by Mike
Guertin
As building codes address wind-zone construction with extra vigor,
more metal hardware is being required to tie buildings together
from foundation to ridge than ever before. Framing anchors, ties,
hold-downs, braces, tie-downs, hangers, connectors, straps —
every year I need more steel to build and remodel houses. And all
this hardware must be fastened to wood framing with nails —
hundreds or even thousands of nails on each building. Ordinarily,
that takes a lot of old-fashioned hammer swinging … unless
you own a metal connector nailer.
This class of nailers drives 1 1/2- to 2 1/2-inch-long by 0.131- to
0.162-inch-diameter nails through holes in metal hardware with
pinpoint accuracy. But they're not all created equal. Toolmakers
take different approaches to power, size, operation mode, and hole
indexing, so each model has its strengths and weaknesses. Choosing
one to suit the range of connecting tasks you encounter may be
difficult. My crew actually runs three different models to meet the
challenges of each connector situation.
To help you sort through the group and find the tool(s) to fill
your nailing needs, we tested 14 different tools to see how they
operate and to evaluate how they perform.
Right out of the gate, the field can be divided into two categories
based on drive mode: multi-blow (like a palm nailer) and
single-shot (like a regular framing nailer). The tools can be
further broken down by the nail length they drive: those limited to
1 1/2-inch nails, and others that drive 11/2- and 21/2-inch (and
sometimes longer) nails. Manufacturers also employ two approaches
to aim and guide nails into connector holes: an integral metal
probe/safety actuator at the tool nose, or the nail point itself.
Other less obvious design details come to light when you examine
the tools more closely.
Figure 1. The big advantages of multi-blow
hammers are safety and control: there's no chance of a ricochet off
the hardware, and it's easy to seat the nail properly.
Multi-Blow Tools
These six tools look unique. Imagine a tool about the size of a
finish nailer with a palm nailer replacing the single-blow motor.
Senco, Grip-Rite, and lesser-known PneuTools Inc. offer two
multi-blow nailers each. Only branding and cosmetic differences set
the tools from each company apart, because all models are made by
PneuTools (Figure 1). One group of models (Grip-Rite GR150, Senco
HN150, and PneuTools RN-150) drives 1 1/2-inch nails, and the other
group (GR250, HN250, and RN-250) runs both 1 1/2- and 2 1/2-inch
nails through an adjustable nose tube assembly.
The magazines are rear loading and handle one strip of 31- to
34-degree paper-collated 0.131-, 0.148-, and 0.162-inch-diameter
nails. The point of the leading nail in the strip is clearly
exposed at the tip and easy to index in a connector hole. Just like
palm nailers, there's no firing trigger on multi-blow tools.
Instead, you push the body of the tool (handle and head) toward the
work to initiate the blows. The body travels about an inch before
driving begins and continues to slide along the driver cylinder
with each blow until it bottoms out. It's important to keep
pressure on the handle and follow the driver until the tool stops
firing; otherwise, the nail head will be left standing proud
(Figure 2, page 4). Don't push the tool forward against the nail or
the driver will slide off the nail head.
It takes several practice drives to get the knack for using
multi-blow tools. The tools work best when you stand in line with
the tool. When reaching, or when your arm is out of line with the
driver, it's tiring to maintain pressure against the nose and
ensure productive blows to complete driving.
Some users warm up to the multi-blow tools and others don't even
want to hear them — literally. Operate more than one tool at
a time on a job, and the neighbors will think they've been invaded
by a flock of woodpeckers during mating season. Hearing protection
is a necessity for the operator and anyone working nearby.
The 250 series tools have an adjustable nail tube to switch between
1 1/2-inch and 2 1/2-inch nails. You just press the nose down
against a surface and slide the adjusting pin to the forward
position for 2 1/2-inch nails and back for 1 1/2-inch nails. So if
you drive both 1 1/2- and 2 1/2-inch nails, it pays to get a 250
series nailer rather than a 150 series.
The primary advantage of these multi-blow tools is safety. There's
no chance of a ricochet off the steel of a piece of hardware. In
order for the driver to reach the nails, the tool body needs to
travel at least one inch along the nail tube to activate the blows,
which acts as a safety for preventing misfires. Occasionally, when
we connected the air hose, a tool would pop once or twice, but a
nail was never broken from the collation.
Multi-Blow Nailer Specs
Features (1 1/2-inch models):
Weight: 4 lb. 7 oz.
Height: 9 1/2 inches
Loading: Rear
Capacity: 1 strips
Street Price: $179 to $239
Features (2 1/2-inch models):
Weight: 4 lb. 12.5 oz.
