Scientists addressing an early November conference in Tampa,
Florida, on defective Chinese drywall have offered a more
detailed explanation of why the material produces gases that
corrode copper elements in buildings, such as wiring and air
conditioner coils. According to reporters who attended the
Technical Symposium on Corrosive Imported Drywall," a
$300-a-head event sponsored by the University of Florida, a
leading investigator into the problem says the gas releases can
be traced directly to the presence of pure sulfur in the
panels.
The Sarasota Herald Tribune says that toxicologist Tom
Gauthier of the firm Environ International, hired to study the
problem by builder Lennar Homes, has found that the elemental
sulfur in the panels reacts with naturally-occurring carbon
monoxide in the ambient air to form carbonyl sulfide. The
carbonyl sulfide then reacts with moisture and air to produce
hydrogen sulfide and carbon disulfide. All three gases have
been detected in test chambers and in homes containing the
Chinese drywall. And according to Gauthier, Environ was able to
stimulate a much faster release of the offending gases by
placing the drywall in a chamber rich in carbon monoxide.
Government scientists lag behind Environ's investigators and
other outside researchers, notes the Herald Tribune
Federal scientists trail others on drywall," by Aaron
Kessler). Consumer Product Safety Commission (CPSC) scientists
in a report last month, the paper notes, "were not yet even
able to state there was an association between the tainted
drywall and the corrosion of copper wires, pipes, air
conditioning coils, and other metal components" — even
though "Florida, along with a host of private consultants, has
long since determined that there is a strong association
between the drywall and corrosion."
Tom Gauthier's results were corroborated by Michael Tuday,
research and development director of California-based Columbia
Analytical Services, Inc., and Zdenek Hejzlar, an expert in the
environmental and toxic health fields with the Fort Myers
office of Engineering Systems Inc., reports the Fort Myers
News-Press
Blame sulfur for drywall woes, experts say," by Mary
Wozniak). "The three scientists, in separate presentations,
confirmed that the sulfur interacts with indoor air and other
agents, like carbon monoxide, to cause different sulfur
compounds to be emitted from the drywall in low amounts. It is
enough to cause the drywall’s corrosive effect on air
conditioning coils and other metal items in the home, they
said."
The sulfur explanation has the virtue of simplicity
— unlike a competing theory that casts suspicion on a
possible microbial source of the gas releases. "Some labs say
Chinese drywall contains significant amounts of
sulfate-reducing bacteria," reports the Palm Beach Post
Bacteria, chemical reaction debated as roots of drywall
problem," by Allison Ross). But "the bacteria theory needs
a lot of work," said Florida Department of Health toxicologist
David Krause, pointing out that while the drywall may contain
bacteria, no connection has yet been established between the
bacteria and the sulfuric emissions. On the other hand, if
carbon monoxide is the limiting element in the formation of
carbonyl sulfide, then according to basic chemistry it would
make sense that gases are emitted at a steady rate until most
of the sulfur in the material is consumed — subject
only to the continued availability of carbon monoxide in the
ambient air.
Environ scientists also told the conference that in their
view, removing the bad drywall and replacing it with fresh,
sulfur-free drywall should eliminate the problem, according to
the Sun Sentinel paper
Rip out Chinese drywall and start over, scientist advises,"
by Paul Owens). James Poole, an industrial hygienist with the
firm, said, "If you remove it, clean up the debris, ventilate
the home and rebuild, there's no reason you can't expect
success."
Lennar Homes, which has torn out and replaced the defective
drywall in dozens of homes already, refused to comment, the Sun
Sentinel reports. But Heather Keith, a lawyer for GL homes,
which has replaced drywall in at least 20 units, told the paper
that customers were "happy" with the fix, saying, "There are no
reported or ongoing health or odor issues. I'd be surprised if
the scientific community would say that the extensive repair
that involves the complete removal of the interiors of a house
is premature or insufficient."
