by Ted
Cushman
Using specially designed sets of removable aluminum forms,
crews for Security Building Group can form and pour houses on the
beach a story at a time, including the walls and floor
slab.
Tougher coastal building codes have led stick builders to beef up
structures using engineered lumber, structural wood panels,
enhanced fastening schedules, and heavy-duty hold-down and
connector hardware.
But there's a limit to what you can accomplish using wood. If you
want to resist the roughest stuff a hurricane can throw at you,
it's hard to beat reinforced concrete. Hurricane Katrina gave
dramatic proof of that: 350 feet inland from the shore in Pass
Christian, Miss., a partially completed concrete house on
poured-concrete piers, owned and built by structural engineer Scott
Sundberg, was the only building left standing after the storm surge
scoured the surrounding area clear of buildings (Figure 1).
FIGURE 1. This poured-concrete house in Pass
Christian, Miss., survived the storm surge of Hurricane Katrina
while all the other homes in the surrounding area, built of wood,
were swept away. The lesson has prompted some home buyers on the
Mississippi coast to opt for elevated concrete houses, despite the
higher cost of construction.
"That Sundberg house is a tribute to the strength of concrete
construction," says Dave Pfanmiller, who runs Security Building
Group (www.securitybuildinggroup.com), a Gulfport, Miss.,
custom-home-building company. And it's not the only example. "Up
and down the Mississippi coast, the only structures left standing
after the storm were the reinforced concrete ones," says
Pfanmiller. "Steel frame structures were twisted and bent, and of
course the wood structures were simply gone."
Pfanmiller's company builds concrete homes that, like the Sundberg
residence, can take the winds and storm surge of a major hurricane
and remain structurally sound. His secret is an aluminum concrete
forming system (Figure 2). His homes have 4-inch-thick
steel-reinforced concrete walls and 6-inch-thick floor slabs. There
are a half-dozen of his concrete houses in the Gulfport area, and
more on the drawing board.
FIGURE 2. After the first elevated slab is
set, crews can add as many as three more occupied stories in
successive monolithic pours using the Wall Ties aluminum form
system (top). Note the foam insulation (still exposed at this
stage), which is placed against exterior forms before the pour and
remains in place after forms are stripped. Pitched roofs are framed
as a wood truss structure, on top of the main flat-topped concrete
box (bottom).
The forms Pfanmiller uses are made by Kansas City-based Wall Ties
and Forms, Inc. (www.wallties.com). While similar in concept to
standard concrete forms, these are a bit more sophisticated. For
one thing, the Wall Ties system lets the builder integrate
2-inch-thick, R-10 rigid foam insulation into the exterior walls,
either on the outside face or in the center of the wall mass. It
also includes a set of accessories for forming up a supported floor
deck at the same time as the exterior walls and interior
partitions. An entire story can be poured in one shot, complete
with wiring conduit, window and door openings, and penetrations for
mechanical systems.
Pfanmiller can build as many as three occupied stories above the
open ground level, in a process that takes five to seven days per
story, including setting the forms, pouring the concrete, and
giving it time to cure.
The cost to the customer is 15% or 20% more than an equivalent-size
wood-framed house. "I'll be honest with you, it takes a special
kind of buyer, because they're going to pay a premium," admits
Pfanmiller. "You need a buyer who appreciates the staying power of
the structure and values the reduced insurance and the energy
savings."
Pfanmiller hasn't had trouble finding those buyers in the
custom-home niche, but he believes there could be a wider market
for concrete homes among production builders, who can use labor
efficiencies to reduce costs. As an example he points to Mexico,
where thousands of units of basic, affordable workforce housing
have been built in recent years using Wall Ties forms exactly like
the ones he owns.
A Custom Blend
For the custom market, Pfanmiller has worked with his friend Curt
Fields of Tri-City Contractors in Raleigh, N.C., to come up with an
approach that is flexible enough to build one-off home designs.
Their solution blends simple methods from the basement wall
industry with production techniques used in commercial concrete
construction.
The deep foundation pilings, for example, are usually made with
driven pressure-treated wood, because it's easy to find local
contractors to do that work. Once the pilings are driven,
Pfanmiller's own crew builds the wooden forms and ties the steel
rebar cages for a grid of poured-concrete grade beams —
again, a typical residential foundation technique (Figure 3).
