A.Michael Byrne,
director of the Ceramic Tile Education Foundation,
responds: The problem with discolored grout in
kitchens is all too common, but it doesn’t
have to be that way. There are three main issues:
Choosing the right grout and grout color,
installing it correctly, and sealing it with the
right product. Tile choice can also make a
difference.
Before choosing a grout color, you need to know
how heavily the kitchen will be used. In a kitchen
that sees only light cooking and cleanup, you
should be able to use any color. Use pink if it
makes the client happy. But if a lot of cooking is
going to go on, you should probably choose a grout
the color of dirty dishwater — gray
— because that’s the color the
grout will want to turn. If you put a white grout
in that kitchen (the worst choice), you’re
essentially making the homeowner a slave to keep it
clean. Black and other very dark colors are also
bad because they show up light stains and deposits.
Steer your client toward cement gray. The most
durable grout is an epoxy, which is available in
gray. But if your client just has to have that dark
green grout she’s seen in a
friend’s kitchen, use a latex grout
— you’ll have a better color
choice.
Next, you have to apply the grout properly. Make
sure you mix it according to instructions, and make
sure to use a grout trowel so the material is
forced into and completely fills the joint. A step
that is usually neglected is striking the joint.
Most installers use only a sponge for grouting,
which has the effect of removing the fine Portland
cement and sand filler and exposing the sharp edges
of the silica aggregate — leaving a very
rough and abrasive grout surface. Imagine dropping
a peanut butter sandwich on a piece of sandpaper
and trying to clean it — this is what the
homeowner will be faced with in trying to clean
that grout surface. Striking the joint, with a tool
like a brick mason uses, compacts and smooths the
grout, making for a much smoother, less absorbent,
and easier-to-clean grout line.
If you don’t install the grout
properly, sealing is a useless exercise. But
assuming you’ve tooled the grout
correctly, now apply an impregnating sealer. A good
choice is 511 Porous Plus (Miracle Sealants,
800/350-1901). This is a solvent-based sealer used
on stone buildings to make it easy to clean off
graffiti. It requires 72 hours of curing, but once
cured, it’s food-safe. Two other good
choices would be Sealer’s Choice 15 or
Grout Sealer from AquaMix (800/366-6877). Grout
Sealer is an acrylic product that leaves a smooth,
easy-to-clean surface; Sealer’s Choice is
a commercial-duty product with a 15-year service
life. I would avoid using silicone sealers, which
are ineffective.
Sealers will have to be maintained, depending on
use. And tile needs to be cleaned for staining just
like any other surface — if you spill some
wine in a grout line, sponge it up.
Tile choice is not usually the
contractor’s decision, though if your
client wants a tile counter but is concerned about
grout staining, you might recommend using oversized
tiles on the counter to reduce the number of grout
lines.
