- Q.I have heard that silicon
caulk should not be used with cedar trim. Is this true?
If so, why?
A.Silicon caulk is not
the best choice to use with any wood trim. It works
best in sealing the joint between two pieces of
non-porous material, such as ceramic tile, metal,
or glass. The oil in cedar will reduce the adhesion
of silicon caulk, which should be applied to clean,
dry surfaces. An acrylic or urethane-based caulk
works best where one of the materials being sealed
is wood.
How the caulk is applied is even more critical
than the type of caulk used. The caulk should be
applied so it bonds to two faces across a gap. That
way, movement of the materials will place the bead
in tension or compression, rather than peel the
caulk away from one of the surfaces. A three-sided
fillet of caulk in a corner will almost always
fail.
