In June, the National Fire Protection Association —
which publishes the National Electric Code — voted to
greatly expand requirements in the 2008 code for residential
use of arc-fault current interrupters (AFCIs). These devices
prevent fires caused by faulty wiring; unlike conventional
circuit breakers (which trip on gross faults) or ground-fault
circuit interrupters (which cut off power to a circuit if they
detect an imbalance between the hot and neutral conductors),
AFCIs trip in response to unintentional arcs in household
wiring. Already, the more stringent rules are provoking debate
within the industry — even though they won't take effect
until January.
Back story. Requirements for AFCIs aren't new: The devices have
been cropping up in the NEC for several years, ever since an
amendment to the 1999 code mandated their use in all bedroom
receptacles. The 2002 code extended that requirement to all
bedroom outlets, including light fixtures, receptacles, and
smoke alarms. And the 2005 code reduced current levels and
required for the first time that the devices detect both series
and parallel arcs. (Series arcs occur when the current jumps a
gap, as when a wire is cracked; parallel arcs form when damaged
insulation allows the current to jump between conductors, or
from a conductor to ground.)
Now the pending 2008 code has gone even further, specifying
combination-type AFCIs — the type capable of detecting
both kinds of arc — in all 120-volt 15- and 20-amp
circuits that supply "dwelling-unit family rooms, dining rooms,
living rooms, parlors, libraries, dens, bedrooms, sunrooms,
recreation rooms, closets, hallways, or similar rooms or
areas."
Advocates tout fire prevention. Gerard Winstanley of the
National Electrical Manufacturers Association (NEMA) contends
that the new AFCI requirement will prevent numerous fatal
fires. "I expect them to have a similar effect to smoke alarms
on reducing fire deaths," he says. "That data will be collected
10 or 20 years down the line." He refers to figures on NEMA's
consumer-information Web site
(www.afcisafety.org) that ascribe 67,800
fires, 458 deaths, and $868 million in property losses to home
electrical problems each year. (It should be noted, however,
that estimates of losses from fires of electrical origin vary
widely according to source; the Underwriters Laboratory Web
site, for example, puts the figures at 32,000 fires, 220
deaths, and $674 million in damages, while a 2006 NFPA report
cites 19,100 fires, 140 deaths, and $349 million in
damages.)
According to Winstanley, the difference in cost between a
conventional circuit breaker and a combination-type AFCI is
typically about $15, meaning it should cost $200 or less to
install a full complement of AFCI breakers in a typical new
home. "That's a fairly small outlay," he says. "Once it's
explained, consumers will accept them."
Opponents predict glitches. Other industry observers, however,
are skeptical; they question not only NEMA's numbers but also
its motivation, noting that the electrical manufacturers
themselves are in the business of selling the mandated
products. Independent NEC expert Mike Holt, for example,
contends that AFCI technology is "not even close" to being
ready for general use. Few electrical contractors, he says,
have experience with the new combination AFCIs, making it
impossible to know whether normal arc-producing events like
distant flashes of lightning or the operation of motorized
devices will lead to widespread nuisance tripping. "I'm totally
convinced there will be a huge problem," he says.
The pending 2008 NEC will require AFCI circuit breakers
— like the ones shown here from four manufacturers
— to protect 15- and 20-amp circuits in most rooms of the
house. Opponents claim the devices are not ready for general
use, and that nuisance tripping will be a problem.
Moreover, Holt scoffs at NEMA's cost figures. "Look," he says,
"if they're smart, electrical contractors are going to figure
out their real costs and add some money for service calls to
the job." He figures that the AFCI provision will cause most
subs to up their bids by $500 to $1,000 per home. "Electrical
contractors will be okay," he says, "but they don't have to
sell that increase to the buyer. I still can't believe home
builders didn't fight this more than they did." — Jon
Vara
Offcuts
• The chief executive of the nation's largest mortgage
lender says that home prices are falling "almost like never
before, with the exception of the Great Depression," reports
the New York Times. According to the paper, Angelo Mozilo of
Countrywide Financial predicts that because there are currently
so many homes on the market, the housing sector will continue
to struggle until sometime in 2008, and will not start to
recover until 2009.
• Union carpenters, cement masons, and laborers in
Washington will get 5 percent to 6 percent raises in 2007,
2008, and 2009 under the terms of a recent agreement between
union representatives and the Associated General Contractors of
Washington, reports the Puget Sound Business Journal. Despite
the nationwide housing slump, the state — particularly
the Seattle area — continues to experience a building
boom.
