by Jake Loeffler
It's often said that trends start on the West Coast and
gradually work their way eastward. One example is the
conversion of garages into places where homeowners can enjoy
automotive and DIY hobbies; by adding cabinets, slat wall, and
durable floor finishes, contractors can transform ordinary
garages into enticing recreational spaces.
After years of watching this specialty grow, I decided the time
was right to bring it to northern Vermont. My company, Garage
Outfitters, specializes in garage conversions and is a
Slide-Lok dealer (800/835-1759,
www.slide-lok.com). Slide-Lok distributes
the cabinets, slat wall, and organization accessories I install
and the concrete-slab floor coatings I apply. It's not a
franchise, but the arrangement provides me with referrals and a
protected territory. In addition to floor coatings and
cabinets, I can install appliances, lighting, automotive lifts
— virtually anything the client wants.
The following project is typical of the work we do. The client
had recently bought a brand-new Corvette and he wanted a
good-looking, well-organized place to keep it. He also uses his
garage for storing lawn and garden tools, sporting goods, and
anything else that doesn't fit inside his suburban
split-level.
Floor Coating
As is typical, the first part of this project consisted of
preparing the floor for the Flexmar polyaspartic coating
(724/339-1442, www.flexmarcoatings.com). This two-part
paint — which is often confused with epoxy — offers
some significant advantages over epoxy coatings. For one, it
dries much quicker, so it can be installed and put into service
faster. In warm weather, we can usually walk on the first coat
within an hour or two, and we typically complete the entire
three-coat process in one day. The client can drive on the
floor 24 hours after we finish.
Polyaspartics also have a wider working temperature range than
epoxies; they can be installed in temperatures from 140°F
down to -30°F, while many epoxies need temperatures of
55°F or higher. Polyaspartics also perform better than
epoxies in ASTM tests for color retention, adhesion, wear
resistance, and flexibility. The manufacturer suggests a
calcium chloride test before application and won't guarantee
installations with vapor transmission rates exceeding 3 pounds
per 1,000 square feet (see "Testing for Moisture in Concrete
Slabs," 6/07).
The coating carries a lifetime guarantee against fading and
yellowing and a 15-year warranty for peeling, flaking, and
excessive wear. It comes in three main colors, with numerous
custom options available. I keep the various components in
inventory; you won't find these products at your local paint
store.
Preparing the Slab
We start out by grinding the floor with 50-grit diamond pads in
a dust-collecting upright grinder. For edging, we use a smaller
grinder mounted on a three-wheeled cart; it too has a
dust-collection system (see Figure 1). The slab should be free
of adhesive and solvent residues. We learned this the hard way
on one of our first commercial jobs, a showroom with glue-down
carpet. The adhesive residue clogged the diamond pads and made
for slow going and long workdays.
Figure 1. To prepare the garage slab for a
two-part polyaspartic coating, the author grinds the surface
with 50-grit diamond pads. He uses the larger machine (previous
page) in the field and the smaller one (above) around the edges
and on the sloping apron near the overhead door. Both are
connected to a high-performance dust-collecting vac.
Once the slab is ground and any remaining dust vacuumed, we
patch cracks and pockmarks on the surface with a two-part
patching compound combined with sharp-edged silica sand. Since
the liquid patch hardens within a minute or two, we make small
batches to minimize waste. We pour it over the sand, let it
cure, and then grind it with a diamond cup wheel in a
dust-collecting grinder (Figure 2).
Figure 2. Workers fill cracks and
pockmarks with silica sand, then pour on a rapid-setting
two-part compound (top). After it dries — which takes
only a few minutes — the compound is ground with a
hand-held grinder that's equipped with a 50-grit diamond cup
wheel and connected to the dust-
collecting vacuum (bottom).
Color Prime Coat
Before mixing the colored prime coat, we make sure we have all
the materials and equipment on hand, because once the two parts
are combined we have only a half-hour or so of working time. We
cut in around the edges with a 3-inch chip brush and use a
3/8-inch nap roller in the field. An 18-inch-wide roller covers
a lot of ground with each pass (Figure 3).
