Lessons From Ike
After a year-long study of the damage caused by last year's
Hurricane Ike in coastal Texas, the Institute for Business and Home
Safety (IBHS) released a
report on the storm in October, including recommendations for
upgrading homes to better withstand similar storms. Here is the
first of three stories outlining the IBHS
recommendations.
As with most hurricanes, only a minority of homes in Ike's path
suffered the devastating effects of storm-surge wave action or
extreme winds. Generally, the IBHS report notes, the most common
risk to houses from hurricanes is simple water intrusion, caused by
a combination of 70-mph to 100-mph wind and rain. And so the
obvious place to start improving existing houses is to upgrade
roofs, roof coverings, and roof vents against the action of
wind-driven rain. In a section called "Tier 1: The Roof and Water
Intrusion," the report recommends a series of measures to toughen
roofs.
The basic concept is to install high-wind-rated roof covering
over securely attached sheathing, to ensure a strong attachment for
ridge and soffit vents, and to provide for quick and easy
deployment of temporary vent coverings if a storm approaches. If
replacing the roofing is cost-prohibitive, and it's not time for a
routine re-roof, then the report suggests a series of steps
building owners can take between re-roofs.
If you are re-roofing, IBHS recommends re-nailing roof sheathing
to bring it up to a stronger spec. Use 8d ring-shank nails spaced
at maximum 4 inches on-center near roof edges, overhangs, and at
the corners of hip roofs; space nails no farther than 6 inches
on-center for the rest of the roof.
Because shingles might get blown off, it's important to seal the
gaps between roof sheathing panels as a backup against rain
intrusion. You can apply peel-and-stick membrane to the entire roof
or just apply 6-inch-wide strips of peel-and-stick to the cracks.
But make sure you get good adhesion — some OSB is coated with
a waxy water repellent that can keep membrane products from
sticking down. In that case, you'll have to use a special primer to
prep the OSB before applying the membrane (most membrane
manufacturers can also supply a recommended primer for this
situation).
Finally, use wind-rated shingles. Asphalt shingles are now
tested for compliance with ASTM Standard D 7158, and receive a
rating for resistance to wind uplift. You can use shingles with a
Class F rating if your design wind speed is 110 mph or less, but
you want a Class G rating for design wind speeds up to 120 mph, and
a Class H rating if the design wind speed is higher than 120
MPH.
If you're not re-roofing, you can still seal the roof sheathing
gaps and strengthen the sheathing attachment, by applying adhesive
foam sealant from the inside. Spray a closed-cell, urethane-based
foam onto the joints between panels and at the joint where
sheathing meets the rafters or truss top chords. (Information on
one product, Foam Seal from ITW, is available at
www.foamsealamerica.com.)
And whether you're re-roofing or not, it's a good idea to
strengthen the attachment of gable-end roof "lookouts," which are
vulnerable to being peeled back by high wind, leading to water
intrusion and gable-end structural failure. The IBHS report
provides a detail (see page 37) for upgrading this framing element
using steel connectors at the gable end and at the joint where the
lookout framing end meets an interior truss.
Next issue, we'll take a look at the IBHS recommendations for
protecting window and door openings and strengthening porches and
carports.
