When it comes to the long-term energy performance of homes,
there is little doubt — particularly after the recent
spike in oil prices — that the marketplace is going to
start expecting greater accountability and more sophisticated
analysis. It’s essential that those of us on the
supply side (contractors and designers) keep up with the needs
and priorities of the demand side (homeowners and home buyers).
And the first step toward meeting those evolving needs is
understanding the range of strategies we have to choose
from.
In my experience, there are six main ways of thinking about
household energy-efficiency improvements. In implementation,
there aren’t clear boundaries between these
approaches; they’re not mutually exclusive and in fact
there can be significant overlap. But they do represent
distinct ways of thinking about energy improvements —
six different places from which to start the
conversation.
Here they are, in order of analytical rigor:
Do some stuff and hope for the
best
This seems to be how most weatherization work is done these
days. A homeowner has no idea what his home’s current
energy usage is or how it compares with that of similar houses
in the neighborhood, yet he has a general sense that there are
opportunities for improvement. He hires an insulation
contractor — often through a utility-rebate program
— and has some insulation work done. Maybe this leads
to an improvement, maybe not — nobody knows for sure,
because nobody’s really keeping score.
Or perhaps the homeowner has his kitchen renovated. The
contractor, being a savvy, up-to-date “green”
contractor, uses spray foam in the walls rather than fiberglass
batts. Everyone assumes the extra cost is worth it —
but again, no one knows for sure, because there’s no
attempt to compare pre-project and post-project energy usage,
or even to ensure by means of a blower-door test that the spray
foam was installed properly.
Roughly 90 percent of homeowners and contractors, I’d
say, take this approach to energy improvements — which
is why as a nation we’re making such insignificant
progress toward becoming a more energy-efficient society. For
the most part, we’re flying blind.
Do some stuff and measure what
happens
With this approach, you do your usual energy improvements, but
then you actually monitor whether or not those measures reduce
household energy consumption. In my experience, the easiest
analysis is to track Btu consumption from all energy sources
over time and separate out the heating-load component from
season to season based on local heating degree day data.
Predominantly cooling climates will need to track cooling
degree days. A detailed explanation of home energy performance
measurement strategies is outside the scope of this article,
but you’ll find a good general introduction at
homeenergy.org/consumerinfo/benchmark
ing-energy-usage.php.
Once you start keeping score in this way, you’ll be
able to figure out over time what works best, what works a
little, and what doesn’t work at all. Then, building
on that knowledge base, you and your clients can start setting
more specific targets and back them up with established past
performance.
Calculate the payback period
The next step up is the payback calculation, which involves
thinking in terms of what’s cost-effective. For
example, you may determine that it will cost $1,000 to upgrade
your client’s wall insulation, which will reduce his
energy costs by $100 a year, so his simple payback will be 10
years ($1,000 total cost divided by $100 annual savings equals
10 years to recoup the cost). Various tools are available for
this exercise; we use a simple spreadsheet developed by an
energy consultant we work with.
A big problem with thinking in terms of payback period,
however, is that what’s cost-effective is a moving
target — the extreme fluctuations in petroleum prices
have made this abundantly clear.
Let’s say we’re planning an attic renovation
and determine that it will cost $3,000 extra to upgrade the
rafter insulation from R-40 to R-60. At current fuel oil
prices, we estimate the payback to be 25 years, which
doesn’t sound like a good investment to the homeowner,
who takes a pass on the upgrade. In five years, though, fuel
oil prices have doubled or even tripled, and the extra
insulation seems like a much better idea, so the homeowner
gives us a call to see what we can do. Now, however, the
upgrade is not going to cost $3,000 — it’s
going to cost $20,000, because we have to remove the drywall
and insulation and start over.
Energy consultant John Krigger tells an anecdote about a
similar — though larger-scale — issue in
Germany in the 1990s: After reunification, the country embarked
on a major project to add exterior insulation to the
underinsulated masonry buildings in what had previously been
East Germany. The designers calculated that the most
cost-effective approach would be to add 2 inches of exterior
rigid foam insulation with a stucco coating. Halfway through
this massive undertaking, as Krigger tells it, they realized
that the overall trend in energy prices actually made 4 inches
of exterior insulation more cost-effective; the marginal cost
of the extra 2 inches would be relatively small compared with
the updated payback. The contractors were able to shift gears
for the upgrades that had not yet been started, but it was too
late for the buildings that had already been completed. Those
buildings won’t get another chance for several
decades, when they’re next due for major exterior
renovations.
This brings up a complication with the concept of payback.
Many home improvements have an expected service life of 40
years or more, meaning that good opportunities to make truly
significant energy improvements in a particular area of a house
come along only two or three times a century. So when we plan
an improvement we need to anticipate what will be
cost-effective over the course of several decades. This, in
essence, makes “payback” a moral and ethical
debate as much as an economic question: Since few homeowners
can realistically expect to stay in their home for another 40
years, they have to decide what — if anything
— to invest on behalf of future owners and
occupants.
