Jeff
Kent
Unlike many composites, PVC won't pucker at the surface when
nailed. Some boards come with precut lock miters (inset), which
don't have to be glued.
The company I work for builds custom homes on the coast of
Narragansett Bay in Rhode Island. It's a harsh, damp environment
that eats wood finishes and encourages mold and rot. Most
homeowners here can look forward to spending a lot of time and
money maintaining their exteriors. So when my supplier approached
me five or six years ago with a new PVC trim product that looked
like painted wood but was immune from these problems, I was eager
to try it. I already use fiber-cement siding and Trex decking, so
PVC would let me offer my customers a totally maintenance-free
exterior. I used it for the first time on a 5,200-square-foot
Shingle-style house in Charlestown, Rhode Island. The material more
than lived up to its promise. I now use it every chance I
get.
Using PVC trim doesn't require any new skills. You can cut it,
drill it, and fasten it with standard carpenter's tools (Figure 1).
But because the material is more flexible than wood and expands and
contracts more, you do have to vary your approach a bit. If you
don't have good installation information, you're going to hate this
product. However, if you learn to detail it right, it can save you
expensive callbacks. The people I know who have learned how to use
it, myself included, say they'll never go back to wood.
Figure 1: PVC trim stock cuts and routs much like wood. The
dust tends to have a static cling, but it's not as fine or as
abrasive as fiber-cement dust. PVC trim also won't dull blades any
faster than wood.
The Material and Cost
The material used in PVC trim is called cellular PVC. The resin
itself is similar to that used in plumbing pipes, but the term
"cellular" refers to the trim material's lighter density. PVC pipe
is much denser; the cut edge actually looks like glass. If you made
a board out of the pipe material, it would be too heavy to lift and
you would never be able to drive a nail through it. To make PVC
trim boards, manufacturers mix the compound with a blowing agent
that causes it to expand, giving the material a uniform cellular
structure that matches white pine and clear cedar but has no grain
to warp or soak up moisture.
PVC trim comes in 1/2-, 5/8-, 3/4-, and 1-inch thicknesses and in
18- and 20-foot lengths. Shingle mold, brick mold, crown mold, and
beadboard are also available, as are PVC sheets in 1/2-, 5/8-, and
3/4-inch thicknesses.
Most of the companies that make PVC trim seem to charge roughly the
same price for it, but that doesn't mean all products are the same.
The main variables I've found are porosity and color. Some brands
have porous edges that are hard to sand smooth and finish, and some
products aren't a true white — a problem if you don't intend
to paint. Others have a white surface and a brown interior that
shows on unfinished butt joints. In my experience, the best-quality
PVC trim is made by Azek and Kleer. Both companies make dense,
nonporous boards that are easy to sand and finish. And they're a
true white all the way through.
PVC costs about twice as much as finger-jointed pine and just a
little less than clear cedar. It also takes a little more time to
install than wood. However, we encourage our customers to look
beyond the initial cost to the fact that it's a durable product
that never needs maintenance.
Indeed, the product's advantages make it well worth the cost. Since
there's nothing organic, you don't have to worry about insects
eating it. It won't soak up water, so you can set it right on
concrete without fear of rot. Because there's no grain, it won't
warp, twist, or bend. And when you glue two pieces together, they
fuse into one, making the joint permanently watertight. These
advantages make the product great for much more than simple trim.
In fact, the more we use it, the more uses we find for it. They
include:
• exterior railings and balustrades
• raised panels for exterior window treatments
• access panels for whirlpool tubs
• outside shower stalls (Figure 2).
• interior and exterior columns. We've had so much success
with these that we made 100 three-sided columns in our shop. We
slip the column over a structural post, then glue the fourth side
in place on the job site (Figure 3).
We even used PVC once to make a 10-foot-long photographer's sink!
The glue fused the joints, making it a single piece.
Figure 2: PVC material has no organic material, so it is not
prone to rot. This makes it ideal for coastal homes. Not only will
all exterior trim, including everything on this entry (above), hold
up to wind and high humidity, but it also is an excellent material
for outside showers (right). The author even shapes the soap dish
from PVC.
Figure 3: While durable on the exterior, PVC has advantages for
interior woodwork as well. The author uses it for interior columns,
preassembling a boxed column and then installing it around a
structural post.
Workability
The first thing you will notice about a PVC board is that it's a
lot floppier than an equally sized wood board. It's so flexible
that you can tie a 1-inch-wide strip into a pretzel shape. Because
of this flexibility, it takes two guys to rip the material (Figure
4).
Figure 4: PVC trim stock is much more flexible than wood of
comparable dimension. It will sag on a table saw, so two people are
needed to rip it. To demonstrate the material's flexibility, the
author ties a 1-inch-wide strip into a pretzel.
