by Ted
Cushman
Tropical storms and hurricanes damage coastal housing in multiple
ways. As building scientist Joseph Lstiburek observed in a November
2005 ASHRAE Journal article, "We learn our lessons from disaster.
Hurricane Andrew (1992) taught us about wind. Hurricanes Charley,
Frances, and Jeanne (2004) taught us about rain. The Red River of
the North Basin taught us about floods. Hurricane Katrina had it
all: wind, rain, and flood."
But insurance companies consider the Katrina disaster to be
primarily a flood event (although the storm reached Category 5
intensity at sea, winds in most affected land areas were no higher
than a Category 2 storm, and wind damage was relatively light). And
as Joe Lstiburek points out, Katrina's flooding was to some extent
predictable, and some of its effects could have been avoided.
Even as floodwaters rose in New Orleans in late summer 2005,
Lstiburek predicted in an interview, "The buildings in the older
part of New Orleans that were built elevated, using water-tolerant
materials like masonry and cement plaster, and with no cavity
insulation, will be relatively less damaged and will be able to be
cleaned up and put back into service. But houses that are flooded
that were built more recently using wood frames, gypsum wallboard,
and fiber cavity insulation are going to be much worse damaged, and
many of them will never be usable again."
Flooding is an inevitable consequence of coastal living, and
regardless of what the flood maps say today, the statistical
probability is that flood zones will change during the service life
of any home. Wet floodproofing ensures that when a home gets
flooded, it can dry out without causing excessive
damage.
Almost a year after Katrina, Lstiburek's predictions are borne out
by experience. Many older buildings in New Orleans (especially in
higher terrain) have been put back into service, while most of the
newer structures in lower-lying areas are candidates for
demolition. And if the lessons of Katrina could have been known in
advance of the storm, says Lstiburek, they should certainly be
learned now.
There are modern materials and assemblies as water-tolerant,
drainable, and dryable as the traditional methods used on some
older Louisiana buildings, he observes, "and if we build houses in
places that we know are at risk of being flooded, it's just common
sense to build them so that they can survive repeated
wettings."
Lessons of a Real-Life Test
New Orleans represents a citywide experiment on the effects of
flooding on contemporary structures and materials, Lstiburek noted
in March 2006. "All you have to do is spend a couple of weeks down
there and look at what they are tearing out," he says. "Paper-faced
gypsum is destroyed and has to be removed. Fiberglass insulation is
saturated and it's damaging the rest of the structure — it
has to come out. Wherever they have a failure, that's what they
have to remove. Well, the obvious lesson is that none of that
should be put back."
Whether restoring old buildings or constructing new ones, says
Lstiburek, construction in flood areas should use drainable,
dryable assemblies built with water-tolerant materials. "And what's
neat about this," he adds, "is that there is no code prohibition
telling us we can't do it that way. The code is not preventing us
from doing the right thing, for a change."
"Wet floodproofing" and FEMA. The concept Lstiburek advances is not
new: In fact, as he noted in the November 2005 ASHRAE Journal
article, "The Federal Emergency Management Agency (FEMA) has all of
the basics correct and has had them correct for a long time." PDF
documents available on the FEMA Web site outline the agency's
wet-floodproofing and flood-resistant materials requirements for
structures in low-lying areas.
But for FEMA, wet floodproofing is a second-tier defense: The
primary requirement is to elevate the building on a pier
foundation. Flood insurance coverage for buildings that are not
elevated but only wet-floodproofed is restricted to certain cases.
For example, a detached garage that is built below the level of the
main house is allowed to be wet-floodproofed (elevating a garage is
obviously impractical). Historic buildings whose character would be
altered by elevating may sometimes be wet-floodproofed instead. And
some commercial structures on the waterfront whose function
requires them to be built at grade may be wet-floodproofed rather
than elevated. Despite these allowances, FEMA has yet to sanction
wet floodproofing as an alternative to elevating a conventional new
home.
A sensible precaution. In Louisiana, and perhaps Mississippi, wet
floodproofing can be a wise idea for many people who aren't even
required to elevate — or as an additional backup precaution
for those who are. That's the message from experts at the Louisiana
State University (LSU) Extension. Says LSU's Claudette Reichel, "In
Katrina and Rita, many houses that were built above the Base Flood
Elevation got flooded." Currently undergoing a nationwide revision,
FEMA's floodplain maps are far from up-to-date; in any case, says
Reichel, "one of the things about Louisiana is that the Base Flood
Elevation does not stay put. Our flood patterns are not the same
over time. So if a house lasts 50 years or more, during that time
flood patterns are quite likely to change because of development.
