A.Contributing editor
Michael Byrne, an expert tile setter and consultant in Los
Olivos, Calif., responds: While breezeway enclosures are
good because they help shield walkways from precipitation and
temperature extremes, they can also trap moisture. A floor that
puddles is a nuisance and a safety hazard, and in the
environment of an enclosed breezeway, chronic excess moisture
can lead to mold and wood rot. So, depending on your
breezeway's design and exposure, you may have to slope the
walkway prior to tiling and provide a method of draining off
excess water. And even without the need for a slope, scuppers,
or a drain, retrofitting this installation for tiling will
still require a waterproofing/crack-isolation membrane applied
to the slab. Finally, if the crack in the concrete exceeds 1/8
inch wide or results in uneven concrete surfaces, the walkway
should not be tiled at all.
Flat or sloped, all exterior tiled walkways need a
waterproofing membrane. If sloped, the slope should allow the
walkway to self-drain. I prefer to float a crowned, bonded
latex mortar fill over a concrete slab, but many walkways are
finished with the tiles sloped to one side only. Drainage is
needed in either case; I recommend fitting the enclosing walls
with scuppers large enough to allow for the free flow of excess
water, leaves, and whatever else is going to be tracked
in.
The crack is a serious problem requiring careful membrane
detailing to limit tile damage and prevent water from getting
between the membrane and the setting bed, which could damage
the surrounding structure. Many isolation membranes aren't
suitable for exterior use. I use Noble Deck, a sheet membrane
made specifically for this purpose (The Noble Co.,
800/878-5788, www.noblecompany.com). I lap the membrane
about 4 inches up the wall and use the company's shower-pan dam
corners to detail the membrane around scuppers and openings (an
exterior floor membrane has much in common with a shower pan).
Regardless of the membrane system you install, make certain
that the perimeter joints are filled with an approved sealant
and not hard grout, which can damage the tiles and render the
membrane useless.
Porcelain tiles are highly resistant to moisture penetration,
but not all porcelain tiles work well in breezeways. Some have
a coarse surface finish that helps reduce slips and falls but
also makes the tiles ideal dirt magnets. Dirt lodged in the
surface pores can be very difficult to remove, so make sure
your tile dealer directs you to a tile made specifically for
use outdoors: It should be both freeze/
thaw stable and easy to maintain.
I also recommend using high-quality latex thinset mortars and
grouts that are approved for exterior use; follow manufacturer
instructions and wet/dry mixing ratios to the letter. For
spreading uniform layers of latex thinset mortar, a notched
trowel should be used to achieve the industry-standard 95
percent adhesive coverage. Any less and moisture is likely to
pool in the voids, expand when it freezes, and pop tiles off
the surface. To achieve 95 percent minimum coverage, the tile
industry recommends the use of a 1/4-by-1/2-by-1/4-inch U-notch
trowel for 12-inch tiles, but only on-site experimentation will
reveal the right trowel. It isn't the size of the trowel or the
notch profile that is important; it's the coverage.
When grouting, make sure that all the grout joints are
thoroughly packed. Water can easily fill voids in the grout,
and on freezing cause significant damage to the installation.
All membrane systems require that any joints abutting
restraining walls, plumbing, or other penetrations be filled
with a flexible sealant — not caulk — rated for
exterior use.
Vitreous or impervious tiles, latex thinsets and grouts, an
exterior waterproofing/crack-isolation membrane system, a
sloped setting bed when needed, and regular applications of a
penetrating sealer will get you a simple-to-maintain tile
walkway. Anything less and your customer isn't going to be
happy.
