by Ted
Cushman
High-end homes in prime locations often boast the best in exterior
woodwork, including costly entry doors of oak, mahogany, teak, or
even cherry. And that means potential trouble. Entry doors on a
coastal home stand directly in harm's way, sandwiched between the
indoor and outdoor climates and often facing blazing sun, soaking
rain, and drying wind.
One solution is to protect the entry door with durable solid-color
paint. "I've worked on 200-year-old exterior doors and shutters
whose wood was as fresh as new," says veteran contractor Greg
Sullivan of Marion, Mass., whose career has included high-end
architectural woodwork and finishing as well as commercial and
residential building and remodeling.
New Jersey door-finishing specialist Dave Anderson notes, "I
sometimes mention paint to people." Anderson finishes or refinishes
about 70 top-end entry doors a year, many of them on
multimillion-dollar houses facing the rivers, bays, and beaches
near New York City. But Anderson finds that his clientele is not
very interested in the paint option: "If they're spending $25,000
on a custom-built mahogany door," he observes, "they don't want to
hear about that."
Another commonsense idea is to shelter the door under a broad
overhang or portico (Figure 1). "I have one customer who owns a
gigantic, 15,000-square-foot, house, with zero overhangs over a
25-foot door unit," explains Anderson. "I've done his door two or
three times already. Now he is going to build a big portico over
it. Wood can be finished only so many times before all the cells on
the surface are shot — at least as far as making finish
adhere to them."
Figure 1. Clear finishes last longer when
sheltered from direct sun, as in the entry to this Rhode Island
home by architect/builder Andrew DiGiammo. The more exposed wood
trim has been painted on this house, and wood shingles have
received an opaque stain.
If customers don't want to hear about either paint or shelter,
however, they are going to have to hear about maintenance and
refinishing. Clear or translucent finishes need continual
reapplication, because they don't have anywhere near the
durability, or the protective power, of paint. The same
transparency that lets you see the beautiful wood grain also lets
damaging rays of sunlight reach the wood — a factor far more
damaging than wind or rain.
Solar Bombardment
Even through clouds, the sun is like a machine gunner taking
all-day target practice on a house, showering the exterior with
tiny ultraviolet (UV) bullets. And there's only so much ultraviolet
radiation that either wood or finishes can take. Photons of UV
shatter the electrical bonds that hold molecules together and
energize the remaining atoms to react with nearby materials or with
oxygen from the air. The results: faded colors, torn and bleached
wood fiber, and brittle, broken-down film coatings (Figure 2).
Coatings may erode, split, crack, yellow, peel, buckle, bubble, or
curl; what they won't do is last.
Figure 2. At right, two doors on opposite
sides of the same street show the effects of different solar
exposures. The two-part polyurethane clear coat on a mahogany door
on the sunny side of the street (left) is beginning to whiten and
crack after just two years in the sun and will soon need to be
stripped and reapplied. The same finish on a white oak door on the
shady side of the street (right) is still going strong after five
years in place. "Wind and rain don't have that much to do with
finish performance," explains finisher Dave Anderson. "It's mainly
the sun." However, once the finish begins to fail, water damage to
the underlying wood becomes a risk, adding urgency to the need to
refinish.
"I paint a doom-and-gloom picture for my customers because whoever
sold them the door probably didn't," says Dave Anderson. "I tell
them, ‘You put clear finish on wood outside, and you are
going to have to maintain it. And that will be expensive and very
time-consuming.' "
Blocking UV
UV blocking turns out to be difficult because the coating has to
defend not just the wood but also itself from the sun's
bombardment. Most formulas contain finely ground metallic
compounds, such as titanium dioxide (TiO2) and iron oxides called
"trans-oxides." These tiny flakes are mostly transparent to visible
light but reflective to the shorter-wave ultraviolet. They aren't
100% transparent, however, so the more you apply, the more the wood
grain is obscured.
In addition, there are UV-absorbing compounds — typically
organic (carbon-based) molecules — that soak up the UV and
release it as heat. Those are included in formulas to protect the
coatings themselves as well as the wood beneath.
