Synthetic Decking As Quality Advances Preference Becomes a
Matter of Appearance
Builder’s 2011
Brand Use Study , the magazine’s comprehensive
annual survey of builder product preferences, was released on
April 12. Among the hundreds of products examined, one category
of special interest to coastal builders is synthetic
decking.
Builder surveyed 10,000 readers identified as professional
building contractors, asking respondents to answer four basic
questions about their brand choices:
• Which brands have you heard of?
• Which brands do have you used in the past two
years?
• Which brand do you use the most? And,
• How do you rate the quality of the available
brands?
When it comes to synthetic decking, one brand,
Trex , stood out as the most
widely known, and also as the most commonly chosen
view results. Seventy-two percent of builders had heard of
Trex, and 46% had used Trex recently nearly double the score of
the first runner-up,
Azek. Twenty-one
percent said they used Trex “the most”
— double the second-place finisher, Azek, at 11% Trex
and Azek were the only two brands to hit double digits on this
question.
Interestingly, however, despite being the clear favorite of
Builders, Trex did not score at the top of the scale in
perceived quality.
CertainTeed’s EverNew decking won that honor,
followed by
TimberTech
in second place. Trex was third in the crowded field of 20
brands.
The quality ratings, however, are a near dead heat across
the board. Although Builder provided a seven-point scale of 1
(poor) to 7 (excellent), all the synthetic decking brands
clustered between 4 and 5.5. The top 7 brands all ranged from a
low of 5 to a high of 5.41. The top three scores —
CertainTeed’s 5.41, TimberTech’s 5.29, and
Trex’s 5.22 — amount to essentially a photo
finish, with any significance lost in the statistical noise.
Still, the results underscore Trex’s undeniable
success as a brand. By establishing an early lead in market
penetration and consumer name recognition, Trex has earned the
category-defining position of prominence, even without any
clearly perceived quality edge. The name stands for itself:
just as “Kleenex” is tissue and
“Xerox” is photocopying,
“Trex” is synthetic decking.
For a more nuanced look at the market Coastal Connection
turned to Jim Finlay the owner of
Archadeck of Suburban
Boston a deck and porch construction franchise based in
Burlington Mass Finlay sees Trexs name recognition advantage
every day His showroom offers a wide selection of brands on
display 15 large floor assemblies and another 20 choices in 2
foot sample squares But he says customers typically come in
saying Oh Im interested in that Trex stuff I ask them says
Finlay ‘Do you mean Trex the manufacturer or do you
mean composite decking in general and they say ‘Yeah
composite decking
“Trex is the original,” says Finlay.
“They’ve been around the longest. They kind
of invented composite decking. They got a good lead on everyone
else.” But when it comes to quality, Finlay says, the
apples to apples comparison gets a little more complicated.
“Other companies have typically been quicker to
introduce various improvements,” he says.
“They put grain in, they use hidden fasteners, they
add new colors. Trex has tended to lag behind a little, and
when they do come out with their version of the new features,
they’re a little more expensive.”
But at this point, Finlay says, all the big leading
manufacturers are on a fairly even footing in terms of quality
and features. Instead of comparing brands, he says,
it’s more interesting to compare whole generations of
products, across the brand spectrum. And the ten or more years
since Trex started the ball rolling, Finlay says he’s
seen three generations arise.
“This is just my way of understanding the array of
available products,” Finlay explains. “But to
me, the first generation was the original Trex and some of its
early competitors. The material was homogeneous — all
one color, all one texture, flat, and smooth, with no grain to
it. It looked manufactured, because it was. And you
can’t find that stuff anymore, even if you wanted
it.”
“Then the second generation came along,”
Finlay goes on. “People brought out systems with
hidden fasteners — typically, using a board with
grooves on the side, and some kind of clip or biscuit with
screws. And in about that same time period, companies
introduced boards with some kind of embossed wood grain to make
the decking look more natural and realistic. By then you had a
number of players in the market —
CorrectDeckTimberTechFiberon, et
cetera.”
All of those products still had a few drawbacks, however,
notes Finlay. Reinforced with wood fiber for strength, the
boards had small exposed surface fibers that served as food for
mold and mildew. Marketing those products as
“zero-maintenance” got some suppliers in
trouble, as homeowners discovered that decks in shady locations
were prone to surface mildew and needed periodic scrubbing with
bleach. Colors faded over time, too.
The third generation of products dealt with those
disadvantages. Manufacturers added new color effects to augment
the embossed grain — random streaking and shading. And
they improved the surface durability of the boards, achieving
high degrees of stain resistance, scratch resistance, and
mildew resistance. “That’s really popular
with customers,” says Finlay. PVC-based products are
naturally hard and tough; third-generation boards made of
polyethylene or polypropylene are now surfaced with a
“cap stock” — a thin layer of
hardened pure plastic with no exposed fiber to gather dirt or
support organic growth. “So now we have a good-looking
grain, nicer colors, more natural shading, and a greater
resistance to the elements,” says Finlay. But he notes
that the suppliers are also careful now to market the material
as “low maintenance,” rather than
“no maintenance.”
The improvements come at a price, Finlay notes.
Second-generation boards, which are still on the market, sell
for about $2.50 a line foot in Finlay’s market, while
the third-generation material may sell for $3.50 or $3.75. That
price difference is enough to keep some customers buying the
older technology.
Within the third generation, however, the different brands
of synthetic decking offer equivalent features, and are priced
within a few percent of each other. And given the fact that
framing costs and installation labor costs are the same,
there’s no significant price advantage with any of the
common brands, says Finlay: “Any price difference
generally loses to the trump card of appearance.”
These days, Finlay says, synthetic decking in general is
starting to out-compete wood. “We do more synthetics
than we do wood now,” he says, “and
that’s because the features have gotten
better.” Technically speaking, he says, the latest
composite products are head and shoulders beyond what the
market offered five or ten years ago. “Used to be,
people would consider synthetic decking and look at the
features. How much does it fade? How much maintenance will I
really have to do? Is it strong enough? But now the industry
has solved those issues, and they’ve got products that
are fade-resistant, stain-resistant, perform well outside, are
strong enough, hold their color -- and all that’s left
for the consumer to think about is appearance.”
And with the newest products, that appearance has become a
strong selling point. “Today’s
third-generation decking looks great,” says Finlay.
“It doesn’t have that horrible manufactured
look. My sense is that people who own a synthetic deck are no
longer bringing friends in and making excuses and talking about
how low maintenance it is, but rather looking at it and seeing
the beauty of it. It’s good-looking
stuff.”
