by Ted
Cushman
Three painters work together on the shady side of a house to
get the paint on quickly. Modern acrylic paints and stains tend to
dry quickly compared with older, higher-VOC formulas.
If you've gone to the beach on a calm day in midsummer, you've
probably seen the haze: a thin, brownish gray soup in the air
that's not quite smoke, not quite fog, and not quite a cloud,
veiling the horizon and dimming your view of the distant hills.
What you can't see — but what is often there, along with the
visible haze — is ozone. In the upper atmosphere, the ozone
layer is good: it shields the earth from harmful ultraviolet
radiation. But at ground level, ozone is bad: it's a corrosive form
of oxygen that can irritate the eyes and nose or trigger asthma
symptoms. Ozone even damages plants, causing billions of dollars of
crop losses every year.
House paint plays a role in both the ozone and the haze. The
"volatile organic compounds," or VOCs, evaporating out of paint
solvents react with power-plant and vehicle emissions to help form
the harmful ozone molecules as well as the tiny, light-scattering
airborne particles that we see as haze. So as federal and state
governments try to get a handle on the pollution problem, they're
turning their attention to paint. A cascade of regulations, moving
from the U.S. Environmental Protection Agency (EPA) down through
regional federal/state commissions, and finally taking effect at
the state level, is putting the squeeze on suppliers to reduce the
solvent content of all paint, stain, and primer formulas, or else
be forced to take the products off the market.
The gears of government grind slowly, however, so the regulations
aren't ramping up overnight. Southern California imposed strict VOC
rules starting in the 1960s, but the Northeast and Mid-Atlantic
states are just beginning to regulate VOCs. Some coastal states
have rules in place already, while others are still phasing them
in. With plenty of lead time to adapt, paint makers are staying
ahead of the curve, at least on the East Coast. After years of
adjusting to California requirements, most suppliers can now put
low-VOC products on East Coast shelves that come close to matching
the performance of the old solvent-borne products they replace. But
a close match isn't a perfect substitute — and therein lies
the rub. For contractors in the field, the new formulas may call
for some changes in the way they choose, handle, and apply their
products.
What's a VOC?
The "volatile" of VOC means the material evaporates easily;
"organic" means it's based on carbon; and "compound" just means
that it's a molecule made up of different kinds of atoms. Alcohol
and gasoline are examples of VOCs; in paint, the typical VOCs are
solvents with names like toluene, benzene, acetone, and ketone.
Most VOC solvents come from crude oil: the most common solvent in
house paint or primer is a generic mix of petroleum distillates
called "Stoddard solvent," also known as "white spirits" or
"mineral spirits," or simply "paint thinner."
Not quite a cloud nor fog, the haze of ground-level ozone is
clearly visible in this image captured from NASA's Terra satellite
on the morning of August 2, 2006, off the mid-Atlantic coast. Also
known as smog, this ground-level ozone is created when VOCs react
with power-plant and vehicle emissions. Paint solvents contribute a
small but significant part of the VOC problem. At the time, a high
heat advisory was in effect for the region. In addition to trapping
particulate pollution near the earth, high heat, stagnant air, and
humidity generate more ground-level ozone.
Oils vs. Acrylics
When you talk about solvent-borne and waterborne house paints,
you're basically talking about oil (or, more precisely, "alkyd")
paints versus acrylics. And as the VOC rules get tighter, oil
paints are taking the brunt of the heat. That's because of the
different manner in which oil and acrylic paints are formulated: as
a result of their different chemistries, oil paints and stains are
typically solvent-borne, while acrylic coatings are always
waterborne.
Solvent-borne alkyd formulas react with oxygen, leading to
eventual brittle failure over time. Shown here is an advanced case
of "alligatoring" of alkyd paint over old clapboards.
Alkyd paints oxidize as they dry; oxygen reacts with the
string-like alkyd molecules and helps them "cross-link" together.
So an alkyd paint coating actually becomes a continuous, chemically
connected film as the paint cures. That's how oil-based paints
develop their particularly desirable properties, such as high
gloss, hardness, abrasion resistance, water repellency, and
washability. But there's a downside, too: the oxidation process
continues indefinitely. Exposed to sun and air, the paint will
eventually yellow, become brittle, shrink, and crack in the process
known as "alligatoring."