Figure 3. The two-part polyaspartic
coating is applied with an 18-inch roller and cut in with a
3-inch chip brush (top left). Once the second coat is half
done, the author starts spreading the vinyl chips (top right)
that give the floor its distinctive look and dirt-hiding
qualities (bottom).
The polyaspartic coating is extremely thin, like water, so it
really seals and penetrates the surface — unlike more
viscous epoxies, which tend to stay on the surface. We roll the
floor in one direction — usually front to back —
and then roll on another coat in a side-to-side direction. Our
goal is even coverage with 3 mils of wet thickness and no lap
marks.
When the floor is all covered, we speed the drying process with
a pair of squirrel-cage blowers.
Clear Chip Coat
With the blowers running, we prepare for the next step —
the clear chip bed coat. The chip coat is what gives the floor
its distinctive appearance.
We begin by applying a clear coat of the polyaspartic paint to
the floor, working much as we did with the first color coat,
but with spiked overshoes so we don't track up the finish. When
about half the floor is covered with the clear coating at 2
mils thickness, we start spreading handfuls of vinyl
chips.
It's important to work fast; if the coating dries, the chips
won't stick and we'll have to redo this step. The job requires
a two- or three-person crew. With two people, one cuts in and
rolls and the other spreads the chips; with three, one person
cuts in, another rolls, and the third spreads the chips.
Once the floor is completely coated and the chips are applied
in an even layer, we start the blowers again and head to lunch.
If we start a job by about 8 or 9 a.m., we can usually go to
lunch by 12:30 or 1 p.m. — but we won't leave before this
step is completed.
Top Coat
After we get back to the job, I use an electric leaf-blower to
gather the excess chips into a corner, so we can pick them up
for reuse (Figure 4). Then we scrape off any remaining loose
chips with floor scrapers (the kind used for removing vinyl
flooring).
Figure 4. After excess chips are swept
into a corner with a leaf blower (left), the floor is scraped
in two directions to dislodge any remaining loose pieces
(right).
The final step is to apply two clear finish coats. (Since clear
polyaspartic coatings won't yellow with time, they are ideal
not only for this application, but also for protecting stained
and dyed concrete in both interior and exterior
settings.)
As with the color coat, we mix two parts in a one-to-one ratio.
We pour some of the mixture onto the floor and spread it with
the roller and the chip brush (Figure 5). We roll the two coats
in opposite directions to ensure uniform coverage; the final
thickness should be 6 mils. Then we clean up and head for
home.
Figure 5. A clear top coat protects the
chips and makes the garage floor shiny and easy to clean. It's
mixed and applied in much the same way as previous coats,
except it's poured directly on the floor and spread from there.
Rolling the entire floor front to back and then side to side
ensures uniform coverage with no lap marks.
Slat Wall and Cabinets
The next day we start installing the slat wall, which is a lot
like putting up lap siding: You start at the bottom and work
toward the top, making sure to land any seams on studs. Every
garage is different, but we add framing and blocking as needed
to provide flat, solid backing. We fasten the 8-foot plastic
panels with 2-inch screws driven into the framing at every slot
(Figure 6). H- and C-shaped moldings hide cut edges and provide
a finished appearance.
Figure 6. Installed much like lap siding,
the plastic slat wall is screwed to the framing and furring
with 2-inch color-matched screws. Hooks and organizing
accessories are installed last.
Slide-Lok cabinets come in four colors and have a lifetime
warranty. All are constructed with sturdy dovetail joints and
plywood carcasses. Although they're shipped knocked down, they
are easy to assemble, requiring little more than a bottle of
wood glue and a hammer to drive the nails that secure the
back.
Once the cabinets are installed, we usually add a post-form
countertop for a workbench and install a variety of
organization accessories on the walls. The homeowners can
contact us for additional accessories once they figure out what
suits their needs.
The project shown here cost the customer about $6,000 and took
about 40 man-hours over three days to complete. Now the owner
has a great place to entertain friends and neighbors who share
his interest in cars, and he no longer has to search for his
tools and detailing supplies.
Jake Loeffler owns Garage Outfitters in
Jericho, Vt.
