I run a full-service home-improvement and remodeling company
that was founded by my dad in 1976. Today, we have two basic
divisions: one that handles kitchens, baths, additions, and
basement finishing; and another that does handyman services and
exterior work, including siding, roofing, and door and window
replacements. Last year, our company did around $4 million in
sales, and fully 30 percent of that was generated by what we
call AWAs, or additional work authorizations — otherwise
known as change orders.
Clearly, change orders are a vital piece of our business
model, and they don’t just happen by accident. We lay the
groundwork for changes by keeping clients happy and informed
throughout the job process. Dissatisfied customers, we know,
are unlikely to authorize additional work.
Building Trust
In years past, once we sold a job there’d be no visit or
contact with the clients until the start of work, which could
be as much as two months later. We learned the hard way all the
problems that can crop up during that lull. So now we maintain
near-obsessive communication with the clients, from the very
first sales call (when customer anxiety levels are typically
high) all the way to the end of the job.
We lay the groundwork for a trusting relationship at that
first meeting. The salesperson explains our operating plan
— standardized steps we follow strictly on every job
— so that the clients know from the beginning what to
expect and when to expect it.
Having an operating plan and sticking with it is critical to
our success. Whenever there’s a problem on a job, I
dissect the situation and identify what went wrong. Inevitably,
I discover that the trouble arose because we failed to follow
our operating plan to the letter.
Getting Acquainted
During most of the first visit, the salesperson focuses on
listening; the idea is to get acquainted with both the job and
the clients. Only after prequalifying and getting to know the
customers does the salesperson present our proposal, typically
during a second visit. The proposal outlines absolutely
everything that’s in the specification and —
equally important — everything that is not included. The
salesperson also informs the clients that we always conduct two
preconstruction meetings.
Double-check. The first of these two meetings is what
we call the “remeasure visit.” It’s conducted
by our production manager within a couple of days of the
proposal presentation. He walks the job with the clients,
remeasuring and reviewing the proposal line by line. This
provides an opportunity to detect errors or oversights and to
emphasize work that is not included. For example, the job may
involve installing new exterior siding and trim but not new
gutters. If the existing gutters are dingy-looking and will
detract from the new look, we have an obvious opening for an
AWA. Thus, we can often add to the scope of the original
proposal during the remeasure visit, based on the trust
we’ve already established through our careful attention
to detail.
Triple-check. The second preconstruction meeting
happens when, a few days before the start of work, the lead
carpenter and the salesperson walk the job with the clients.
Once again, they go over the proposal and review any special
needs previously discussed with the production manager, such as
where a dumpster must be located, where lumber drops should or
should not happen, and so on.
These two visits help bulletproof the job against
miscommunication or the forgetfulness that can creep in between
the time of sale and the start of work.
Preparing Clients for
Changes
It’s the salesperson’s job to thoroughly prepare
the customers for every aspect of the upcoming job. That
includes explaining the reality of AWAs and why they may occur.
Some change orders are generated by conditions that can be
anticipated but not predicted with any kind of certainty. For
instance, if the house is 50 years old and we’re going to
be opening walls, we know there’s a good chance
we’ll find wiring or plumbing that must be brought up to
code. Other hidden conditions are more of a surprise, such as
termite damage revealed under the sill during a door
replacement job. The salesperson points out the contract clause
that covers these types of contingencies.
Then there are AWAs for work not within the scope of the
original proposal. Most of the building stock we work on is 20
to 30 years old, so unless the clients have already replaced
every component of their house, there are innumerable
opportunities for adding work — a wood floor in need of
refinishing, walls that could use a fresh coat of paint, an
aluminum slider or windows that could be replaced. We come to
the clients’ home not only as installers but as
consultants with a home inspector’s eye for problems. The
house tells us what it needs, and we bring those needs to the
homeowners’ attention and offer solutions.
Educating customers this way isn’t just a sales gimmick.
As professionals, it’s our job to root out problem areas,
and we consider it negligent not to do so. Say we’re
hired to replace a patio slider, and the installer notices
decay in the decking while he’s setting up outside. If he
doesn’t call attention to this problem and an accident
occurs later on, the homeowners are sure to be upset that we
didn’t warn them.
After the clients signed the original proposal for this job
— which involved installing aluminum trim coil over
existing exterior trim at a cost of $18,850 — they
decided they also wanted the house’s siding and deck
stained. The new work is carefully detailed on this AWA
(additional work authorization) form; one-third of its $9,600
cost is due upon signing.
Accommodating Additional
Work
A construction schedule is a moving target. Generally we have
enough manpower available to cover contingencies. If bad
weather delays a job, the production manager immediately
informs pending projects of any schedule changes. We already
know the potential for change orders and preconfigure each
job’s time frame accordingly. If we know the job is going
to take four weeks, for instance, we assign it five weeks in
the proposal. This allows us to either complete the work
earlier than expected or to accommodate added work without
compromising our schedule. It’s also possible under these
circumstances that we can start the next job earlier than
proposed.
We do everything in specialty fashion, according to the type
of work performed. If, during a siding-replacement job, the
clients decide they also want the roof replaced, our roofing
crew performs that work. If the roofing crew is three weeks out
at that point, we schedule the new work three weeks out. What
matters most is not that we achieve an uninterrupted flow of
work, but that everything is done in a timely, professional
manner.
Reviewing the Job
At the conclusion of every job, we ask clients to complete a
customer satisfaction survey. Once a month, the entire company
gets together for a TQM (total quality management) meeting. We
review the survey results and analyze all of the prior
month’s projects. The installers consider the
salesperson’s performance and evaluate how well the job
was measured, estimated, and specified. For each job, we
discuss the issues that cropped up, how well the process
worked, and its final profitability. In this way, we’re
constantly tweaking our procedures, looking for any possible
improvements and the very best ways to implement them.
Staff Incentives
Although each and every employee is authorized to write an
AWA, 80 percent of our AWAs are generated by the production
manager. This is mostly because he constantly inspects and
reviews the job with the clients and is the person most
responsible for maintaining communication. The 9 percent sales
commission on every change order is shared equally between the
person who generated it and the initial salesperson on that
job. This motivates the salesperson to train the crew to spot
AWA opportunities and gives crew members yet another good
reason to care about their work.
Tom Capizzi Jr. runs Capizzi Home Improvement in Cotuit,
Mass.