There are many people in Louisiana whose homes were built in areas
that have never flooded for 30 years, and now, lo and behold, they
flood."
Even the best floodplain map, explains the LSU Extension's Pat
Skinner, is by no means a guarantee. "The regulatory elevation is a
statistical thing," she observes. "In any given year, the
probability of flooding above it is 1%. But the chances that you
may see a flood are multiplied over the 25 or 30 years of a home
mortgage, or the 50 or 100 years that the house is occupied. So
there are many houses that were elevated above the Base Flood
Elevation that did flood in this last storm, 1 or 2 feet into the
part of the house that was expected to stay high and dry. That's
why we recommend, ‘Build this high, and then also
wet-floodproof.' That way, if you get that bigger-than-expected
flood, your house will be less susceptible to damage" (Figure
1).
Figure 1. Wet floodproofing relies on the same
principles that are effective when used for exterior rainwater
management: drainability and dryability. The drawing at right shows
recommendations provided by the LSU Extension program for
flood-tolerant interior assemblies. When this concept has been
applied, interior walls can be opened up after a flood event to
drain and air-dry. Water-tolerant materials such as non-paper-faced
gypsum board, treated lumber, and closed-cell extruded polystyrene
insulation are used so that the building components can be returned
to service after they are thoroughly cleaned and dried, rather than
having to be totally demolished.
Recommendations for Rebuilding
Basic information on wet floodproofing can be found on the FEMA Web
site (see "For More Information," below). But FEMA's general
guidelines do not provide flood-tolerant assembly details. To help
remedy that, Joe Lstiburek has drawn up a set of suggested floor
and wall assemblies that represent simple, practical modifications
of commonly used details.
In new construction, Lstiburek calls for elevated floor frames to
be built with treated lumber and insulated with non-water-absorbent
rigid sheet materials such as extruded polystyrene (Figure 2).
Lower-story cavity walls should use treated wood or steel and get
exterior-applied rigid insulation; siding should be vinyl or
fiber-cement (Figure 3). Interior walls should receive
non-paper-faced gypsum wallboard, such as Georgia-Pacific's
DensArmor Plus (http://www.gp.com), which is free of paper facings as
well as starches and other ingredients within the board that could
support mold growth. In the event of a flood, strips of wallboard
can be removed at wall top and bottom to allow convective air
drying, says Lstiburek. In the case of contaminated floodwaters,
enough wallboard may need to be stripped to allow
power-washing.
Figure 2. Building scientist Joseph Lstiburek
(http://www.buildingscience.com) offers these
construction details for flood-tolerant foundation and first-floor
assemblies. The method uses water-tolerant materials and creates
drainable components that can be opened up to air-dry after a flood
event. According to Lstiburek, these options are compatible with
existing codes and can be adopted immediately for rebuilding or
repairs in flooded areas.
Figure 3. Shown here are two options for
drainable and dryable cavity-wall assemblies suggested by building
scientist Joseph Lstiburek. The wall designs share several key
characteristics: (1) No water-sensitive materials are used; (2)
exterior cavities are vented to the exterior; (3) interior cavities
can be opened to allow passive air-drying in the event of a flood
by removing strips of wall material at top and bottom to encourage
convective airflow.
Lstiburek also offers a masonry mass-wall detail (Figure 4). Rigid
insulation is installed on all masonry walls, walls are framed
without cavity insulation, and the water-tolerant gypsum board is
applied in the same fashion as for the steel- or wood-frame
assemblies, to allow air-drying after a flood event.
Figure 4. Like the cavity-wall assemblies
suggested by Lstiburek, these mass-wall assemblies are designed to
dry by vapor diffusion toward both the interior and the exterior:
The most moisture-impervious material (closed-cell rigid insulation
board) has been located at the center of the wall
profile.
Appliances like ovens, water heaters, and washing machines should
be installed on elevated platforms — a simple measure that
the LSU Extension recommends for all homes in potentially
flood-prone areas.
For retrofits of flood-damaged homes, damaged gypsum board and
fiber insulation should be replaced with more appropriate
materials. If installing exterior rigid foam insulation on walls is
impractical, Lstiburek suggests a 11/2- to 2-inch spray application
of a closed-cell, high-density polyurethane foam between the studs.
For additional protection of wood framing, he suggests a
borate-salt wood preservative treatment and maybe a coat or two of
latex paint. And in the case of retrofits of recently flooded
homes, it's obvious where the new materials are necessary. "You can
see how high the water came last time," Lstiburek says. "Just
replace everything from there down." ~
Ted Cushman reports on the building industry
from his home base in Great Barrington, Mass.