• Home Depot has agreed to provide free replacement
shutters to South Florida consumers who purchased the store's
shutters in 2006. An investigation by the state attorney
general's office determined that the company had falsely
claimed that the shutters met the stringent wind-velocity
requirements of Broward and Miami-Dade counties. According to
the South Florida Sun-Sentinel, buyers who live outside the
two-county area will be eligible for a 25 percent refund.
Recalls
Milwaukee Electric Tool Co. is recalling about a million
14.4- and 18-volt 2.4-Ah nicad battery packs that could explode
during use or while being charged if an overpressure vent is
compromised or damaged. The company has received reports of
more than 35 incidents involving the battery packs, including
at least 11 injuries.
The recalled batteries — used to power drills, saws,
radios, flashlights, wrenches, and Extractor windshield glass
removers — were sold from July 1999 through 2005 under
the brand names Milwaukee Power Plus (though not all 14.4-volt
packs include the Power Plus label), Chicago Pneumatic, and
Extractor. For more information, call 800/729-3878 or go to
www.milwaukeetool.com.
Southern California
Grapples With Three Trench Collapses — One Fatal
June was not a good month for trench safety in Riverside
County, Calif.: In a period of less than two weeks, three
separate trench collapse accidents — one fatal —
occurred in the Southern California county. State OSHA
officials are investigating all three incidents, but are not
expected to make their findings public for several
months.
The first two incidents occurred on consecutive days at
construction sites only a few miles apart, in the fast-growing
community of Temecula. On June 11, a 21-year-old worker,
Herminio Parra-Alarcon, was acting as a spotter for a backhoe
operator digging a septic-tank hole when he fell into the
12-foot-deep excavation and was engulfed by a wall of dirt. A
co-worker jumped in after him and dug away most of the dirt
around his upper body, then called rescuers. (Actually, the
co-worker was lucky to get out safely himself: According to the
National Utility Contractors Association, an untrained person
who goes into a hole to offer help has a 40 percent chance of
becoming an additional victim.)
More than 80 rescuers worked for seven hours to rescue a
contractor from this excavation in Desert Hot Springs, Calif.
The breadth and depth of the excavation, the loose, sandy soil,
and the victim's position made the rescue especially difficult.
A powerful vacuum excavation truck (note the suction hose at
center in photo above) was used to remove soil from around the
trapped man's body.
An unshorable trench and a life lost. Riverside County Fire
Department spokesman Rick Griggs, who was at the scene, says
two conditions complicated the rescue: First, the injured man
had come to rest directly beneath an undercut bank; and second,
the 14-foot-wide hole exceeded the span of the department's
available shoring. Stabilizing the sides of the hole so that
rescuers could work safely took nearly three hours, Griggs
reports, after which it took about 20 minutes to pull
Parra-Alarcon free.
Shortly before he was lifted from the hole, however,
Parra-Alarcon's condition rapidly deteriorated, and though he
was revived by paramedics after going into cardiac arrest, he
died in the hospital three days later.
Even among victims who are only partly buried, that outcome is
not uncommon, notes Griggs. "It's called ‘crush
syndrome,'" he says, explaining that when blood flow is cut off
by soil pressure, red blood cells die and rupture. "When the
pressure is released, that sends a big surge of potassium into
the bloodstream, which can cause irrecoverable cardiac
arrest."
A stable trench and a life saved. The following day, Riverside
Fire Department responded to a second Temecula call: A
Metropolitan Water District employee had been struck and
injured by a section of concrete form. This rescue, however,
was straightforward: The victim was not buried and the trench
was safely sloped and stable, making it possible for the first
firemen on the scene to simply walk in and carry the injured
man to safety.
Shifting sand and an arduous rescue. A week and a half later,
on June 23, the Riverside team was called to what Griggs
describes as an "extremely complex" situation in the community
of Desert Hot Springs.
A 45-year-old private contractor was trapped at the bottom of a
crater-like excavation — estimated to be 20 feet deep and
20 to 25 feet wide — in loose, sandy soil. The victim,
who had been working with two companions to repair a broken
residential water line, had gone into the hole to remove the
chain from a precast concrete ring when he fell feet-first into
an open stack of previously placed rings. He was buried almost
to his neck in sand.
Because the massive hole was extremely difficult to shore and
the victim's position inside the concrete rings left little
room to maneuver, it took more than 80 rescuers about seven
hours to free him. A powerful vacuum excavation truck was used
to suction soil from the concrete casing enclosing the victim's
body (see photos).
The injured man was taken to a nearby medical center. He has
refused to talk with the media, but the length of time he spent
buried makes it almost certain that he suffered extensive
tissue injury, with a high likelihood of permanent nerve and
muscle damage. — J.V.
