By Larry Garnett,
AIBD
Over the last ten years or so, residential designers have made
tremendous progress in offering open floor plans. Eliminating
long hallways and unnecessary walls are both good ways to
impart a spacious feel. Too much emphasis on openness, however,
can lead to a floor plan that looks great on paper but doesn't
work very well for the homeowner.
Traffic Patterns and Privacy
One of the most critical elements of any floor plan is its
handling of traffic patterns — the routes that
occupants follow as they travel from one room to another.
Fortunately, it's not difficult to determine how well a given
floor plan performs in this respect: Just imagine living in the
house and walking from one area to another.
As you enter the home from either the front door or the side
entrance, for example, how convenient is it to walk to the
kitchen? Do you have to cut across the family room to get
there? What if you want to move from the living area to the
master bedroom? Ideally, you should be able to move from one
area to another without crossing directly through any other
room along the way. Traffic-pattern conflicts are especially
common in and around centrally located family rooms, which
frequently double as circulation areas.
The poor plan layout in the original version of Figure 1, for
example, forces traffic to swing around a kitchen peninsula
that juts out into the family room.
Figure 1.The original plan
(above) has two major problems: A protruding kitchen counter
interrupts traffic flow and takes space from the family room,
and there's no buffer between the public space of the family
room and the private master suite. In the improved version
(right), removing the kitchen peninsula allows foot traffic to
take a direct path from the garage to the bedrooms. The
addition of a short hallway to the master suite sacrifices some
of the walk-in closet in the master suite, but adds privacy and
improves the family room by eliminating through
traffic.
This limits furniture placement and makes the family room much
smaller than it might be. The absence of hallways in the plan
introduces another problem: Note how the master suite, although
tucked away at one end of the house, opens directly onto the
family room. Obviously, there's a serious lack of privacy
here.
Addition by Subtraction
Even a very small hallway can create a sense of privacy for a
bedroom. In the improved version, a walk-in closet has been
scaled back to make space for a short hallway linking the
master suite to the front of the house. To smooth out the
traffic flow and make better use of the family room, the
kitchen has been altered to get rid of the protruding
peninsula.
Both improvements illustrate an important point: Open plans
are appealing because they make it possible to fit a lot of
living space into a given footprint. But that compactness can
also tempt a designer to cram more amenities into a plan than
it can comfortably hold. When evaluating a floor plan, keep an
eye out for unnecessary or oversized elements. Eliminating or
downsizing them can be a net gain if it leads to a roomier,
more functional design.
Circulation Galleries
Where a hallway isn't needed for privacy, a designated traffic
area, or gallery, can be an excellent way to improve
circulation. In effect, a gallery is a hallway without the
walls — a planned pathway that promotes efficient
movement without detracting from the open feel or restricting
natural light.
To see how that can work, consider the original version of the
plan in Figure 2. Someone walking from the back door area to
the bedrooms has to walk around two sides of the family room to
get there, and because there's no clearly defined pathway
between those points, people are likely to encroach on the
family-room space by cutting the corner. Another problem is the
awkward access to the kitchen, which can only be reached
through the dining room at one end or the breakfast nook at the
other.
In the original plan (above), an
awkwardly placed back door and restricted access to the kitchen
make for poor circulation, especially between the breakfast
nook and the bedrooms. Moving the door and opening up the
kitchen allow traffic to flow more smoothly, while shifting the
fireplace turns the focus of the family room away from the
adjoining circulation areas (right).
In the revised version, a few relatively minor changes make a
big difference in comfort and efficiency. Relocating the back
door and creating a new opening to the kitchen form a pair of
logical traffic pathways that meet at a central "intersection."
The floors of the resulting galleries have been covered with
tile to further establish the designated walkways and prevent
foot traffic from spilling over into adjoining areas. (An added
practical benefit of this approach is that the hard-surfaced
gallery floors are easy to keep clean and resist wear better
than carpeting.)
Finally, the columns in the revised plan (Figure 3) could be
configured in several different ways, depending on the effect
desired.
Figure 3.Two views from near the back door of the
original and revised plans in Figure 2 highlight the effect of
the added circulation galleries. In the original plan (left),
it's difficult to tell where the circulation space ends and the
family room begins. In the revised version (right), their
separate functions are defined by the columns, header, and
change of flooring; the added opening to the kitchen also
improves traffic flow.
Connecting the columns with a header that meets the wall at a
pilaster tends to separate the passageway between the bedrooms
and the kitchen from the adjoining family room. Another option
would be to eliminate the header and pilaster and run the
columns to a flat ceiling plane for a more open feel.
Larry Garnettis a designer in Glen Rose, Texas.