Some contractors, concerned that the PVC will flex between rafters
or trusses, claim you need a sub-fascia. However, we don't use a
sub-fascia and I've never had any deflection problems, even when
spanning 2-foot distances between roof trusses.
The flexibility actually has an advantage. The same thermal
blankets plumbers use to bend PVC pipe (available from any plumbing
supply store) can be used to soften a PVC board. If you're
installing arch-topped windows, for example, the softened board can
then be placed in a jig to make a piece of curved head trim. It
will cool in about ten minutes.
Nailing and cutting are the same as for wood. The material won't
pucker when you nail it, like some composites, and there's no more
wear and tear on bits, blades, and tools than with wood. (Compare
that with fiber-cement, which not only dulls blades, but its fine
dust actually destroys tool motors.)
Gluing
The biggest problem with PVC is that it expands and contracts with
changes in temperature, and unlike wood, it actually expands more
lengthwise. The manufacturers claim that you get only a 1/16-inch
expansion and contraction in a 14-foot board, but I haven't
measured it. I do know that if you put it on a house during the
summer when it's warm and don't use the glue, you can come back in
the winter and see big gaps. Manufacturers say that the greatest
expansion comes after the last nail, so it's important to nail
aggressively and close to the end, but in my experience the best
way to prevent shrinkage is to glue all joints.
I use glue wherever one piece of trim touches another, and I always
stagger the joints from one piece to the next. Without glue, the
material will expand and contract in different directions. With
glue, you control that expansion and contraction. In fact, the glue
does more than bond two pieces, as with wood: It actually fuses
them together to form a single piece (Figure 5). I've glued butt
joints and given them to people to try and break. They can't do it.
If they succeed in breaking anything, it's the board and not the
joint.
Figure 5: Once glued, the many pieces
of a PVC cornice fuse together, creating a stiff assembly that
remains seamless. These seams are hardly noticeable after three
years on a house in Narragansett, R.I.
I've used PVC plumber's glue, but wasn't altogether happy with it.
It turns yellow over time, and it starts to set up in a matter of
seconds, giving you little work time. I've since switched to
Gorilla brand PVC glue, a water-based product that does as good a
job, doesn't yellow, and gives about five minutes' working time
(Figure 6). That's plenty of time to get it on the edge of an
18-foot piece of trim. We've found the easiest way to apply the
glue is from a plastic squeeze bottle. An empty drinking water
bottle works great for this.
Figure 6: While plumber's PVC cement will bond trim stock, the
author prefers Gorilla brand PVC glue — a water-based product
that doesn't yellow, and gives about five minutes' working time. He
buys it in bulk and uses a water bottle to apply it.
For corner boards, we rely on Kleer brand stock that comes with a
lock miter that doesn't need to be glued (see inset to lead photo,
above). We preassemble the corner boards,
using an Omer nail gun that shoots plastic nails. The nails fire
through the material very easily, and a light sanding blends the
heads in with the white trim. The plastic nails aren't structural
(they're only meant to clamp the joint while the glue dries), so we
still use stainless-steel nails to fasten the boards to the
house.
Finishing
PVC can be left unfinished or painted. Because the product is
white, the first few times we used it, we figured we wouldn't have
to paint. But glue drips, as well as glue-laden fingerprints and
smudges, meant we spent a lot of time cleaning the stuff afterward.
We finally concluded that we could offer a better result for less
money by painting it. Another reason for painting PVC is to
discharge the natural static, which is inherent to the product.
(The static attracts dust and dirt.)
We use one coat of a good acrylic latex paint. We find that it
actually holds up better on PVC than on wood because there's no
moisture in the material to weaken the paint bond. We don't prime
and we don't use oil paint. We don't use oil-based putty, either,
because the oil in the putty will bleed through the paint. (I heard
one contractor say that he has a guy dab appliance paint on the
nail heads with an artist's brush, but I haven't tried that.)
Painted PVC is virtually indistinguishable from painted wood trim
and the PVC will hold paint for up to 25 years. Homeowners will
probably grow tired of a color before they need to repaint.
If you're not painting the material, use a paint scraper to clean
up dried glue and remove scratches from the surface (Figure 7).
Simply bear down on the scraper and pull on it. Although it takes
several passes, it will eventually pull the scratch away. ~
Figure 7: PVC trim holds paint much better than wood, and it
will never require maintenance if left unpainted. Scratches,
scuffs, and glue can be removed with a sharp scraper or light
sanding.
Jeff Kent is a project manager with EFC Construction Management
in Pawtucket, R.I. All photos by Charles Wardell.
