Coastal areas are particularly vulnerable to pollution.
Streams, tidal flats, wetlands, and shore waters form a rich,
but sensitive, ecosystem, and man-made pollution can have
devastating effects on the life forms that inhabit that coastal
zone. One of the biggest threats to that coastal web of life is
simple runoff — stormwater that falls on roofs, lawns,
or roads, then flows into sewers and makes its way to streams
or directly into the ocean.
Ordinary road runoff is bad enough — tainted with
gasoline, oil, brake and transmission fluid, metals, and other
toxins. But even worse is the problem of "combined flows." In
many municipalities, stormwater shares a pipe with sewage; when
there's a lot of rain, sewage treatment plants are overwhelmed
and raw, untreated sewage overflows into the local waterways or
into the ocean.
New York City, Washington, D.C., and many other East Coast
cities are plagued by sewage overflows. "New York's system
— like those in hundreds of others cities —
combines rainwater runoff with sewage ... New York’s
sewage system overflows essentially every other time it rains,"
the New York Times reported in November of 2009
As Sewers Fill, Waste Poisons Waterways," by Charles
Duhigg). Smaller cities are also prone to the problem: on
December 13, for instance, Fox TV's Channel 10 in Mobile,
Alabama ran a short, routine report about a rainstorm that sent
more than 12,000 gallons of raw sewage into the Bayou le Batre
Heavy rainfall causes sewage overflows," by Blanton
Box).
As development eliminates more and more acres of natural
landscape and replaces soil and vegetation with urban
"hardscape" (roofs and paving), the runoff and sewage overflow
problem grows more intense. In response, states and communities
are moving to require a new approach to stormwater —
an approach that seeks to detain rain on the site where it
falls and allow the water to seep into the earth, as it would
in an undisturbed natural landscape. Called "Low Impact
Development" or "Environmental Site Design," the advanced
method relies on technologies such as permeable paving and
natural "rain gardens" rather than on catch-basins and
pipes.
Maryland passed
legislation in 2007 requiring all new development and
construction to apply Environmental Site Design methods,
according to a state website;
final regulations to implement the policy were published in
May. And while Maryland is a leader in the Low Impact
Development arena – Prince George's County, Maryland,
created the first comprehensive
manual for the technique (9 MB PDF download) -- other
states are moving the same way. North Carolina, for example,
also has new
stormwater
regulations for coastal sites which require stormwater to
be contained and managed on site.
To manage rainwater on site, one of the prime tools in the
builder's or developer's toolkit is "pervious" or permeable
paving. Whether made with poured concrete, asphalt, or pavers,
permeable paving systems allow rainwater to flow through and
percolate into the ground, instead of flooding into sewers. In
fact, the porous materials don't just permit flow: microbes and
funguses that grow within the pores of the material and in the
gravel sub-base are able to capture and break down many
pollutants, helping to purify the rain and runoff before it
passes into the local groundwater. The storage and slow release
of the water evens out local stream flows, preventing flooding
and "scouring" during rain events, while slowly feeding the
streams so that they don't dry out between storms —
thus maintaining the natural, pre-development stream
environment.
The US EPA has installed three types of pervious paving at
an EPA facility in Edison, New Jersey, and plans a long-term
study of the system's performance. Scientific American covers
the Edison test
EPA tests porous pavement to combat contaminated rain
runoff," by Larry Greenemeier), and the Agency has
published an official statement on the project
EPA's New Green Parking Lot Allows Scientists to Study
Permeable Surfaces That May Help the Environment").
But there's already plenty of data about the performance of
pervious materials — enough that authorities are
starting to consider it as a first-line option for builders and
developers. In South Bethany, Delaware, for instance, city
officials are looking at pervious concrete as one acceptable
means to satisfy a new town requirement for permeable
landscaping for homes near the beach, reports the Bethany
Coastal Point
New concrete type gets perking in South Bethany," by Monica
Scott).
Pervious concrete's water-draining capacity is impressive.
In this YouTube
video,
a demonstration parking lot at the University of New Hampshire
drinks down 1500 gallons of water in under two minutes.
As more and more concrete companies get trained on the
technology, pervious concrete is becoming more widely
available. And the material itself is advancing, according to
engineer Matt Offenberg of Rinker Materials (a major supplier
of concrete admixtures). On his blog, Offenberg says that with
the use of appropriate admixtures to enhance the mix, pervious
concrete is evolving from a "lumpy, sticky paste" with "little
workability" into a "flowable, workable, slump-able material
Modern Vs. Meatball Pervious Concrete"). In this YouTube
video,
workers place a mix stiffened with Forta Corporation's
"GreenNet" reinforcing fiber admixture.
For more information on pervious concrete, check out the
website of pervious concrete specialists
PCI Systems, LLC, and
take a look at the pervious concrete section of concrete
industry website
concretenetwork.com.
