A.Mike DeBlasio, a masonry
contractor in Littleton, Mass., and a member of the
Scaffold Industry Association, responds: OSHA
doesn't specifically prohibit the use of forklifts
and rough-terrain forklifts to elevate personnel,
but there are a number of restrictions that
severely limit their use for this purpose.
For one, the manufacturer of the forklift has to
specifically allow the use of a work basket, in
which case the company typically will offer an
approved model as an optional accessory. The width
of work baskets is limited by the wheel base of the
forklift; according to OSHA and ANSI requirements,
baskets can extend no more than 10 inches past
either side of the load-bearing tires.
On an 8-foot-wide forklift, for example, the
allowable work basket could not measure more than
116 inches wide (96 inches + 10 inches + 10
inches).
These work platforms must meet OSHA scaffold
standards in terms of capacity, construction,
access, use, fall protection, and training, and the
operator of the forklift must be fully trained and
licensed.
In cases where the manufacturer does not address
the question of whether its machine may be used for
this purpose, there's more of a grey area.
First, the employer or contractor needs to
either find out from the manufacturer if the
forklift was, in fact, designed for this use, or
have a registered PE certify that it was. In
addition, the engineer would need to certify that
the supported scaffold being used in conjunction
with the forklift complies with applicable
requirements in terms of capacity, construction,
access, use, and fall protection.
Also, these forklift-supported platforms can be
used only when the contractor has determined that
no other practical options — such as
scaffolds, scissors lifts, aerial lifts, or ladders
— could be used instead.
Keep in mind that, regardless of the platform
design, you can't use a forklift for elevating
personnel platforms if this is specifically
prohibited by the manufacturer or by the operator's
manual.