Design to a percent use
reduction
With this strategy, we calculate the owner’s baseline
usage and work out what an aggressive (but not unrealistic)
reduction would be. Say the household uses 60 kBtu per square
foot per year. And say we know from past experience with
similar projects that in the course of a whole-house renovation
we can bring that down by 25 percent — to 45 kBtu per
square foot per year — without stretching the project
budget too much.
That 25 percent sounds pretty good — and it is pretty
good, in fact, by the standards of what’s going on in
today’s marketplace — so everyone is happy.
(We have found that using a HERS — Home Energy Rating
System — index as a metric is the most effective way
to design to a percent reduction, since each one-point
reduction in the HERS score represents a 1 percent improvement.
For more information on HERS scoring go to
natresnet.org.)
The good news with this approach is that you know
you’re making progress that you can quantify. The bad
news is that the degree of progress may be completely arbitrary
or insufficient. If all houses reduce their energy usage by 25
percent in the next 10 years, we’ll certainly all be
better off — but will we be better off enough?
Design to a target energy
budget
Which gets us to the concept of a target energy budget. This
is an attempt to calculate how much a household’s
energy usage should be based on some overarching goal or goals,
which can range from the personal to the global. For example,
some owners might want a home that’s able to weather
an extended power outage; others might want a net-zero-energy
house. Yet other homeowners may have set their sights on
broader, more lofty objectives like national energy
independence and long-term atmospheric carbon
stabilization.
With this approach, you establish the target goal and then
figure out the most cost-effective way to get there. In other
words, the target goal drives what’s cost-effective,
not vice versa — an important shift in thinking.
Let’s say the goal is a net-zero-energy house. You
calculate what the site can produce over the course of a year
from PV and solar thermal, and that becomes the energy budget
for the house. In this case, it might be 17 kBtu per square
foot per year, which becomes the budget you design to.
If, less aggressively, the goal is a house that can be lived
in safely for up to a week with no power, only a
“zone” of the house would need to be operable
on 17 kBtu, while the energy budget for the rest of the house
could be 35 kBtu.
At the opposite end of the spectrum, the homeowners may be
motivated by the goal of a 2000-watt society (en.wikipedia
.org/wiki/2000-watt_society). This would mean an individual
(per capita) energy budget of about 17,500 kilowatt-hours per
year for all activities: work, transportation, food,
entertainment, housing, and so on. Given this overall budget,
you might do some calculations and decide that your household
energy budget should be about 12 kBtu per square foot per
person. (Full disclosure: Doing this sort of mathematical
calculation is really hard, but it can be an eye-opening
intellectual exercise — and we have to start
somewhere.)
The Passive House approach to home design (passivehouse.us) is
based on a similar approach: It sets a very low budget for
household energy usage based on estimates of what a worldwide
sustainable per-capita household energy budget might be, and
then provides the tools to help you design to that
budget.
Don’t forget that when you’re designing to a
target energy budget, the homeowners’ commitment to
living within that budget is really important. Their
willingness to modify their behavior will obviously have a huge
impact on the household’s energy consumption.
Design to specific construction
standards
Designing each project to a specific energy budget —
or even to a percent reduction — requires a lot of
analysis and can get complicated, time-consuming, and costly. A
cruder but generally effective strategy is to establish
insulation, air-sealing, and mechanical-equipment efficiency
standards that you aim for on all your projects.
Periodically you would verify that those are the
“right” standards by measuring actual energy
performance on a range of projects over time.
Here’s one way to set those quality standards: Say
you decide you want your projects to reach a HERS index of
around 50 (prior to any “credits” for PV or
solar thermal), or 50 percent of the anticipated energy usage
of a code-level home. You’d calculate what levels of
insulation, air-sealing, and mechanical efficiency were needed
for a representative project to reach that score. This will
yield a pretty good set of “draft standards”
for you to start working with on all your projects; over time,
you can fine-tune the standards as you gain more data about the
actual energy consumption of the projects.
In our climate region — 5,600 heating degree days
— there’s a growing consensus that the
following are useful target standards, though they still need
to be tested over a wide range of homes:
• R-10 basement floors
• R-20 basement walls
• R-40 above-grade walls
• R-60 roofs
• U-0.20 windows
• Less than 1.0 ACH @ 50 as tested by a blower
door
• High-efficiency whole-house ventilation
It might seem unrealistic to think that you could reach these
levels of insulation — which also happen to yield a
HERS index of around 50, prerenewables — over the
course of just one renovation project. However, such standards
can serve as the framework for an incremental strategy
— a “master plan” that is followed
over time as various parts of a house are improved, repaired,
or replaced. Though not without challenges, this approach will
practically eliminate potential regrets about missed energy
opportunities.
Paul Eldrenkamp owns Byggmeister, a
custom remodeling firm in Newton, Mass.