For house paints, longer-chain alkyd molecules tend to provide a
better mix of properties than shorter-chain oils, but it takes a
lot of solvent to keep those bigger alkyds in solution, and
multiple coats are required to achieve a really good film build.
Cutting down on the solvents makes the paint thick and heavy, which
means it doesn't flow or handle as well. As a result, it's hard for
an alkyd paint maker to even come close to the new VOC limitts and
still make a paint that will perform the way it's supposed to. As
the rules get tighter, traditional alkyd paints are increasingly
ruled out.
Acrylic latex paints are a very different animal. Polyacrylic is a
plastic polymer derived from petroleum, rather than from
plant-based oils. Polymers are long, repetitive chains built up out
of short links. Chemists can control the laboratory process to grow
the big polyacrylic molecules to whatever size they like, out of a
soup of short "acryl" pieces. And by varying the ingredients, they
can modify the molecules to get special properties they desire,
creating, for example, an acrylic polymer that is hard, soft, or
somewhere between.
Acrylic paint resins "coalesce" as they dry, creating a
continuous film on top of the wood. As long as the surface is
prepped well, the paint will stick. But acrylics are particularly
intolerant of conditions such as mill glaze and dirt, and surfaces
should be sanded to give some "tooth" to which the paint can
bond.
An acrylic polymer doesn't dissolve in the hydrocarbon solvents
used for oil paint. In fact, acrylic won't dissolve in water,
either. Instead, chemists blend the acrylic into water as an
"emulsion" or "dispersion" — in simple terms, whipping the
materials together with soapy surfactants and thickeners to form a
smooth mixture, like making a milkshake. These surfactants and
thickeners, along with flow agents, help to keep the mixture stable
in the can, and help it flow and level out in use.
Compared with the small, stringlike alkyd paint molecules dissolved
in a high volume of solvent, acrylic paint resins are more like
large, semisoft balls suspended in a relatively small amount of
water and customized additives. It's called a "high solids"
formula. And as the paint dries, acrylic doesn't cross-link:
instead, the bits of acrylic gradually soften and melt together, or
"coalesce," to form the continuous film. Because it's not
chemically active when it's dry, acrylic paint ages better than
alkyd paint, especially outdoors, holding its color and gloss
longer and not readily shrinking or cracking.
In addition to the acrylic binder, acrylic-based paints contain
pigments and light blockers, to add color and to protect against
sunlight. As the paint dries, it's tricky to keep the pigments and
the binder evenly distributed, rather than clumping together and
forming a faulty, inconsistent film. Because of this, waterborne
paints generally have some kind of "coalescing agent" or
"coalescent" additive that helps the acrylic molecules melt
together around the pigment, trapping the pigment within the
acrylic film. Coalescents are slow-evaporating VOC solvents —
which is why even most waterborne acrylic paints contain at least
5% or 10% VOCs in the can, and it's why an acrylic paint job may
take a week or more to fully harden and to stop smelling like fresh
paint. As the rules get stricter, even some acrylic paint makers
find it challenging to squeeze the VOCs out of their formulas to
squeak in under the regulatory limit and still get the good film
formation they want.
Paint Makers Adapt
Paint formulation is a game of trade-offs, explains Stewart
Williams, director of the Rohm and Haas Paint Quality Institute.
Even the very strict, 50 grams per liter, VOC limit enforced in
smoggy Los Angeles is doable in a flat or semigloss acrylic paint,
he says. "But if you go to the higher gloss, it's more challenging
— because you've got to deliver those enamel-type properties
that we've all grown accustomed to. I can give you a zero-VOC gloss
today, but it won't have that enamel hardness or the other 20
things you may want."
Rohm and Haas and its competitors spend hundreds of millions of
dollars on research each year. Advanced paints that don't exist
today will be on the shelves in a few years. "There is no question
that there are going to be breakthroughs," says Williams. "Whether
it's on the acrylic end, or in the acrylic/alkyd hybrid end, or
what have you — it's going to happen."
