be
scraped and thoroughly vacuumed, using a heavy-duty shop vac.
Concrete floors should be wet mopped (Figure 3), and plywood
substrates damp mopped, changing the mop water as it gets
dirty.
| Figure
3. Dirty substrates create poor bonding
conditions. Concrete substrates should be wet mopped
and plywood substrates damp mopped, with the mop water
changed regularly. |
If you fail to change the mop water, you’ll be
creating a homogeneous bond-breaking layer that contributes to,
rather then prevents, bonding problems. I’ve had to mop
floors as many as four times before the water came up
clean.
In most cases, these intense cleaning chores can be avoided
by placing a protective covering over the substrate as soon as
possible. For a few days’ protection, red rosin paper may
be all that’s needed. When long-term protection is
needed, I often put down a layer of polyethylene, followed by
rosin paper topped with protective tarps.
The Advantage of Additives
Many tilesetters argue that there is no need to add an acrylic
latex additive to thinset mortar. Some parts of their argument
may have merit, but the overriding reason to use an additive is
that it eliminates the need for damp curing (a seven-day affair
involving wet tarps and repeated trips to the job site). Some
brands of thinset mortar have the acrylic latex additive mixed
in at the factory (all you do is add water). If you’re
using a brand of thinset mortar that is not latex modified,
you’ll need to substitute a liquid latex additive for a
portion of the mixing water.
Mixing thinset mortar is another area where contractors
often stumble. A new batch of thinset should never be mixed in
with a previous mix, and mixing buckets should be emptied and
sponged out between mixes. This prevents remnants of a previous
mix from "heating up" the fresher batch, causing an accelerated
setting time that weakens the bond.
Match the Trowel to the
Tile
Notched trowels are used to spread tile adhesive, and while
there are no hard-and-fast rules when choosing notch
configurations, there are some guidelines. For standard wall
and floor tile up to 6 inches square, a 1/4x1/4-inch notch
configuration is recommended (Figure 4).
Figure
4. Notched trowels come in many configurations. Shown
here, from left, are a 1/4x1/4-inch notch, for tiles up to 6
inches square, a 1/4x3/8-inch notch, for tiles up to 12 inches
square, and a 3/4x9/16-inch U-notch, used for irregular
handmade tiles. | Figure
5. After applying the setting adhesive with the
straight edge and bottom of the trowel, the tilesetter
combs the setting bed with the trowel held at a
45-degree angle. |
One last note on trowel technique: Before laying down the
full setting bed, a thin layer of adhesive should be worked
into the substrate using the straight edge of the trowel, with
ample pressure to work the adhesive into cracks and voids.
Grouting Tips
If you’ve ever wondered whether you should use a latex
additive when mixing grout, stop wondering: A latex additive
should always be used. Latex increases bonding strength and
water resistance, improves color retention, produces denser
grout joints, increases stain resistance, and eliminates the
need to damp cure. About the only downside to using a latex
additive is that when it’s used with an absorptive tile
(cement-bodied tile, for example), the additive makes it more
difficult to clean the residual grout haze. You may need to
apply a grout-release product to prevent the grout from getting
a "bite" on the surface of the tile.
Always follow the recommended powder-to-liquid ratios when
mixing grout. The latex additives create a mix that is much
more sensitive to variations in water content, and tilesetters
must be careful when adjusting the "feel" of the mix. Too much
liquid results in a weak grout that is more porous when it
dries, while a mix that is too dry will have trouble bonding to
the sides of the tile and may not cure properly, resulting in
powdery joints.
Grout containers carry instructions recommending that
freshly mixed grout be allowed to "slake" for 10 to 15 minutes
before remixing and applying. Slaking provides time for the
powdered portion of the mix to absorb and react with the newly
introduced liquid. Impatient tilesetters who bypass this step
will be working with inconsistent grout, and face the prospect
of explaining to a customer why spot defects have occurred in
the grout joints.
Colored grouts raise the level of difficulty by introducing
a color consistency issue. Maintaining the same color
throughout numerous mixes can be challenging. The first line of
defense against mismatched batches is to empty all the bags of
powdered mix into a common container and thoroughly mix them
together while dry. This will defuse any color variations on
the manufacturer’s side. The next step is to carefully
measure out the liquid-to-powder ratio and scrupulously follow
the same measuring method every time a batch is mixed.
Finally, make sure that all the peripheral conditions are
the same for each mix. If mixing by hand, count the number of
strokes. If you’re using a paddle mixer attached to a
drill, note the run time of the drill. If the first mix is
slaked in the shade, make sure all remaining mixes are slaked
under the same conditions. Spread the same amount of grout over
the tile each time and be careful not to let any errant water
drip on the grout joints (as from a wet sponge, for example.
The edge of the rubber grout trowel should be used to remove
excess grout, not a wet sponge.) The color consistency may look
fine as you’re working, but water-induced color
variations can show up a week or more later.
Premature Traffic
No matter how careful you are with a tile installation,
premature traffic can instantly create problems, often causing
the grout to crack and come loose. Many mortar manufacturers
offer an accelerated setting system that will match a required
"in use" deadline. Generally, the quicker you need to get on
the floor, the more expensive the setting material. Before
making any promises to your customer, check with your supplier
to be certain the product will perform to your customer’s
expectations.
Remember, the penalty for inferior tile work may no longer
be death, but it can kill your reputation.