Height: 101/2 inches
Loading: Rear
Capacity: 1 strip
Street Price: $199 to $249
Strengths:
• Safe — no chance for ricochet with multi-blow
operation
• Nails do not have to be heat treated
• Consistently seats nails properly on the connector surface
except when operating at a shallow angle
• Lightweight, compact
• Low price
• Fits into cramped quarters
Weaknesses:
• Noise
• Slow drive speed
Figure 2. Nailers that drove the nail to the
correct depth seated the nail as shown (photo center). When
overdriven (photo left), the nail deformed the hardware, which is
just as bad as underdriven nails (photo right). Deformed hardware
and underdriven nails both result in an inferior structural
connection that will not pass inspection.
1 1/2-inch Single-Shot Tools
The two tools in this group use the nail point to index the
connector holes.
They have an obvious limitation in the type of anchors they can be
used with. But what they lack in versatility, they make up for in
maneuverability.
Bostitch MCN150 StrapShot
Sightlines on the nail point are very clear because Bostitch uses a
unique surface-sensing nose that remains retracted until you pull
the trigger. The nose slides out to touch the work surface when you
squeeze the trigger; if it senses a surface, the nailer fires. The
sliding nose also acts as a shield to reduce the chances of a piece
of paper tape, or an errant nail, flying back in your face. The
small notches in the side of the nosepiece increase sightlines to
the nail tip when you're positioned behind the tool.
By design, there's a limited range where the sliding nose permits
the tool to fire. The first time I used the MCN150, I placed the
nail tip against a stud and it wouldn't fire. That's because
Bostitch has designed a very sensitive nosepiece that can sense the
thickness of the steel hardware. It's designed to prevent misfires
on the surface of the hardware. The tool will fire only when the
nail drops down into the hole. Also, tipping the tool too far left,
right, or forward also reduces the distance the sliding nose can
travel. Tip the tool beyond about 30 degrees from plumb and the
nose won't slide far enough to let the tool fire. This prevents
users from driving nails at low angles to the work surface and
reduces the chance nails will glance off a connector.
The compact size makes sneaking the MCN150 into tight spaces a
breeze. It's lightweight and powerful enough to sink 1 1/2- by
0.148-inch nails into dry SYP and LVL, though there's noticeable
recoil when driving nails into these dense materials.
Bostitch MCN150 StrapShot Specs
Features:
Weight: 4 lb. 10 oz.
Height: 10 3/4 inches
Loading: Rear
Capacity: 2 strips
Street Price: $229
Strengths:
• Seats nails properly
• Good sightlines for indexing
• Sliding nose safety feature functions well
• Good weight/balance
• Dry-fire lock
Weaknesses:
• Recoils when driving into dense materials
• Drives only 1 1/2-inch nails
PneuTools Inc. RNS-150
The "safety" on this squat-looking tool isn't built into a nose
feature but relies on the body traveling about half an inch along
the nose tube like the multi-blow tools. You need to make sure the
nail is positioned in the hole and that the tool body doesn't catch
on anything nearby when sliding toward the work, or the nailer
won't fire.
Avoid placing any forward pressure on the handle, or the nail strip
can slide backward in the magazine, resulting in a misfire, a nail
jam, or a nail driven at a backward angle.
There's a forked "yoke" at the nose that raises the nail point out
of the hole when the tool is tilted too far left or right (Figure
3).
PneuTools Inc. RNS-150 Specs
Features:
Weight: 5 lb. 0 oz.
Height: 10 1/4 inches
Loading: Rear
Capacity: 1 strip
Street Price: $209
Strengths:
• Belt hook on body
• Dry-fire lock
Weaknesses:
• Left nail head proud of workpiece in dense woods
• Nails slide backward when forward pressure applied to
tool
Figure 3. To prevent ricochets off the metal
connector, manufacturers rely on a variety of different nose
designs. The Bostitch StrapShot tool (left photo) has a streamlined
barrel that moves the thickness of a metal connector. The gun won't
fire unless the nail is in the hole, and the geometry of this
barrel prevents the tool from firing at a steep angle. PneuTools
relies on the travel of the whole front end, not just the
nosepiece, but includes a forked yoke that will prevent a misfire
at a steep angle (right photo, left image). Hitachi relies on both:
a wide yoke prevents angled misfires and a sensing finger that can
"feel" the nail in the hole will prevent firing outside of the hole
(right photo, right image).
