A.David Dobson, an architect and licensed
general and glazing contractor in San Diego, responds: On
most job sites (and even in the promotional material of many
manufacturers), I've found that applicators usually drag
caulked sealants when they apply them. But it's hard not to
pull the caulking gun too quickly and stretch the caulking
bead, which will prevent enough sealant from being applied to
the joint.
Applied too thinly, a caulked sealant can suffer from cohesive
failure, meaning it's not strong enough to maintain its bond.
Or, it can shear (split) along the length of the joint. This is
particularly a problem when a sealant is used to create a
"bridge" joint, where the gap between two materials is simply
painted over — rather than filled — with
sealant.
When using a simple caulk to fill a joint that isn't expected
to move or to repel moisture, joint failure is usually no more
than a cosmetic problem. But when high-performance polyurethane
and silicone sealants are used to form long-lasting welds
between dissimilar materials that are expected to be both
flexible and air- and watertight, a properly designed and
installed sealant joint is critical. That's why these sealants
should be applied by using the caulk gun to push — rather
than pull — the bead along the joint. This technique
helps work the air bubbles out of the sealant and pushes the
sealant into the joint instead of pulling it out.
Keep in mind, though, that caulked sealants applied too thickly
lose their elasticity. To picture this, take a rubber band and
stretch it, then double it up a few times and try stretching it
again. Like the rubber band, the thicker bead of sealant
becomes less flexible and loses its elongation
properties.
In general, the best joint size for most caulked sealants is
between 3/8 inch and 1/2 inch (always refer to the sealant
manufacturer's recommendations for joint designs).
Sealant joints should be designed to avoid three-sided
adhesion. A sealant that adheres to three sides of a joint will
tear along one of the sides when the two materials move
differentially. One common way to avoid three-sided adhesion is
to use a bond-breaking tape underneath the joint (see
illustration).
Another way is to install a closed-cell foam backer rod before
filling the joint with sealant. Available in different
diameters, backer rods are useful for controlling the depth of
the joint between thicker materials, and therefore the size of
the sealant bead.