Neither the reflective nor the absorptive UV protectant is 100%
effective. The absorbers eventually wear out and break down. The
reflectors let enough UV through that the wood will ultimately get
a sunburn. And while a heavy dose of UV protectant is the key to an
effective coating, there's no way to load up a coating with enough
to provide perfect protection and still see the natural wood. "If
you put enough material in to totally protect the wood, you've got
paint," explains Greg Sullivan.
A finisher applies a two-part ("2K") clear polyurethane to a
white oak entry door at the Jeld-Wen door factory (above).
Door-finishing specialist Dave Anderson (left) touches up the edge
of a distressed alder door from International Wood Products (a
Jeld-Wen division) in his finishing shop after changing the handing
on the door. Anderson says that whether factory-applied or
field-applied, 2K urethanes are very tough when new but strip
easily with paint stripper after several years of exposure to the
sun. He expects a urethane finish to last anywhere from two to
seven years without maintenance, depending on solar exposure,
before the door needs to be completely stripped and
refinished.
Paint chemist Steve Smith points to another helpful additive:
"antioxidant" chemicals that help keep molecules from reacting with
oxygen when they're hit with UV photons. These additives can
protect a urethane coating in much the same way that antioxidant
vitamin E helps protect human skin, says Smith. But he notes that
coatings that cure by oxidation, such as spar varnishes, can't use
antioxidants in the formula, because they inhibit the curing of the
film.
Unfortunately, it's hard to know how much UV blocker you're buying
in each can of finish. The type and quantity of UV blockers in a
coating formula is the one secret that manufacturers guard most
jealously. "I'm told that if they put one drop of UV inhibitor in
the formula, they can label it as a UV-inhibiting coating," says
Dave Anderson. "But it takes a lot more than a drop to have any
real effect."
Steve Smith points out that the coverage of a given finish is
typically what determines whether you've put enough blocker between
the sun and the wood. Smith provides clear instructions specifying
the volume of liquid to use for a given application. This way, he
knows how much UV blocker will be sitting on each square foot of
exposed surface. When you use a coating that doesn't come with
similar instructions, it may take some trial and error to develop a
feel for how many coats are needed.
UV blockers and solid film-forming ingredients are the high-cost
ingredients in a clear exterior finish. The better the quality and
higher the concentration of those components, the better the finish
will perform — and the more you'll pay for it.
Clear-Coat Options
When evaluating a clear finish, the most important question is
this: How well will it stop UV? To evaluate a product, the
experience of boatbuilders proves much broader than that of home
builders. Here's a quick look at the top choices from the
perspective of woodworkers with extensive marine experience:
Spar varnish. The traditional favorite is
the yachtsman's old standby, marine-grade spar varnish, made from a
base of natural oils. (Tung oil, a nut oil from Asia, is typical,
but linseed oil, soy oils, and other natural oils are also used.)
The oil is chemically modified to form "alkyd" molecules and is
mixed with metallic catalysts to speed drying (unmodified linseed
oil, an old-fashioned boat finish, can take forever to dry). The
alkyd films cure by reacting with oxygen from the air as well as by
evaporation of solvents and thinners in the formula. The best spar
varnishes have high concentrations of "long oil," which forms long,
flexible chains in the cured film. They also have heavy loadings of
UV-blocking chemicals.
Boatbuilder Doug Randolph-Foster says he's tried every finish out
there, but he still prefers traditional spar varnish (Figure 3),
despite the fact that it requires a laborious, painstaking
application. He starts with a careful sanding that includes a final
hand-sanding with 220-grit paper. He then wet-sands the wood using
tung oil, linseed oil, or an Epifanes flow-enhancer called
Easy-Flow, working the sawdusty slurry into the wood grain. Then he
wipes it off with a clear rag and leaves the wood to dry overnight.