FIGURE 3. The elevated foundation employs a
mix of commercial and residential methods. Grade beams are formed
with wood, and reinforced with rebar as specified by the project
engineer (top left). Vertical rebar is placed for connecting the
grade beams to columns. After the beams are poured, reinforced
columns are formed and poured using conventional basement wall
forms. A rented commercial shoring system is set up to support the
first-floor elevated slab (top right), and crews form the slab with
plywood (middle). Then floor insulation, rebar, conduit, and
blockouts for floor penetrations are placed, and the concrete is
delivered (bottom).
The piers (or "columns") that will elevate the home's first-floor
deck are formed on top of the grade beams. The first-floor deck is
then formed with plywood supported by rented shoring equipment.
Slab shoring includes all the adjustable screw jacks, steel beams,
brackets, and braces needed to temporarily support the plywood
formwork and the freshly placed concrete until the reinforced slab
has had time to set. Shoring is a commercial construction
technique, but there are shoring suppliers in most local
markets.
For the occupied stories above the first elevated slab — the
"housing lifts" — Pfanmiller relies on the Wall Ties
system.
Housing Lifts
Pfanmiller and Fields were among the first contractors to use Wall
Ties aluminum forms. "I think we have the second set of housing
panels that Wall Ties built," says Pfanmiller. The system uses
2-foot-wide rugged wall panels with extra reinforcement to
eliminate the bowing (or "pillowcasing") that conventional basement
forms typically experience with repeated use and wear. "Our forms
give us a smooth, flat wall that we don't have to mess with during
finish work," explains Pfanmiller.
To form up a story, the crew first sets the forms for exterior
walls (Figure 4). They apply a 2-inch-thick layer of rigid foam
insulation to the inner face of the forms, as well as special
spreader ties that hold the foam tightly in place. The crew then
cuts out the door and window openings, and screws treated-wood
window and door bucks, or blockouts, to the exterior forms.
(Additional screws are set into the sides of the blockouts, so that
when concrete is placed, the screws will lock the wood framing to
the concrete wall.) Rebar is placed and tied next and the plastic
wiring conduit and electrical boxes are installed. Finally, the
interior wall forms are erected.
FIGURE 4. Workers start to form walls (far
left) for a "housing lift" pour. Note the exterior wall forms, foam
insulation, form spreaders, rebar, and door blockout. The spreaders
lock inside and outside wall forms (left) together and hold foam
tight against the outside face. Plastic nailer strips are locked
into a slot routed into the foam.
The interior and exterior forms are set 6 inches apart, so the
result is a 4-inch-thick concrete wall, with 2 inches of insulation
on the exterior of the building.
Interior partition walls are formed the same way, but the forms are
set only 4 inches apart and no insulation is added.
Once the walls are in place, the crews install the accessory pieces
that form the transition from the vertical wall to the horizontal
floor, and that support the floor (Figure 5). These include:
• Interior ledger forms. These come either square-cornered, or
profiled to create an integral crown molding. They are attached to
the inside top of the wall form with special hammered-on "slide
clips." They also support the edges of the horizontal ceiling
forms.
• Exterior cap forms. These are wider than the interior
ledgers, and are used to form the edges of the 6-inch-thick ceiling
slab.
• Floor slab forms. Slab forms are 3 feet wide, and come in
lengths of 4 feet, 5 feet, or 6 feet, which can be combined along
with the beam supports to create rooms of different sizes.
• Shoring beams. These are designed to support the slab
forming system and are supplied in three widths — 4 inches, 6
inches, or 8 inches — in order to allow for a range of room
dimensions.
Figure 5. Special ledger cap forms are clipped
to the top of the inside wall forms (above). Shoring beams of
various lengths and widths integrate with the slab forms to allow
for a range of floor sizes (left). Crews set slab form panels to
span between the ledger forms and the shoring beams (below),
creating the form system for a monolithic wall-and-slab
pour.
After the forming system has been set and leveled, the second-floor
slab is equipped with the steel reinforcement, as well as with
conduit for wiring and blockouts for openings and penetrations
(Figure 6). As with the first-floor slab and the walls, this
process takes time and care. "It requires a lot of planning," says
Pfanmiller. "So often in residential construction you've got a
sketchy set of plans, and a lot of the mechanical stuff gets
figured out on the fly. But with this system we have to know where
the outlets, the plumbing, and the heat runs are going to be before
we get started."
Figure 6. Prepping the slab formwork is
laborious and exacting. Wiring conduit has to be carefully
positioned within the dense mat of heavy rebar (left). The
treated-wood blockout for an air-duct register has screws in the
back to lock it to the slab, and is chamfered at the bottom so that
the exposed-wood edge will be narrow enough for the grille flange
to cover. Plywood caps on the wood blockouts raise them to a good
height for use in guiding the screeds used to strike off the fresh
concrete slab.
