- Q.The new water-based
urethane finishes are easier to apply than the old
solvent-based polyurethanes. But are they as
durable?
A.Painter Dan Greenough, a
member of PaintCraft Associates, a San Francisco
Bay-area guild of professional finishers,
responds: I have found that with most
water-based varnishes, an extra coat is required
for adequate coverage and protection of the
surface. According to Flecto, a manufacturer of
varnishes (800/635-3286), their water-based
Varathane Diamond Finish is "very close" in
hardness to their oil-based Liquid Plastic Interior
Wood Finish. Experience and logic tell me that most
water-based clear finishes are not quite as hard as
their conventional oil-based equivalents.
Water-based finishes have some definite
advantages. Because they have relatively little
odor, they are appropriate for use in occupied
homes where the clients are sensitive to odors.
Water-based finishes dry quickly, allowing several
coats to be applied in one day. They also dry
clear, without the yellowing associated with
oil-based polyurethanes.
These advantages also point to some potential
disadvantages. Fast drying sometimes results in
more prominent brush strokes. Some clients prefer
the amber color of oil-based polyurethanes.
Finally, water-based clear finishes always raise
the grain of the wood. This increases the sanding
time, which is an additional cost.
