A.Rocky Geans, president
of L.L. Geans Construction Co. in South Bend, Ind.,
and member of the board of directors for the
American Society of Concrete Contractors,
responds: A garage floor does require a slope
for drainage so water won't pool on the floor, and
1/4 inch in a foot is typical. But if you do a good
tight screed and finish job, 3/16 inch per foot
will do. And yes, the gravel sub-base should be
graded to the same slope as you intend for the slab
surface.
The bigger question is, where do you drain the
water to? If you are located in a freeze-thaw
climate such as we have here in South Bend,
drainage toward the overhead door could be a
problem.
When snowmelt or water from washing the car
seeps under the door and meets 25°F or
colder temperatures, it freezes. Frequent seepage
can repeatedly melt and refreeze the existing ice,
setting up a continual freeze-thaw cycle that can
cause the surface to scale off early in the
driveway's service life. One solution is to pitch
the slab to the center of the garage and provide
drainage into a dry well or, if the elevation
allows, to an exterior drain.
But even with drainage through the overhead
doorway, many concrete driveways and aprons hold up
well under freeze-thaw conditions. The keys are to
make sure you have air entrainment in the mix, seal
the slab and driveway when new, then instruct the
homeowner to maintain it properly.
We seal new driveways and slabs with Kure-N-Seal
30 from Sonneborn. The frequency of
resealing depends on wear patterns for a particular
driveway. Basically, as soon as the sealer has worn
off, it's time to apply a new coat. A good test is
simply to wait until the drive is perfectly dry and
apply a few separate drops of water on the drive
using an eyedropper. If the drops soak in, you need
to seal the surface; if they bead up, you're
okay.
If you do install the drain in the center of the
garage, be sure to check your local and state
building codes. Some may allow a dry well, while
others may require connecting to an exterior
drain.