On the acrylic side, companies are working on natural,
nonevaporative substitutes for petrochemical coalescents, hoping to
get away from VOCs entirely. Acrylic polymers continue to evolve as
well: Rohm and Haas' Avanse technology uses custom-brewed polymers
to evenly embed pigments within the acrylic binder matrix, for
better and more efficient coverage and hiding. Benjamin Moore's new
Aura paint line goes a step further: the company claims its new
polymerization method actually encapsulates paint pigments
completely within the small spheres of acrylic polymer, achieving
better gloss as well as more durable and brighter color — and
with a zero-VOC formulation.
As rules tighten, 150-g/L flat acrylic paints (top left) and
350-g/L alkyd stains (above left) will be disappearing from shelves
in the few coastal states where they can still be found. Taking
their place may be advanced formulas such as Benjamin Moore's Aura
brand (above right), a near-zero-VOC acrylic with an innovative
colorfast pigment system.
Meanwhile, oil-based alkyd suppliers are working to break away from
their solvent-borne past with a new "alkyd dispersion" technology,
grafting modified alkyd chains onto acrylic polymers and blending
them into a mostly waterborne matrix. That technology is only a few
years old and still in its early stages of development. The hybrid
alkyd/acrylic chemistry is tricky — it still needs some
solvents to work, and it may not yet supply all the benefits of
both the alkyd and acrylic ingredients. But already, ICI (Imperial
Chemical Industries) has introduced a line of "advanced alkyd
technology" paints under the Dulux brand, based on the
alkyd/acrylic hybrid resins, that promises the hardness and gloss
of an oil paint with the convenience of soap-and-water cleanup and
the advantage of lower VOCs. The raw ingredients for the new
waterborne oil paints are available to any paint company from
outside sources, so as the method advances, more enamel and gloss
paint brands are likely to appear using water-compatible
alkyds.
In the Field
What does all this mean for the professional painter? Most agree
that modern paints perform as well as, or better than, traditional
coatings: they stick better, last longer, and hold color better.
But the new paints tend to behave differently on the brush or in
the sprayer. For many painters, adjusting can be a challenge.
Nigel Costolloe runs Catchlight Inc., a custom painting company in
the Boston, Mass., area. Says Costolloe, "Years of habit and
practice and skills, honed in the application of one type of
material, when confronted with a material that behaves markedly
differently, is a challenge for anyone." If a painter is accustomed
to brushing or spraying oil formulas, he'll find modern acrylics
tricky at first. Oil paints dry slowly and provide lots of "open
time" for painters to brush back into their work, and oil paints
relax gently, allowing brush marks or lap marks to disappear more
readily. Modern acrylic paints dry much faster — especially
if the weather is hot, dry, or breezy — and so lap or brush
marks are harder to avoid.
To keep a house looking good, walls need to be routinely washed
and repainted every few years. In coastal zones, three years
between recoats is fairly good performance for paint or stain over
wood siding and trim.
New England painter Charles Gilley has modified his technique to
accommodate the faster-drying new acrylics. On a building exterior,
for example, he has to paint fewer courses of clapboards at a time,
in order to maintain a wet edge as he works. On sunny days, Gilley
has to hustle to stay on the shady side of the building —
once a wall is hot and sunny, the paint dries too fast. And for
wood-panel doors, Gilley now follows a meticulous pattern, painting
first the panels, then the rails, and then finally the stiles, so
that cross brushstrokes won't create visible lap lines across the
door's component parts.
Traditional painters particularly regret the loss of solvent-borne
primers for repainting jobs on old weathered wood exteriors. The
traditional method, which Gilley and other painters have practiced
for years, is to start with an oil-based primer, and then apply an
acrylic top coat. The solvent-borne primer wets the wood more
readily and soaks in better, explains Gilley, and it can partially
overcome difficult-to-remove dust and grime. "Just take some fine
dust, like drywall dust, and put a drop of water on it, and you'll
see what I mean," says Gilley. "Water will bead up on the dust. But
if you put some paint thinner on that same dust, it will soak right
in." In the same way, argues Gilley, oil paints will soak into wood
through dust or dirt, where a water-based paint will get repelled
and fail to form a bond.
A thorough and vigorous washing is the best prep for routine
repainting. Don't neglect the areas under eaves — they can
accumulate salt and grime deposited by moisture rising up from soil
around the building.
