A.Carl Hagstrom
responds: When nail holes are filled prior to
staining or clear coating, it’s difficult
to get a good match. The filler will always absorb
stain or finish at a different rate from the wood,
and it typically ends up darker. Preparing a test
board and filling holes with different blends of
filler will help, but it’s a
time-consuming process.
A much simpler (and practically foolproof)
method is to use a product called Color Putty
(Color Putty Co., 121 W. Seventh St., Monroe, WI
53566; 608/325-6033). This linseed-oil-based putty
is about the consistency of Play-Doh, and
it’s available in more than a dozen
wood-tone colors. For best results, first apply any
stain and all finish coats and allow them to dry,
then fill the nail holes with the Color Putty. Use
your thumb to push the putty into the holes, and
wipe off any excess with a paper towel dampened
with denatured alcohol. I wear a pair of latex
gloves to prevent the color pigment from working
into my skin.
The directions on the container recommend
applying the final finish coat after filling the
nail holes, but this can cause problems. If excess
putty isn’t completely removed by the
denatured alcohol, the residual putty haze will
show through the finish coat.
By kneading two or more colors together, a wide
range of color variations are possible, and with a
little patience, you can achieve a perfect match.
One caution: Never use denatured alcohol to wipe
down an alcohol-based shellac finish. Most other
finishes will not be harmed by denatured alcohol,
but it’s always a good idea to test the
finish in an inconspicuous area.
Carl Hagstrom is an associate editor
of the Journal of Light
Construction.
