I built my first
timber-frame barn in 1986 at the request of a homeowner who
wanted to replicate the style of an existing barn in town,
which dated from the early 1800s. With permission, I
photographed and examined the details of that building, noting
both its structural details and the aesthetic considerations
that went into its construction. The barn was smaller and
simpler than barns intended to house livestock and tons of
feed, which were often built with massive timbers and pegged
mortise-and-tenon joinery. But with its exposed framing, solid
plank sheathing, and balanced proportions, it still had
tremendous visual appeal.
Once I built that one, a steady stream of barn clients seemed
to spring out of the woodwork. I've specialized ever since,
building barns at a rate of eight to ten each year (along with
some barn rehab work and an addition here and there when the
weather turns bad). The form varies, but the method is pretty
constant. In this article, I'll cover the essential
elements.
What's Wrong with Nails?
The availability of mass-produced nails and bolts in the 19th
century freed up old constraints in framing and house
carpentry, turning joined and pegged timber-frame structures
into quaint relics practically overnight. Liberated from
labor-intensive overlapping and interlocking timber joints,
builders began producing buildings with unheard-of speed. But
the timeless look of a timber-frame building remains popular.
And none of my customers care how their barn is held together
as long as it's strong and looks good. So, in the tradition of
our times, I happily spike butted and mitered framing members
together with common nails and use nail guns to apply planking
and trim. Wherever possible, we conceal the fasteners. I
appreciate and respect traditional post-and-beam framing
methods, but if customers want a barn built purely that way, I
tell them I'm not their guy. My main goal is that the only wood
seen in the final product is solid full-dimension lumber (see
Figure 1).
Figure 1.An all-pine interior reflects the
author's homage to this traditional construction
method, although it's a sure bet that if the
practical-minded original builders had had plywood,
they would have used it. |
Foundations
The underpinnings of the barn vary, depending on the desired
application of the building. Eighty percent of our buildings
serve at least partly for garaging a vehicle or two and, more
often than not, we build on a poured-concrete stem wall and
pour the slab last. In other cases, we build on a monolithic
slab or a wood deck supported on poured-concrete piers (Figure
2). We recently built a barn over a full basement foundation
with a wood I-joist deck that ultimately received a
poured-concrete cap and supported two cars. My clients always
have a specific purpose in mind for their barn beyond
protecting their cars, whether it's a place to build boats,
exercise, or run a home business, so our methods have to be
adaptable.
| The author usually builds on a
poured-concrete stem wall (top). The slab area is
filled and compacted, then poured later. Although a
building inspector may occasionally require post
anchors to tie the vertical structural members to
the foundation, toe-nailed posts are generally
accepted, provided the mudsill is properly bolted
(bottom). Another option is concrete piers and
pressure-treated carriage beams, which greatly reduce
excavation and foundation costs (middle). |
Design
A barn's layout and design are based more on the builder's
seat-of-the-pants sense of proportion than any prescriptive
formula. They're also driven by practical considerations. With
a particular post spacing in mind, I may ask for 28-foot-long
6x6 lintels, but sometimes the mill cuts and ships what's
available. So we may end up with a stack of 14- and 18-footers
instead. For this reason I don't try to fine-tune the lumber
list down to the last board, but buy extra footage instead. My
lead carpenter, Alan Dunham, develops the specific layout on
the first day of construction, and it's different for every
job. While the other crew members sort the lumber drop into
specific lengths, square-cut every piece on one end, and cut
rafters to a pattern, Alan decides how best to use the beam
pile delivered.
The barn frame is assembled from
rough-sawn, full-dimension lumber and sheathed with
nominal 1x10 pine boards, either square edge or
shiplap, depending on whether a secondary siding is
applied. Rigid insulation, applied over the sheathing
and covered with siding and roofing, adapts the barn
for comfortable winter use. |
Framing layout. While the
economy of building on modules based on plywood dimensions
doesn't pertain to traditional barn construction using lumber
sheathing, there are a couple of reasons for sticking with the
typical light-framing layout. First, a 24-inch-on-center joist
layout gives the inspector something familiar to evaluate.
Second, we often use plywood and OSB in my buildings but only
where it doesn't ultimately show. For example, when the
building department decides to designate the upstairs over a
barn garage as habitable space (usually triggered by a bathroom
in the plans), we're forced to hang gypsum firewall downstairs
in the car bays. In that case, I'll use a plywood subfloor
overhead because it will be covered (Figure 3). I'll also use
plywood for a first-floor subfloor when we build on piers or a
full foundation.
Figure 3.Engineered lumber and plywood
find use in concealed locations, such as in a
pine-veneered barn door header, or, in this case, in a
subfloor that eventually will be concealed by a gypsum
ceiling when the habitable space upstairs is
finished. |
