A.Bill Palmer, former
editor of Concrete Construction magazine and
president of Complete Construction Consultants in
Lyons, Colo., responds: Cracks seldom degrade
from freeze-thaw action, since water within them
isn't confined and therefore can't cause damage
when it freezes. In addition, most "hairline"
cracks are surface cracks; they don't go all the
way through the slab, so water can't get through
and degrade the subbase. For cracks less than .04
inch wide (about the thickness of a standard paper
clip wire), the aggregate interlock will prevent
any differential movement across them, and repair
is unnecessary. So if these truly are hairline
cracks, the best approach is probably to do
nothing: Whatever crack-repair technique you use
will look worse than the crack.
Even a crack wide enough to allow water all the
way through the slab shouldn't cause any damage if
there's a well-compacted and well-drained subbase;
without that, uneven settlement could occur around
the crack. But keep in mind that cracks this size
are active — they widen in cold weather
and narrow in warm weather — so any
sealant must have enough elasticity to handle the
movement.
If you do decide to seal the cracks, the best
solution for the narrow ones you describe is to
seal the entire slab. Make sure the surface is very
clean, then apply a good solvent-based acrylic
sealer with a pump sprayer. Don't put it on too
thickly, though — it's best to apply it in
two thinner coats — and don't apply it if
the temperature is less than 50°F or greater
than 90°F.
For a broom-finish surface texture, work the
sealer into the surface with a roller. (Sealers
come in both glossy and matte finishes.) Add some
grit — a product such as H&C's
SharkGrip (800/867-8246,
www.hcconcrete.com) should work
— to the mix if the surface seems too
slippery.