2 1/2-inch / 1 1/2-inch Single-Shot
Tools
Five tools fit in this group, the Paslode F 250S-PP, Bostitch
MCN250, Hitachi NR65AK, Max HN65J, and PneuTools RNS-250. Most are
slightly larger than the 1 1/2-inch-only nailers and almost as
maneuverable and small enough to fit between rafters spaced 16
inches on-center. All of the tools set nails fully when driving
into dimensional framing lumber, but only one — the Max HN65J
— had the power to drive a 2 1/2-inch galvanized nail into
LVL stock.
Paslode Positive Placement F 250S-P
The first connector nailer we bought (and still have) was an older
version of this tool. The Paslode is a full-size framing nailer
with a special magazine and long probe safety tip (Figure 4). The
probe gives good sightlines to see around the body of the tool and
locate the connector holes. It's one of only two nailers with an
adjustable depth-of-drive control (hex wrench needed), and it has
quick-release magazine for clearing nail jams (though we never had
to use it). The tool fits between 16-inch framing. You can mix nail
lengths in the drop-in style magazine without causing a jam.
The tool is the heaviest of the lot at almost 9 pounds, which takes
its toll when you have to fill hundreds of holes. And despite it
being a full-sized nailer, it had trouble sinking a 2 1/2-inch nail
into LVL even with the nose adjusted to the maximum depth
setting.
Paslode Positive Placement F 250S-PP Specs
Features:
Weight: 8 lb. 13 oz.
Height: 13 inches
Loading: Drop-in
Capacity: 2 strips
Street Price: $349
Strengths:
• Fits between 16-inch framing
• Probe easily locates hole
• Adjustable depth of drive
Weaknesses:
• Heavy
• Sometimes left nail head proud of workpiece in dense
woods
• Price
Figure 4. Paslode (left) and Max (right) use a
safety probe that both indexes the hole and prevents the tool from
firing if it's not in a hole. This probe pivots out of the way when
the nail fires.
Bostitch MCN250 StrapShot
Big brother to the MCN150, this model has the same safety nose
feature. These are the only tools with a nail-point-type indexing
system that prevents the nails from back-sliding when forward
pressure is applied (Figure 5). Two spring-loaded one-way check
pawls flip out behind the leading two nails on a strip and lock
them in place.
We tested the long magazine model that holds two strips of nails. A
short magazine (one nail strip) is also available. The magazine has
two rear loading slots, one for 11/2-inch nails and one for 21/2
inch. Be sure to remove the remaining 21/2-inch nails when
switching to the 1 1/2-inch length. Difficult-to-clear nail jams
occur when 11/2-inch nails are loaded behind 2 1/2-inch ones. The
shorter nails seem to throw off the angle of the last two or three
longer nails in the magazine as they enter the firing chamber,
resulting in two nails being driven at once — with a jam
resulting. It's tricky to unload nails from the magazine; you have
to squeeze two tiny buttons to disengage the check pawls, and then
push the nails backward until they pass by the pusher.
The nailer always set nails flush with connector surfaces, except
when driving 2 1/2-inch nails into LVL, leaving them 3/4 inch
proud.
Bostitch MCN250 StrapShot Specs
Features:
Weight: 6 lb. 0 oz.
Height: 13 3/4 inches
Loading: Rear
Capacity: 2 strips
Street Price: $359
Strengths:
• Nails don't back-slide in magazine
• Fits between 16 o.c. rafters
• Dry-fire lock
• Rafter hook
Weaknesses:
• Nail jams when 1 1/2-inch nails loaded behind 2 1/2-inch
nails
• Leaves 2 1/2-inch nails 1 inch proud in LVL and sometimes
dry SYP
• Hard to unload remaining few nails when changing sizes
Figure 5. A tool that uses the nail to index
the holes can potentially jam if the tool is pressed forward while
the nail is in the hole. This causes the collation to back out
slightly, so the nail is misaligned with the driver blade. Only the
Bostitch StrapShot (left) prevented this with a pawl that slips
down between nails and prevents the collation strip from backing
out.
PneuTools RNS-250
This nailer is nearly the same as the RNS-150, with a bigger cap
and wider magazine. As with the Bostitch MCN250, don't load
11/2-inch nails behind 2 1/2-inch nails, or the nailer may jam. The
RNS-250 sets nails flush with the metal connector when driving into
most softwood but leaves the nails proud in LVL and dry SYP.
PneuTools RNS-250 Specs
Features:
Weight: 5 lb. 12 oz.
Height: 14 1/4 inches
Loading: Rear
Capacity: 1 strip
Street Price: $249
Strengths:
• Drives nails flush
• Dry-fire lock
Weaknesses:
• Leaves nail head proud of work piece in dense woods
• Nails slide backward when forward pressure is applied to the
tool
Hitachi NR65AK(S)
The Hitachi uses a surface sensing "push lever" similar to the
sliding nosepiece on the Bostitch nailers. The lever remains
retracted until the trigger is squeezed. When it contacts the
surface, the tool fires. The nail points index the connector holes,
so don't push the tool forward, or the nails will slide backward,
throwing off the drive angle. Though the nails never jammed when
the magazine was pushed forward, some nails were driven at a
backward angle and others didn't fully sink.
