- Q.We ordered preprimed
HardiePlank lap siding to finish a project, but when it
was delivered, we discovered that the backs were left
unprimed. Normally, we back-prime wood clapboards, but
I’m not sure this step is needed with
fiber-cement siding, and the manufacturer’s
Web site is mute on the subject. Is back-priming
necessary?
A.Mark Parlee, a builder
specializing in siding installations in Urbandale,
Iowa, replies: You’re right to be
concerned about the moisture resistance of
fiber-cement siding, but carefully following the
manufacturer’s installation guidelines
will have more of an impact on the
siding’s performance than back-priming.
According to Rick Crotts, my local James Hardie
representative, it’s not necessary to
back-prime any of the company’s
fiber-cement siding products. He says that when
panels are primed in the factory, some primer ends
up on the back of the boards as they pass over the
rollers, but this isn’t a half-hearted
attempt at priming the backs. Hardie actually
infuses its fiber-cement substrate with a primer
during the manufacturing process to improve paint
adhesion, Crotts says.
My company installs a lot of fiber-cement siding
(10 to 12 houses per year), and in our experience,
paint failure occurs only when the siding wicks up
excessive moisture because of poor detailing, such
as insufficient clearances at cheek walls and
missing kick-out and diverter flashings.
