A.Sean Kenney, a master
electrician in Amesbury, Mass., responds:
Using a dimmer switch is an inefficient way to save
energy. You’ve probably noticed that
dimmer switches get warm when in use; while
efficient electronic dimmers don’t get as
hot as the old resistor-based models, they still
heat up, which means that they’re
consuming electricity.
To evaluate a lighting product’s energy
efficiency, you need to consider not just wattage
but also lumens, a measure of light output. Dimmed
bulbs use more watts per lumen than undimmed bulbs
and are therefore less efficient. So a 100-watt
incandescent bulb dimmed to half brightness
consumes more electricity than a 50-watt bulb
operating at full output.
The best way to save electricity is to use the
lowest-wattage bulb possible that will get the job
done. In many circumstances, this means a compact
fluorescent lamp (CFL), which draws roughly 14
watts to provide the same number of lumens as a
60-watt incandescent lamp.
CFLs aren’t without their drawbacks,
however: They take a while to achieve full
brightness, for instance, which can be a problem in
areas where lights get turned on and off
frequently, like stairways and hallways. Also, CFLs
contain small amounts of mercury, which can
complicate disposal. Some electricians argue that
the energy used in the disposal process should be
factored in when calculating a CFL’s total
energy consumption.
