For many decades on Cape Cod, masons have routinely used a
single, large sheet of lead to create a through-pan flashing
for their chimneys. The main reasons for using lead pan
flashing include speed and economy and, in most cases, the lead
eliminates the need for a constructed cricket on the upslope
side of the chimney. Though I think they're ugly, I've never
seen a properly made pan flashing leak, so if that's what
customers want, that's what I give them. The general principle
behind pan flashing is that any water entering the chimney,
whether by absorption or directly down the flue, will be
redirected back out through weep holes once it hits the
integral barrier inside the flue. Whether building a new
chimney, or rebuilding above the roofline, the basic process is
to bring the masonry line up a little higher than the roof
plane, completely cap it with a single sheet of lead, and then
complete the chimney construction.
Chimney Rebuild
On a recent remodeling job, the asphalt roof shingles had just
been replaced, and the roofers had conscientiously replaced the
old chimney's lead step flashing, turning and caulking it into
the face of the brickwork. However, due to the roughly 40-year
age of the chimney, freeze-and-thaw cycling had taken its toll
on the bricks, mortar, and concrete cap. The chimney still
leaked, and a rebuild was called for, from the roofline up.
Building a baseline. I began by covering the
roof below the work area with a tarp to protect the shingles,
and set up staging just below the chimney, which measured 28
inches across by 24 inches on the sloping side. I tore the old
masonry down to just above the roofline, leaving the step
flashing and the bricks that it covered in place (see Figure
1). The existing ceramic flue was a large, discontinued size
but still in good condition, so I set it aside for reuse. Using
a 7 1/4-inch-diameter diamond-abrasive circular saw blade and
the plane of the roof as a guide, I cut through the lead and
the brick, making repeated passes to cut as deeply as the blade
allowed on the two sloping sides of the chimney. The offset of
the saw's shoe kept the cutline about 2 inches above the actual
roofline. The blade didn't cut all the way through the brick,
but did go deep enough so that I could finish the cut with a
chisel. Chiseling fractured a few of the bricks, so I replaced
them to create an even, sloped plane.
| Figure 1. Newly
replaced stepped flashing won't stop the leaks in a
failed chimney but will remain in place under the
pan as a secondary barrier, to prevent wind-driven
water penetration.
Leaving the existing lead kept a vital, primary skirt of
flashing in place around the chimney's perimeter (Figure 2).
The exposed pan flashing actually serves to counterflash the
concealed base flashing. Without base flashing installed,
wind-driven rain would find its way into the building.
Figure 2. Using
the roof to guide his circular saw, which is fitted
with an abrasive diamond masonry blade, the author
cuts through the lead and brick on either side of
the chimney parallel to the slope (left). The flue
tile is marked with a pencil, removed, cut, and
replaced. Gaps in the brick are filled and parged
with mortar to provide a smooth, even base for the
lead pan (right). The basic layup is identical in
new construction, minus finished roofing and
flashing.
Fail-safe underlayment. On a new chimney, I
cut bricks to match the angle of the roof and lay them parallel
to the roofline, about 2 inches higher than the surrounding
roof deck on all four sides. Ideally, the chimney goes up
before the finished roof goes on. I use 12-inch-wide strips of
Vycor Plus, a sticky, self-adhesive bituminous membrane (Grace
Construction Products, 62 Whittemore Ave., Cambridge, MA 02140;
800/444-6459; www.graceconstruction.com), as a fail-safe
underlayment around the chimney. It sticks as well to brick as
it does to plywood. I install it just like flashing, working
from bottom to top, making the transition from the roof deck up
onto the face of the chimney. It's important to install a layer
of asphalt felt paper at the bottom of the chimney first to
serve as a bond-breaker, so that the Vycor can later be lifted
and interwoven in a bottom-to-top sequence by the roofers. I
leave the installation of the metal base flashing to the
roofing crew, making sure to inform the builder of the
importance of this step in the flashing sequence. If there's a
leak, I don't want any part of the blame game. I recommend
using lead for the apron flashing, stepped flashing, and head
flashing under the lead pan to avoid any chance of a galvanic
reaction between dissimilar metals.