Hitachi avoids the jamming problems the Bostitch and PneuTools
nailers have when mixing nail lengths by adding a nail length gate
at the back of the magazine that prevents you from doing so. Before
you can slide the gate between the 1 1/2-inch and 2 1/2-inch
settings, the pusher must be released and slid forward. The action
prompts you to remove the remaining nails before loading new
ones.
There's a yoke at the nose similar to the PneuTools RNS tools that
prevents firing when the tool is tilted far to the left or
right.
We tested the S model with the short track that held one strip of
nails. The standard NR65AK weighs slightly more and holds two
strips of nails.
Hitachi NR65AK(S) Specs
Features:
Height: 13 inches
Loading: Rear
Capacity: 1 strip (S model) / 2 strip (regular model)
Street Price: $375 to $425
Strengths:
• Magazine gate prevents loading different length nails at
same time
• Dry-fire lock
Weaknesses:
• Recoils and leaves nail head 3/4 inch proud when driving
tool
Max HN65J
There's no describing how pleasurable this tool is to use. Compact,
lightweight (lightest of the lot), good sightlines, and able to
sink 21/2-inch nails into LVL without any kickback. And since it
loads coil nails rather than strips, it has more than twice the
capacity of other nailers. The coil swing-out door opens up the
nail chamber for jam clearing (but we never needed to use the
feature). The tool uses a probe that looks blunt at first glance
but has a small molded point at the tip to index connector holes
well. There's a built-in air filter, a lock-out switch next to the
trigger, and a depth-of-drive adjustment in front of the
trigger.
The only hitch is it operates at 170 to 380 psi, so you'll need
Max's high-pressure compressor ($1,250) to run it. If you already
have the compressor, you're only looking at $850 for the nailer
(gulp). Make sure you can readily get nails locally. My local tool
shop has to special-order nails (taking three to four days).
Max HN65J Specs
Features:
Weight: 4 lb. 6 oz.
Height: 11 1/4 inches
Loading: Coil
Capacity: 100
Street Price: $850
Strengths:
• Drives nails flush even in dense material
• Coil capacity
• Light weight
• Depth-of-drive adjustment
Weaknesses:
• Price
• Nail availability
Convertible Single-Shot Tool
Bostitch F 33 PT
This is a full-sized framing nailer, but when the regular contact
nosepiece is replaced with a probe-tipped nose, the tool becomes a
metal connector nailer (Figure 6). The transformation takes just
six seconds with the squeeze of a button.
There is no depth-of-drive setting, but despite the full power
behind the driver, this tool doesn't overdrive short 1 1/2-inch
nails. And for users who need to drive "double shear" diagonal
nails into connectors, this tool has the capacity and power to
shoot full-length 10d nails.
Figure 6. The Bostitch F 33 — a
full-size framing nailer — converts to a metal connector
nailer by switching out the nosepiece. This is the only metal
connector nailer that can handle the 3-inch-long nails required for
the "double-shear" or diagonal location required in some
hangers.
The Bostitch has no problem sinking nails into the hardest woods,
including LVL. But the full-size nailer has a couple of drawbacks:
it's hard to locate connector holes with the small probe tip in
tight spaces where sightlines are restricted, and it's heavy to
work with in tight quarters and overhead for extended
periods.
The dual function makes this Bostitch a good tool for users who
work with metal hardware occasionally and don't need a dedicated
tool. And for users who prefer 21-degree plastic collated nailers,
the Bostitch F 21 PL has the same convertible metal connector
feature. ~
Bostitch F 33 PT Specs
Features:
Weight: 8 lb. 8 oz.
Height: 14 1/2 inches
Loading: Drop-in
Capacity: 2 strips but only 1 recommended at a time
Street Price: $289
Strengths:
• Drives nails flush even in LVL
• Can mix nail length without jams
• Drives 3-inch to 3 1/4-inch nails
• Dual-use tool (framing and metal connector)
• Rafter hook
• Price
Weaknesses:
• Heavy
• Tight fit between 16-inch o.c. spaced rafters.
Mike Guertin (www.mikeguertin.com) is a custom home builder and
remodeler in East Greenwich, R.I., and a member of the JLC LIVE
Construction Demonstration Team leading sidewall shingling
workshops. All photos by the author.