Even Rohm and Haas, the acrylic specialist, won't argue with that
tradition, says Stewart Williams. "If your substrate is
sufficiently damaged and in need of repair, then yes —
instead of moving large balls of acrylic through pores, you're
moving string-shaped molecules with a solvent that penetrates. It's
not just some belief that is out there — I think it has
proven out that you get much better performance on difficult
substrates by going with the old faithful alkyd primer followed by
an acrylic top coat."
But Nigel Costolloe points out that a penetrating primer is no
substitute for good surface preparation. Oil-based formulas may
have better wetting power, he says, but years of accumulated grime
and pollution can repel even an oil-based formula and prevent good
adhesion. "I've seen oil-based primer flake and peel off a house
prematurely when somebody didn't take the time to do the proper
surface prep," he explains. "But if you do make sure that the
existing paint is cleaved and the wood is sanded off to remove the
deteriorated cellulose that has been damaged by ultraviolet light,
and clean the surface, in my experience a waterborne primer can
adhere just as well as an oil-based primer."
Even Costolloe, however, sees situations in which he prefers to use
alkyd paints. "In the residential market, if you already have
multiple existing coats of alkyd paint on a house, it's better to
stay with an alkyd," he notes. Alkyd and acrylic paints expand and
contract at different rates in response to changing weather, he
explains, and where a base of alkyd paint already exists on the
wall, another coat of alkyd on top of it is more compatible.
Good surface prep improves the performance of any paint. Here,
sun-damaged wood fibers and remnants of an old prime coat are
sticking to the back side of peeling alkyd paint. A thorough
sanding and washing and a high-quality prime coat would have helped
this paint job hold up longer.
Ultimately, argues Costolloe, it's craftsmanship, not paint
formula, that makes or breaks a paint job. "I think the greatest
challenge for any painter is reading a label," he says — only
partly in jest. "The painting business does not have a barrier to
entry," he notes. "A car, a small ladder, and $65 worth of tools,
and you can be up and running. And education and continuous
learning and the concept of self-improvement are almost alien to
our industry." But good learning resources are available, he says,
including educational sessions put on by paint companies and by
local chapters of the Painting and Decorating Contractors of
America. Costolloe likes a three-hour CD-ROM training tool produced
by the Quality Paint Institute: "We put all our new hires through
it, and every employee retakes the program once a year." The CD is
available from the Paint & Decorating Retailers Association at
www.pdra.org/shop.php.
Even with the best of paints and the best of training, however,
paint is temporary — especially in a coastal climate. In mild
exposures, a good exterior paint job won't last a decade, admits
Great Barrington, Mass., painter Paul Shepard. Some paint companies
promise 12 years for a wall painted with their primer and top coat,
but Shepard counters, "That's B.S. — and you can tell them I
said so. I tell my customers a paint job is good for five to seven
years. If I say 12, they'll come back to me after 11 years
demanding satisfaction." Shepard remembers painting a house whose
owner had used a paint that promised 20-year performance. "He
actually waited 20 years to repaint it," says Shepard. "That wood
was crying."
And Shepard works a hundred miles inland. On the coast, you're
lucky to get five years from a paint job; three years is more
typical. Martha's Vineyard builder John Abrams, CEO of South
Mountain Company, Inc., has a simple solution: he doesn't paint
exteriors. "We try to have a zero-maintenance exterior, and in our
environment, paints just don't last," he says. "We've tried a lot
of different kinds of paint. But in order to keep a house looking
well cared for and keep the wood protected, you basically had to
repaint every three to five years. And that just seemed
insane."
So now, Abrams relies on aluminum-clad wood windows, white cedar
shingles from the sustainable forests of Maine's Seven Islands Land
Company, and recycled cypress trim. "The shingles are good for 25
to 40 years without paint," he says. "The cypress will last
virtually forever."
For coastal builders who do use paint, this is a time of
transition. In Virginia, Delaware, Pennsylvania, Maryland, and New
York, suppliers stopped shipping high-solvent formulas at the
beginning of 2006, although retailers are still allowed to "sell
through" any existing inventories. Other states aren't on board
yet: in Massachusetts, VOC limits may not take full effect until
2011. Will effective new formulas be available by the time existing
stocks of oil-based paints run out? Only time will tell. ~
A former frame and finish carpenter, writer Ted Cushman has
been covering construction business and technology since 1993. All
photos by the author except as noted.
