Cutting Fiber-CementContinued
The Makita 5057KB 110-volt 7 1/4-inch saw with dust
collector is excellent for production fiber-cement siding work
($329 retail, replacement blade is $33 retail). It's solidly
built and lightweight, and cuts any type or size of
fiber-cement material available. If you had to choose just one
tool, this would be the one. It will make very smooth cuts
through five pieces of siding at once (Figure 6). With a
cement-cutting diamond-tipped blade, it cuts smoothly and
leaves the stock virtually flawless.
Figure
6. If you had to choose just one tool, the
Makita 5057KB 110VAC, 7 1/4 inch circular saw with dust
collector (left) would be the one. The Makita 5044KB
4-inch circular saw with dust collector (right) is a
compact saw that's as solid as the larger Makita, and
will cut two pieces at once quite
effectively. |
Another option from Makita is the 4-inch 5044KB with dust
collector. This practical little saw is compact and great for
tight spots. It won't cut as many pieces at a time as the
larger model, but it's much more portable. I've used this one
25 feet up on a scaffold with no problem ($289 retail,
replacement blade is $25 retail).
The Makita 5036DWA 18-volt, 61/4-inch cordless is an
excellent tool for portability or where electric power is not
available (Figure 7). It's not completely dust-free, but the
collector does cut down on most of the dust. Teamed up with the
24-inch manual shears, this saw will get you through the job,
but I would not recommend it for large jobs. It's especially
good for small, quick repairs ($379 retail, replacement blade
is $26 retail).
| Figure
7. The Makita 5036DWA 18-volt cordless
fiber-cement saw with dust collector. (PHOTO:
MAKITA) |
Blades. I tried blades made by American Tool,
DeWalt, Hitachi, Magna, and the stock Makita blades that came
with the saw. The blades all worked about the same, which was
very well. I've been using some of these blades for almost
eight months and they are not even close to worn out.
Typically, these blades have either four or six teeth. Those
with more teeth cut smoother, but the blades with fewer teeth
definitely last longer (see "").
What to Buy
I'd advise anyone who installs cement siding with any
frequency to invest in at least one set of nippers and one good
dust-collecting circular saw with cement-cutting diamond-tip
blades. For larger or commercial projects, a 14-inch pneumatic
shear is a good investment. For the contractor who only
occasionally works with cement siding, or for the one-time
installation, it's possible to get by with the old reliable
circular saw using a diamond-tipped fiber-cement blade.
Rodney Proctor is a general contractor from Cedar Park,
Tex.
Fiber-Cement Blades
There are several new blades designed
specifically for fiber-cement. Although regular
carbide blades will cut fiber-cement, they won't
last long and they will make a mess. The dedicated
blades are definitely an improvement: They last
much longer (we don't know how much longer yet, but
manufacturers' claims vary from 100 to 225 times as
long as regular carbide blades), and they produce a
lot less dust.
American Tool Fibercut
Blade. Available with four diamond teeth
($90-$100) for cutting stacks of material and a
6-tooth model with carbide teeth ($20) for cutting
single sheets; American Tool, 92 Grant St.,
Wilmington, OH 45177; 800/866-5740;
www.americantool.com. (PHOTO: AMERICAN TOOL)
Hitachi Fiber-Cement Saw
Blade. Developed in co-operation withJames
Hardie Building Products, this 4-tooth blade uses
polycrystalline diamond (PCD) tips. A layer of
powdered diamond is bonded to the tungsten-carbide
tips through microwave heating, $69; Hitachi Power
Tools, 3950 Steve Reynolds Blvd., Norcross, GA
30093; 800/546-1666;
www.hitachi.com/powertools.
DeWalt Fiber-Cement Saw
Blade. Six-tooth polycrystalline diamond
blade with a 5-degree negative hook angle for a
better finish on the cut. Suitable for single or
stacked cuts, $59; DeWalt, P.O. Box 158, Hampstead,
MD 21074; 800/433-9258; www.dewalt.com.
Magna M87340 Fiber-Cement
Blade. Four-tooth chemical-vapor deposition
blade, with 10-degree positive hook angle for ease
of cutting and longer blade life. From $65 to $71;
Magna Industrial Tool , 101 S. 5th St., Louisville,
KY 40202; 800/624-9044; www.magnatool.com.
