- Q.Whenever I need to replace
chimney counterflashings, I seal the top of the
flashing with Quickcrete, using a caulk gun. This
product is made for concrete repairs, and comes in a
tube. I know that some people will mix up a little
mortar for this job, and others use silicone or
urethane caulk. What is the best product to
use?
A.Roofer Tom
Brewer responds: Mixing up mortar is
time-consuming and messy. Since the mortar can
shrink as it cures, you don’t know how
watertight the joint will be. Products installed
with a caulk gun are much easier to install. When
replacing chimney flashings, I usually use a
polyurethane caulk. Silicone caulk and products
like Quickcrete also adhere well to old masonry.
Some people prefer products made for masonry,
because they have texture. Whether you choose a
product like Quickcrete or a caulk, using a caulk
gun allows you to get the product into the tight
spaces between the old masonry and new flashing,
providing a solid, watertight seal and a clean,
finished appearance.
