A.Clayton DeKorne responds: According to Tom
Kositsky, a technical representative for the American Plywood
Association, you would not need two layers of plywood for any
structural purpose, as long as you use APA-trademarked
Sturd-I-Floor panels with a 24-inch on-center span rating. (A
complete explanation of the APA ratings, and guidelines for the
use and installation of plywood, can be found in the
APA’s Residential and Commercial Design and
Construction Guide. Single copies are available free from
the APA, 7011 S. 19th St. W., Tacoma, WA 98466;
206/565-6600).
Sturd-I-Floor-rated panels are designed as combination
subfloor and underlayment panels, usually intended to go under
a carpet and pad. In general, a panel intended for use as
"subfloor" is designed as a structural member, with a span
rating (such as 16, 20, or 24 inches on-center) that is clearly
marked on the grade stamp (see illustration, above). For
subfloor, the panel plies are sized (not too thin) and selected
from wood species with sufficient strength in bending and
deflection. By contrast, a panel specifically designated as
"underlayment" has a concentrated core (few voids), so it can
sustain impact loads (say, from a couch dropped by the movers)
and point loads (the weight of a person wearing high-heeled
shoes, for example). As a combination panel, Sturd-I-Floor is
designed to meet the different strength requirements for both
these applications.
All APA-rated plywood includes an exposure classification.
"Exposure 1" panels are made with a waterproof glue, which will
weather temporary conditions during construction, but should
not be used where it will be exposed permanently to the
exterior.
As a permanent floor, painted plywood would leave a lot to
be desired. (I can hear the callbacks already.) For starters,
it would be hard to keep the deck clean, dry, and smooth during
new construction. Blown-in rain and snow, ground-in mud, loose
nails, dropped lumber, scooted ladders, and drywall mud would
leave the deck wet, dinged, scraped, smeared, and dirty —
all of which would compromise the quality of the paint surface.
In addition, Sturd-I-Floor panels typically have C-grade face
veneers that have been patched and sanded. The patches can be
wood plugs or synthetic plastic, which might take paint
unevenly or would show visibly under the paint. Also, the
C-grade face veneer, though sanded, can splinter — not a
desirable effect for a finish floor.
If homeowners are aware of these limitations, of course,
they are tolerable, especially if the intention is to have a
painted-plywood floor temporarily, until they can afford
another finished floor material. If you’re intending the
plywood as a permanent floor, you might want to consider laying
3/8- or 1/2-inch A/C plywood. The A-grade face will hold paint
longer and will have fewer patches.
Clayton DeKorne is a senior editor for the Journal of
Light Construction.