Next comes a seal coat of Epifanes varnish thinned 50% with
Epifanes thinner, let to dry, and sanded again with 220- or
320-grit paper. Finally, it's time to brush on full-strength coats
of varnish — as many as 10 of them, sanded between coats.
Full-strength, the Epifanes varnish is thicker than most brands,
says Randolph-Foster — "not necessarily harder to flow out,
but different. Some guys hate it. I love it, and I hate everything
else."
The reason boat owners love spar varnish
is shown above: a deep, rich, clear coat that repels water and
reveals all the beauty of the wood. A finish like this takes 10 to
12 coats, however, and needs continual attention to maintain its
good looks. Without a yearly sanding and refreshing, varnish fails
by yellowing and peeling (left). When that happens, it's time for
sanding back to bare wood and starting over.
Two-part polyurethane. The modern alternative to
spar varnish is two-component ("2K") polyurethane, a plastic that
can be derived, like spar varnish, from natural oils but is often
synthesized from petrochemicals. Two-part urethanes cure through
reactions involving ingredients in the formula rather than by
reacting with air. However, they also release evaporating solvents
as well as volatile reaction products.
There are water-based polyurethanes that don't release volatile
organic compound (VOC) solvents, but they don't have much of a
track record on exteriors. Door-finishing specialist Dave Anderson
notes, "I have tested a lot of water-based exterior urethanes, and
I haven't seen one last at all, so far." Stricter regulations may
yet force the use of water-based finishes; "That's when I'll
retire," says Anderson.
According to Anderson, 2K urethanes are "a nightmare" to strip when
fresh, in case of a mistake, but they easily come off with paint
thinner and a putty knife after several years of direct exposure to
sun.
Cetol. Then there are the advanced and
somewhat mysterious offerings of modern chemistry. Popular among
both boat owners and land-locked wood finishers is Cetol, an
advanced system from Sikkens (widely available from professional
paint stores; a good online source is www.jamestowndistributors.com). Greg Sullivan prefers
the Cetol system because of its relatively low-build film, which is
easily rejuvenated on site without major stripping. The topcoat
dusts off gradually but can be renewed with light sanding, followed
by reapplication with a brush.
The Sikkens Cetol system includes a primer/sealer base coat and a
selection of clear and lightly pigmented topcoats. The formulas are
a trade secret, but the coatings have a lot in common with
better-known recipes — the base coat seems to behave somewhat
like a penetrating epoxy, finishers say, while the renewable
topcoat acts a lot like a modified oil-based alkyd spar varnish. An
orangish cast in the Cetol topcoats seems to suggest some sort of
iron oxide-based UV blocker. But as Steve Smith, the owner of rival
(and much smaller) California-based coating maker Smith and Co.
(800-234-0330; www.smithandcompany.org), notes, no coating maker will
gladly divulge what's really inside the can — or in what
proportions. "We paint chemists have our secrets," says
Smith.
Clear epoxy. Smith is the developer, 30 years ago, of
one version of another popular coating option: clear epoxy. Smith
and Co.'s Clear Epoxy Penetrating Sealer or CEPS (also marketed as
MultiPrimer), has a die-hard following among boat owners who use it
as a base for multiple topcoats of conventional spar varnish. (Five
Year Clear, a recently introduced two-part polyurethane from Smith
and Co., has yet to develop the same fan base, but it has performed
well in boating magazine comparison tests, and Smith claims some
owners have gotten as much as 10 years out of it.) MultiPrimer is
almost as thin as water, and Smith says it penetrates wood more
deeply than typical thicker epoxy coatings. But some boat owners
still stick with a thicker epoxy such as Gougeon Brothers' West
System (866-937-8797; www.westsystem.com), sometimes using added thinner to
aid flow and penetration.
Best of both worlds. "The epoxy base, with
traditional spar varnish on top of it, is almost the best of both
worlds," says Doug Randolph-Foster. "The epoxy will essentially
last forever as long as you keep a good UV-inhibiting varnish on
top of it." ~
Ted Cushman reports on the building industry from his base in
Great Barrington, Mass.
