This efficient recordkeeping
system keeps all
job-related paperwork in one place on site
Without a way to organize the paperwork that tends to
accumulate at the job site, it’s impossible to find what
you need when you need it. On my first few jobs, the
client’s name went on an overstuffed file folder that
lived on the passenger seat of my truck, often till months
after the job was complete. Like most tools, however, the
paperwork got sharper with experience.
These days I work as a project manager handling several jobs
at any one time. To keep all the records straight, I use a
separate, three-ring binder for each job. All paperwork
relating directly to the construction process is organized into
ten standardized sections, and the notebook stays on site where
the crew and I – and the homeowners – use it every
day. When the job is completed, the notebook goes onto a shelf
in my office for quick reference.
The ten sections can easily be modified to meet the unique
requirements of any construction company or of a particular
job, but I’ve deliberately designed the organizational
scheme to follow the order of construction. The simplicity of
the notebook increases the likelihood that it will be used, and
to be effective it must be accessible and concise.
Office Supplies
The forms I use for the job-site notebook are
all readily available, either at stationery stores
or by mail order. Here are the sources I use to
build each notebook for as little as $10:
Three-ring binder and
columnar pads: Wilson Jones Company
(ACCO Brands, 300 Tower Pkwy., Lincolnshire, IL
60609; 800/222-6462). I equip every binder with a
low-profile three-ring hole punch that can be
clipped to the binder rings.
Notebook tabs:
10-Tabs Ready Index, Avery Dennison Office Products
(P.O. Box 129, Brea, CA 92822; 800/462-8379;
www.avery.com). The tabs and table of contents can
be customized with a set of labels you specify
using Microsoft Word or Corel
WordPerfect. Blank paper
calendars: The At-A-Glance Group (101
Oneil Rd., Sidney, NY 13838; 607/563-9411).
Computer-generated
calendars: Calendar, Expert Software
(802 Douglas Rd., North Tower, Suite 600, Coral
Gables, FL 33134; 305/567-9990;
www.expertsoftware.com).
Calendar Creator version 5.0, Creative Office
(The Learning Company, One Athenaeum St.,
Cambridge, MA 02142; 617/494-1200;
www.learningco.com).
General construction
forms: Construction Forms and
Contracts, The Craftsman Book Company (P.O. Box
6500, Carlsbad, CA 92018; 800/829-8123;
www.craftsman-book.com). This book includes 125
customizable forms (the forms are also provided on
a floppy disk).
1. Job
Schedule
Section 1 contains the "First
Contact" sheet and the job schedule. I create the single-page
contact sheet on a spreadsheet, then print it onto letterhead
(). The basic information is filled out in the office and added
to later as necessary in the field. It includes client contact
information, a brief description of the project, plus the start
and finish dates. The names and numbers of all subcontractors
are also recorded here, along with contact information for the
designer or architect, if applicable. Depending on the job,
this sheet also includes a list of required inspections, the
names of the inspectors, and the dates they’ll be at the
site. There’s also a place to make notes about site
access and security, use of the owner’s utilities, and
other owner concerns, like child safety and pets.
This section of the notebook also contains the master
schedule (). I fill this out by hand on a preprinted
8-1/2x11-inch blank calendar (see "Office Supplies"). Depending
on the type of work you do, you might prefer to use a Gantt
chart or a CPM flowchart, but the schedule should be simple
enough so that anyone at the site can use it. If the foreman is
not at the job, the lead carpenter should be able to use the
schedule to keep the job on track.
I find it helpful to think of the schedule as the by-product
of the initial takeoff and estimate worksheets, which are
organized by construction category. To keep the schedule
simple, use just enough categories to give you a clear picture
of each phase of the project without cluttering its overall
scope. Then insert subcontractors, inspections, and holidays
into each phase to create the schedule sequence.
2. Daily Job
Log
Section 2 holds the Daily Job Log,
which is used to track job progress (). The backbone of the
notebook, the job log provides both an outline of the
day’s work and a detailed list of work done to date. It
is filled out every evening and consulted every morning by the
job foreman. While the job log should contain all necessary
details, it should be limited to one page. This ensures that it
will get used properly and also makes it much easier to scan
for critical information.
Like the contact sheet, the job log can be created on a
spreadsheet, then printed out or copied as required. At the top
of each sheet is a place to record the job name and date
– simple but essential information when trying to piece
together a chain of events after the fact. The core of the job
log is the list of tasks planned for that day, the time
allotted to complete the work, and the names of the crew or
subcontractors who will do the work. Items on this task list
often carry over to the next day or week, depending on the
scope of the job.
The job log is also the place to list calls to be made,
materials needed (often projected several days in advance), and
suppliers scheduled for deliveries. A separate section lists
subcontractors scheduled to appear at the site, either that day
or in the near future, along with any notes about lead times or
unresolved questions that need clarification.
Every job log sheet stays in the notebook for the duration
of the project. I like to "dog-ear" the top right-hand corner
of the current page at the end of the day so the day and date
for the next day show in the corner. When I visit the site the
next morning, I spend the first cup of coffee with the crew
reviewing the tasks for that day.
3. Time
Sheets
Employees fill out their own time
sheets, breaking down individual tasks into construction
categories and recording the hours spent doing the work. At the
end of each week, I collect the time sheets and enter the data
by hand onto a master sheet. Back in the office, I transfer
this information to a spreadsheet, which calculates all of the
totals, then I print out a summary report for the notebook
This procedure could be modified depending on how your
company is organized. For example, the foreman could collect
the time sheets and fill out the master sheet by hand on site
using a columnar pad like those used for accounting. Regardless
of how you enter the data, the key point is to record labor
hours by construction category for accurate cost tracking.
4.
Subcontractors
The cover sheet for this section lists all subcontractors
involved in the project, along with their phone and fax
numbers, and mailing addresses. A copy of each
subcontractor’s proposal is filed in this section, as
well as a copy of the subcontractor agreement. Subcontractors
are also given a separate schedule showing just their work, and
a copy of that also goes into this section of the notebook. On
big jobs, this section can be further subdivided by
subcontractor.
The point of having so much information about subs on hand
is to be able to clarify any misunderstandings or discrepancies
in the field without going back to or calling the office. This
saves time, energy, and money.