When the pour finally happens, it goes fast — and Pfanmiller
says that the concrete supplier needs to be prepared to keep the
concrete flowing without interruption. "We absolutely don't want a
cold joint in a wall," he explains. (A cold joint occurs when
concrete in a form starts to set and harden before the next lift of
concrete is placed next to it, creating what could be a critical
weak spot.) "This can be a challenge with some ready-mix companies,
because when we order 50 yards we want five 10-yard trucks in the
street before we start the pour. Some of them are used to sending
you two or three trucks, and then cycling back the first two, but
we can unload 10 yards of concrete in 15 minutes, so we can't wait
for those trucks to cycle back."
There's an upside to this for the supplier. "It's also our selling
point for the ready-mix people and the pump people. We tell them
that if we have a pour of 50 yards — five 10-yard trucks
— scheduled for 8:00 in the morning, we will have the five
trucks and the pump off the job by 9:00."
After the first housing lift is poured and has set, the forms can
be stripped and stacked on the deck, and forming can start for the
next story. The exterior cap forms from the first story, however,
are left in place; these serve as the base for installing the next
story's exterior wall forms. Other than that, forming and pouring a
second or third occupied story is just a repetition of the
first-story phase.
Roofs
Security Building Group likes to pour the uppermost ceiling of its
top story as a flat horizontal slab. That makes the home's concrete
shell a flat-topped box. If the design calls for a pitched roof,
Pfanmiller attaches wood trusses to the top of the box (Figure 7).
"The roof is just a wood-framed architectural feature that's
securely bolted down to our concrete box," he explains. The trusses
allow the house to shed rainwater and may also house ductwork or
HVAC equipment. But they aren't really part of the home's
structural shell, and unlike in a wood-frame building, the loss of
the roof in an extreme hurricane event would not necessarily lead
to the loss of the rest of the home's structural integrity —
or even to extensive water damage of interior finishes and
contents.
Figure 7. Pitched truss roofs for the concrete
houses are set on treated-wood beams anchored to the flat top of
the concrete box. Mechanicals can be installed in the attic if need
be, and attic floors can receive deep blown fiber insulation for an
air-tight, highly insulated lid. Damage to the roof structure
during a severe windstorm does not compromise the structural
integrity of the rest of the building.
Not every customer wants the full measure of physical security that
comes with the concrete lid. Says Pfanmiller, "We have done several
custom concrete houses where the owners have opted for
architectural reasons to open up the ceiling for a vault. It comes
down to personal preference."
Finish Work
Once the concrete shell has been poured and the roof bolted on,
there's still a lot to do. Interior wall surfaces are typically
skim-coated with plaster or drywall compound (Figure 8). Pfanmiller
doesn't like to furr out and hang drywall because the energy
benefit of the thermal mass of concrete walls is optimized when the
concrete is in direct contact with the occupied space. Despite the
wall insulation's relatively modest R-10 rating, Pfanmiller says
that the air-tightness of the concrete envelope combined with the
heat-cycling effect of the massive walls and floors has earned the
Energy Star label for many of his homes.
FIGURE 8. Red-iron beams (top) allow the
creation of larger open spaces inside the houses. Wood-framed
chases (above) can be used for architectural detail and to hide
steel or ductwork. Plaster or drywall compound (left) applied
directly to the concrete walls leaves the thermal mass of the
concrete in contact with the occupied space.
Trimwork can be glued to concrete surfaces, or installed with
drilled or powder-driven fasteners. Interior architectural features
such as dropped soffits are often used to conceal ductwork; they're
framed with wood and fastened to the concrete wall or ceiling with
Tapcon fasteners (www.tapcon.com). Wood framing is also used for
stair chases and to box out the steel beams used to increase the
floor span of the reinforced slab.
Exterior cladding can be any common material. Plastic nailers
embedded in the rigid foam insulation hold screws just as well for
wood, vinyl, or fiber-cement siding. Steel stucco mesh can be
screwed to the same embedded plastic and the wall topped with
stucco.
When finished, Pfanmiller's concrete houses don't look much, if
any, different from a wood-framed structure — unless, of
course, that particular beach takes a direct hit from a powerful
hurricane. If that happens, the difference will definitely be
noticeable. ~
Ted Cushman covers the home building and
remodeling industry from his base in the Berkshire Hills of
Massachusetts. Photos by Dave Pfanmiller/Security Building Group
unless otherwise noted.
